Author Topic: Deoxit alternative  (Read 2601 times)
Offline zaknbou
Deoxit alternative
« on: September 21, 2012, 11:27:05 AM »
hi guys,
i guess it is time to clean my 13 pin cable as my E string is dropping with a very low sound, i still have the axon cable that came with the AX 50 USB so i am using again but there is also a hum with it...
i need to clean my 13 pin cables but where i live i don't have the deoxit, can i use any home made stuff instead, donna know maybe alcohol, or glass cleaner  :-\ ;D 8) :o ;D ...oups... any recommendation ???
« Last Edit: September 21, 2012, 12:58:01 PM by Elantric »
Offline Elantric
« Last Edit: September 21, 2012, 01:00:28 PM by Elantric »
Offline papabuss
Re: Deoxit alternative
« Reply #2 on: September 21, 2012, 03:21:58 PM »
THX for the link
about 5 € plus delivering for 100ml or nearly 9€ plus delivering  for 200ml.
I 'll think about ordering this (must be a good one) German product because I' ve also had these "wellknown problems" from time to time. If I test/order it I will tell you about how it works... :)
« Last Edit: September 21, 2012, 03:31:58 PM by papabuss »
Offline curteye
« Reply #3 on: September 21, 2012, 08:15:47 PM »
Aloha guys,
One would think that any type of electrical
contact cleaner would work but perhaps not.
It would be nice to get an 'official' word from Roland on this.
All I could find in the manual about maintenance was
only about the GR-55.
Nothing about the cable.
From the manual:
Maintenance
• For everyday cleaning wipe the unit with a soft,
dry cloth or one that has been slightly dampened with water.
To remove stubborn dirt, use a cloth impregnated with a
mild, non-abrasive detergent.
Afterwards, be sure to wipe the unit thoroughly with a soft, dry cloth.
• Never use benzine, thinners, alcohol or solvents of any kind, to avoid
the possibility of discoloration and/or deformation.
HTH
If yer gear ain't breakin' down, you ain't workin' much.
Offline jcessegismundo
« Reply #4 on: September 22, 2015, 12:54:16 PM »
WD40 Maybe i can use it? ? or color nail remover hehehe?
Offline Elantric
« Reply #5 on: September 22, 2015, 01:18:19 PM »
In Asia
http://store.caig.com/s.nl/sc.15/category.5933/ctype.SS/SS.5933/.f
Lieder International Company
Hong Kong   San Po Kong
011-852 2717 0774
Email tv8888@gmail.com
Clarity Development Ltd
Hong Kong   Mongkok
011-852-2150-1957
info@clarityd.com
http://www.clarityd.com/main/en/caig.html
« Last Edit: September 22, 2015, 01:23:48 PM by Elantric »
Offline HAMERMAN409
« Reply #6 on: September 23, 2015, 09:03:59 AM »
I would not recommend either of these for this application.
WD40 displaces water and may help a little with cleaning so probably won't hurt any of the metal portions of the connector but otherwise it's possible long term effects on the plastic aren't worth the risk.
Nail polish remover will also pose a definite risk for the plastic portions of the connector.
