Author Topic: Godin style Spring loaded Momentary toggle Switch replacement for S1/S2  (Read 8983 times)
Offline highlandsrock
I actually like the two individual push buttons that come with the GT3 internal kit in preference to the single toggle switch. I don't know if it's just my imagination but they seem to generate less signal noise than the toggle switch on my Godin Freeway SA. I suppose it could be down to the piezo picking up the actual click of the switch.
I've been thinking about replacing the Godin switch with push buttons. Does anyone know of a source for swiches that match the Roland supplied items (preferably in the UK or Europe)?
Godin Freeway SA, Ibanez RG870 and PRS SE Custom 24 both with GT3 internal kits, Ibanez 2402DX
GR-33, GR-55, GP-10, US-20, FC-300, KC350 x 2
Offline Elantric
In the UK,  R.S. Components sell what you need
Here's one version fits in a 12mm hole
Switch,p/btn,IP67,black button,off-mom
http://uk.rs-online.com/web/p/push-button-switches/7023599/
« Last Edit: June 11, 2012, 03:08:02 PM by Elantric »
Offline trev27
on the mini switch i take it the centre is the earth connection!
Takamine EG 530 electro Acoustic
Ibanez RG2610
Ibanez RG1570
Aria PE DLX
Offline Elantric
Correct  =  Electrical Ground
Offline trev27
cheers, got one, installed and works fine
Ibanez RG2610
Ibanez RG1570
Aria PE DLX
Offline merman93
A question for the electronically knowledgable,....
Regarding a momentary mini toggle switch, what is the difference in (off)-on-(off), and on-(off)-on?
I'm looking to purchase a replacement switch ,(S1/S2 combo), for one of my ibanez guitars with the factory gk2a install.
Roland comments on this option in the gk kit manual, and specifies off/on/off.
All the switches I've been directed to are on/off/on, and I've been told that will work fine, but a lot of Roland stuff is finicky.
« Last Edit: March 24, 2016, 06:23:58 PM by Elantric »
Ibanez RG 1520 GK
Ibanez RG 420 GK
Ibanez RG 920 (GK KIT)
Ibanez RGA 121 (GK 3)
Roland GC 1/G 505/G 707
Hamer Phantom A7 (24 pin)
BX 13 (24 -13 pin converter)
GP-10
FishmanTripleplay (2)
VG 88 2.0
Apple Imac/Logic 9
MOTU Utralite 3
Kemper (2)
Gemini 2 Active FRFR
Offline gumbo
  • Senior Member
  • Total likes: 192
  • Rating: 27
  • Changing the 13-pin interface - one Jack at a time
The 'standard' S1 & S2 press buttons are used as "Momentary On"...regardless of what the Roland publication says (& to be fair, I never picked up on this even after having owned a copy of that piece of paper for YEARS!)...so what you need is :
(Momentary) ON - OFF - (Momentary) ON
...otherwise you will not make it work.... ;)
HTH
Peter
Online admsustainiac
Read the 1st post in this thread for links to the type of momentary switch you need
Look for (on)-off-(on) switch the parentheses indicate momentary action.
« Last Edit: March 24, 2016, 06:24:32 PM by Elantric »
Offline merman93
No wonder I couldn't find anything in the mouser or digikey catelogs!!! Thanks.
Ibanez RG 1520 GK
Ibanez RG 420 GK
GP-10
VG 88 2.0
Apple Imac/Logic 9
MOTU Utralite 3
Kemper (2)
Offline Elantric
Offline dead3t3rn1ty
Re: Godin style Spring loaded Momentary toggle Switch replacement for S1/S2
« Reply #36 on: March 06, 2017, 11:26:18 AM »
From RS online for those based in EU:
http://uk.rs-online.com/web/p/toggle-switches/7347148/
Edit: installed this one on my guitar, shaft is exactly the same lenght and size as the other switch that comes with the GK3-kit
« Last Edit: March 13, 2017, 03:48:49 AM by dead3t3rn1ty »
