GR-55 - PCM tones are staccatto
Started by wsleight, March 03, 2024, 03:42:25 AM
wsleight
Hello everyone, I am a newbie and this is probably the wrong place to ask this question, but I was not able to search out and answer.  When I use a PCM tone for most of the guitar synths, it sounds very staccato to me.  I am wondering if there is a way to smooth out the transient perhaps by adding a compressor and reducing the attack? Just a guess as I said I am an older guy and new to this kind of tech.
Bill
Your question implies your are experiencing  speaker flub / uncomfortable  anomalies  with GR-55 tones.
What is your amplification system?
A normal guitar amplifier is typically the wrong tool.
A full range powered PA cab is the common type used by keyboard players - which essentially is sane type tones as GR-55 PCM Synths
Most of the popular amplification  options are explained here
https://www.vguitarforums.com/smf/index.php?board=37.0
Be sure you are using Gumtown  GR-55 FX Floorboard  Editor ( essential!). In fact most here never touch the Roland GR-55 Librarian
https://www.vguitarforums.com/smf/index.php?topic=2951.0
And review its included GR-55 patches - which were obtained from the source, VGuitarforums Users , cultivated for past decade here
https://www.vguitarforums.com/smf/index.php?board=67.0
Start by using headphones to judge the GR-55 Sounds
Then determine what suitable GR-55 amplifition type suits your budget or review the available types at your live performance venue
Many here just carry a used Cube 80XL amp, or a powered PA cab to the gig, or just use the house PA , stage PA Monitors and soundman
GR-55 FAQ
https://www.vguitarforums.com/smf/index.php?topic=3137.0
wsleight
Hi
Thanks for the quick reply, I am using a Fishman Loudbox Artist for and amplifier live.  I do have Floorboard set up, but I don't take my computer to live performances, I am very small time.  I will try headphones to see if I get the same stacatto and look over the presets to see what is there.
A few have inserted a dynamic compressor between GR-55 Output and their amplifier.
Numerous options!
Its all about the users knowledge of using Compressors- but FMR RNC is a good one https://www.amazon.com/FMR-RNC-1773-Compressor-Unit/dp/B0006I935Y/ref=asc_df_B0006I935Y/
And if you need stereo or mono ?
Carl Martin, MXR Bass Compressor, are popular
Another option is a gently used Yamaha MG-10XU mixer, and use its built in Compressor channels , and have options for adding more instruments and USB Class Compliant USB  Audio for recording to any computer system
One reason I still enjoy my Roland Cube 80XL  its loud and smooth , oweing to its closed back 12" extended range speaker and 80 watt " tube like"  Class AB power amp - feed the rear Aux Input bypasses the preamp, and yeilds a great reproduction of the intended GR-55 tones
wsleight
Thank you so much for this helpful reply I will dig into you materials you suggest.  I Have a Zoom Live Trak 8 for my mixer so maybe there is something I can do there as well.  Bill
In the GR-55 PCM tone "Filter" page,
adjust the TVA "Attack" setting up to increase the ramp up time for the start of the note.
adjust the TVA "Release" setting up to increase the time it takes for the note to finish after you have stopped picking/strumming.
plexified
PCM  Tone Velocity curve type  range 1-7  has different attack and decay curves displayed on page 25 :
https://static.roland.com/assets/media/pdf/GR-55_OM.pdf
The effect varies with each PCM #
All the PCM controls are on pages 25 - 27 for reference.
