Expression pedal (volume) at the beginning of the effect chain
Started by ILIADE, March 12, 2024, 01:00:18 PM
ILIADE
Hi there,
Is there a way to change the location of the expression pedal in the effect chain? As it is right now, the exp pedal (volume in my case) seem to be at the end of the chain. As a result, when the pedal is up, 100% of the sound is cut. What I would like is a way to have the volume pedal at the beginning so when the pedal is up, the string sound is off but the remaining of the effects are still on (like reverb, delay, etc).
This is something I can do with my SY-1000 but cannot figure out how to do it with the GM-800...
Thanks,
Chris
I use it to control "Part Level" which is the tone source before the effects, which allows effect trails to continue on.
Go into the ASSIGNS section and make an Assign for each part you want controlled, you can also setup each tone part to be controlled at a different rate/ratio.
