Using different Note Sources in scenes
Started by bobruz, March 11, 2024, 10:46:41 AM
bobruz
I use the GM-800 as a guitar synth and as a sound source for a MIDI controller keyboard(A33).  Seems I need to manually set the Note Source in the MIDI setup when I need to do this.  Pg. 18 in the reference manual under MIDI setting.
Is it possible, or is there a way to have this source definition built into the scene? So when selecting one scene it is using the GK as the source.  When selecting another scene, it would use MIDI as the source.
I have not found it can be done yet.  Anyone doing this or similar?
Regards,
bobruz
gumtownadmin
Unfortunately not, the note source options can only be set in the system menu.
It would be great if this option had choice of system or patch.
