Author Topic: Quality of Uneeksupply Roland-Compatible Cables  (Read 1678 times)
Offline Ed Driscoll
« on: September 30, 2012, 08:58:56 PM »
Hi all,
Not sure if this is the right forum for this topic, and mods feel free to move if necessary. But I was wondering what the consensus was regarding the Roland-compatible cables sold by Uneeksupply.com. I'm thinking of buying one or two of their ten-foot cables, but there appears to be conflicting reports in older threads as to whether or not they're compatible right of the box with GK-devices.
In any case, is there a better source you can recommend for shorter GK-compatible chords?
Thanks,
Ed
« Last Edit: July 16, 2016, 02:49:52 PM by Elantric »
Offline DeRigueur
Re: Quality of Uneeksupply Roland-Compatible Cables
« Reply #1 on: October 03, 2012, 11:29:03 AM »
Hi Ed,
I've had good luck with those cables.
I wrote a review for the 20' version on their website.
Fender VG Strat -- Boss GP-10 -- Alto TS112A
Offline Ed Driscoll
« Reply #2 on: October 03, 2012, 11:32:50 AM »
Thanks. I thought somebody had mentioned incompatibility issues here, and I just wanted a reality check before I ordered a couple.
Offline Elantric
« Reply #3 on: October 03, 2012, 11:44:38 AM »
I understand third party cables can vary in quality by a wide margin.
http://www.ebay.com/itm/10-foot-13-Pin-Roland-Data-Cable-GKC-5-VG-8-GR-2A-GK-10-Feet-10-FT-/110758623227?forcev4exp=true&forceRpt=true
 - and I advise anyone ordering any 13pin cable to use a volt / ohmeter after delivery , and verify that all 13 pins are wired straight through to both ends of the 13 pin cable - BEFORE you connect it to your Roland gear.
Don't assume that the 13 pin cable is Roland compatible, even if the seller tells you it is.
Bulk of 13 pin DIN cables on this planet are designed for Kenwood / Alpine car stereos - which use a similar looking 13 pin cable for their remote CD changers, and those will NOT work with your Roland gear.
« Last Edit: October 03, 2012, 12:21:37 PM by Elantric »
Offline Ed Driscoll
« Reply #4 on: October 03, 2012, 11:53:42 AM »
Can a third-party cable damage your gear?
Offline Elantric
« Reply #5 on: October 03, 2012, 12:06:23 PM »
Absolutely  - if its not wired correctly
Roland Cables are wired with ALL 13 pins wired  1:1
in other words
Pin#1 = Pin#1
Pin#2 = Pin#2
Pin#3 = Pin#3
Pin#4 = Pin#4
Pin#5 = Pin#5
Pin#6 = Pin#6
Pin#7 = Pin#7
Pin#8 = Pin#8
Pin#9 = Pin#9
Pin#10 = Pin#10
Pin#11 = Pin#11
Pin#12 = Pin#12
Pin#13 = Pin#13
Compare to a Kenwood cable - which has many pins tied together and internally shorted  or not connected.
Offline Ed Driscoll
« Reply #6 on: October 03, 2012, 05:31:10 PM »
So does anybody make shorter (ten feet or less) GK-style patch cables that are forum approved?
Offline Elantric
« Reply #7 on: October 03, 2012, 05:36:44 PM »
For any 13 pin cable, either purchase from a seller with a decent return policy, or factor into the cost that the cable you purchase might be incompatible.
Many sellers of "Roland Compatible" 13 pin cables are selling a quality product.
And myself, I have purchased several from ebay sellers and never had any problems.
But again, I have heard horror stories from other forum members who purchased from the same ebay seller a few weeks later.
Many times the pic of the 13 pin cable in the ebay ad does not match the actual cable that was shipped.
http://www.vguitarforums.com/smf/index.php?topic=1584.msg12995#msg12995
Roland includes two short 13 pin cables with each Roland US-20.
http://www.rolandus.com/products/details/61
GK Connecting cable
Part Number C-13D
(1.2 meters length)
Call Roland Parts department for pricing of GK 13 pin cables, they should have different lengths available:
Roland Customer Service Tel# is (323) 890-3700.
Customer Service is available Mon-Fri, 8:30am to 5pm Pacific Standard Time.
Carvin sells 13 pin cables too:
http://www.carvinguitars.com/products/C20P13
« Last Edit: October 03, 2012, 06:27:42 PM by Elantric »
Offline Philip
  • Contributing Member
  • Total likes: 0
  • Rating: 0
  • Modding guitars and effect devices
« Reply #8 on: December 05, 2012, 07:56:55 AM »
Just got my cables from uneeksupply at ebay. It is a Kenwood cable, incompatible. You can hear all the strings at totally different volumes and still hear the A string even though the volume is down. See the sticker on the cable, I suppose KEN stands for Kenwood.
Main gear: Godin Freeway SA with Graph Tech stuff, Telecaster lite ash with Graph Tech stuff, G-Sharp with GK-3a, Ibanez Gio Mikro with GK-Kit-GT, GR-55's (plural), Focusrite Saffire Pro 24 DSP, Amplitube 3 on Macbook Pro, Line6 POD HD500, 2x FRFR RCF 310A
Offline Elantric
« Reply #9 on: July 16, 2016, 02:51:45 PM »
Codesmart often sells these  - shoot him a PM
http://www.vguitarforums.com/smf/index.php?topic=13234.0
