Lemur Iphone5 apps to control the GR55
Started by xtian82, November 20, 2013, 11:42:58 AM
xtian82
Here is the first version of a Lemur module dedicated to guitarist who would like to control the main parameters of the GR55.
All the controls are bi-directionals except the standard guitar selection switch and level that reach the limitation of 256Bytes SysEx in reception.
To make it working, you need:
- An Iphone 5
- The Lemur application
- a Midi controller for the Iphone (iRig Midi or an UCX Fireface for example). It doesn't work with the IODock from Alexis as it doesn't support the SysEx messages transmission.
QuoteMidi controller for the Iphone
BTW - If you use IOS7, and have a Iphone 4S or newer, then the APPLE Camera Connection Kit is now supported on iPhone, and these MIDI I/O cables can also be used
Please use search prior to posting new subject/topics.
Here is a prior thread on controlling GR55 with Lemur
https://www.vguitarforums.com/smf/index.php?topic=5379.msg37428#msg37428
How to use Advanced Search Tool
https://www.vguitarforums.com/smf/index.php?topic=2978.0
