GR-55 - U2 With or Without you
Started by Sakke, October 08, 2011, 12:40:26 PM
Sakke
Can someone make patch to U2 With or witouth you, to roland gr 55. please.
Jeremy Hall
Hi Sakke,
Here's my attempt at the main guitar sound in WOWY.
If I get time I would like to make it a two-in-one patch with the initial guitar sound as well (the high pitched one with slow attack at the start of the track). I thought there was a "swell" effect (like a reverse or auto-volume effect) on the GR-55 but I cannot find one other than for synth tones (can any GR-55 experts please advise?).  Anyway, I suspect Edge is using a Fernandez sustainer pickup or something similar for this sound (I can get pretty close with my Sustainer equipped Burny Les Paul).
Enjoy,
Jez
Sakke
Thanks, this is very good patch  :)
thisisjust9
I have installed and tried this patch (* with or without.g5l) in my GR 55. Weirdly, it comes out with synth-brass sound, not guitar? any explanation of this? any one? thank you.
This is what I see when opened:
Mon Oct 2 07:55:16 2023
ROLAND GR-55 Complete Patch Summary
a list of all parameters with-in this patch.
Patch name = With or without
Patch Mode = Guitar
Structure Type = [2]
Pre Amp***********
[PreAmp Sw] = On
[Type] = Tweed
[Gain] = 53
[Level] = 63
[Gain Sw] = Middle
[Solo Sw] = Off
[Solo Level] = 50
[Bass] = 50
[Middle] = 50
[Treble] = 50
[Presence] = 0
[Bright Sw] = Off
[Speaker Type] = ORIGINAL
[Mic Type] = DYN421
[Mic Dis.] = On Mic
[Mic Pos.] = 5 cm
[Mic Level] = 100
Noise Suppressor***********
[NS Switch] = On
[NS Threshold] = 40
[NS Release] = 30
Delay***********
[Delay Switch] = On
[Delay Type] = Single
[Delay Time] = 1
[Delay FeedBack] = 9
[Delay Level] = 82
Reverb***********
[Reverb Switch] = On
[Reverb Type] = Plate
[Reverb Time] = 3.5s
[Reverb High Cut] = 4.0k
[Reverb Level] = 59
Equalizer***********
[EQ: Switch] = On
[EQ: Lo Cut] = 340Hz
[EQ: Low Gain] = 5 dB
[EQ: Lo Mid Freq] = 400Hz
[EQ: Lo Mid Q] = 0.5
[EQ: Low Mid Gain] = -9dB
[EQ: Hi Mid Freq] = 400Hz
[EQ: Hi Mid Q] = 0.5
[EQ: Hi Mid Gain] = 8dB
[EQ: High Cut] = FLAT
[EQ: High Gain] = 11dB
[EQ: Level] = 0dB
[EQ: Character] = -3
PCM Synth A***********
[Synth Tone] = 884 Ride Cymbal
[Tone Sw] = Off
[Tone Level] = 35
[Octave] = 0
[Chromatic] = On
[Legato] = Off
[Nuance Sw] = On
[Pan] = center
[Pitch Shift] = 0
[Pitch Fine] = 0
[Portamento Switch] = Tone
[Portamento Time] = 1
[TVA Release Mode] = 1
[String level [H] String 1] = 80
[String level String 2] = 80
[String level String 3] = 90
[String level String 4] = 90
[String level String 5] = 100
[String level String 6 [L]] = 100
[Line Route] = MFX
[Filter Filter Type] = Tone
PCM Synth B***********
[Synth Tone] = 212 AcousticBs 3
[Tone Sw] = Off
[Tone Level] = 45
[Octave] = 0
[Chromatic] = Off
[Legato] = Off
[Nuance Sw] = On
[Pan] = center
[Pitch Shift] = 0
[Pitch Fine] = 0
[String level [H] String 1] = 0
[String level String 2] = 0
[String level String 3] = 0
[String level String 4] = 60
[Line Route] = ByPass
Guitar Mode Modeling***********
[Tone Tone Level] = 100
[Tone Tone Sw] = On
[String Level [H] String 1] = 100
[String Level String 2] = 100
[String Level String 3] = 100
[String Level String 4] = 100
[String Level String 5] = 100
[String Level String 6 [L]] = 100
[NS On/Off] = On
[NS Threshold] = 15
[NS Release] = 20
[Guitar Mode Category] = Electric Guitar
[Guitar Mode E.Guitar] = E.Guitar-Telecaster
[03-04-05-07 PU select] = R + F
[01-02 PU select] = Rear
[06 PU select] = Rear
[01-02-03-04-05 Volume] = 100
[01-02 Tone] = 100
[steel PU select] = MA-28
[steel Body] = 80
[steel Tone] = 0
[Nylon Body] = 50
[Nylon Attack] = 50
[Nylon Tone] = 0
MOD***********
[Effect] = Off
[MOD: Type] = Octave
[Pan] = center
MFX***********
[Switch Effect] = Off
[MFX: Type] = Hexa-Chorus
[Pan Pan] = center
[Hexa-Chorus PreDelay] = 4.0 ms
[Hexa-Chorus Rate Type] = Time
[Hexa-Chorus Time Rate] = 40
[Hexa-Chorus BPM Rate] = whole note
[Hexa-Chorus Depth] = 50
[Hexa-Chorus PreDly Dev] = 0.0 ms
[Hexa-Chorus Depth Dev] = 5
[Hexa-Chorus Pan Dev] = 20
[Hexa-Chorus Balance] = 50W
[Hexa-Chorus Level] = 100
Master***********
[GK SELECT GK Set Select] = System
[GUITAR OUT Guitar Out] = Normal PU
[EXP EXP] = Bright
[EXP ON EXP ON] = Play Speed
[GK VOL GK VOL] = OFF
[STRUCTURE Structure] = Structure 2
[Line Route] = Amp/MOD
[PATCH LEVEL Level] = 11
[Tone Sw] = Off
[Tone Level] = 50
[Switch for ALT Tuning] = Off
[ALT TUNING Type] = -2 Step
[User Shift H [H] String 1] = 0
[User Shift 1 String 2] = 0
[User Shift 2 String 3] = 0
[User Shift 3 String 4] = 0
[User Shift 4 String 5] = 0
[User Shift L String 6 [L]] = 0
[PATCH TEMPO Tempo] = 7
[PATCH TEMPO Tempo] = 8
[Chorus ByPass] = 100
[Delay ByPass] = 100
[Reverb ByPass] = 20
[EXP PEDAL Modulation MIN] = 0
[EXP PEDAL Modulation MAX] = 100
[EXP PEDAL ON Modulation MIN] = 0
[EXP PEDAL ON Modulation MAX] = 100
[GK VOLUME Modulation MIN] = 0
[GK VOLUME Modulation MAX] = 100
