GX 100 .... Looking For Previous Firmware's 1.10 -or- 1.11 -or- 1.12 ?
Started by benifin, February 25, 2024, 10:08:52 PM
benifin
Hi all !
Anyone have (?)  or know where I can download  GX 100  FW's   1.10  or  1.11  or  1.12  (?)
Am trying to isolate / bug-identify  if the "dull IR issue"  was present from Day 1  -or-  as the "fixed"  1.01 IR Loader was released in May 2022 ..... was the "fixed IR Loader"  re-broken with FW's  1.13 (?)
Thanks,
Ben
benifin
Oh well.  No Luck
Tried 1.10, 1.11, 1.12 and  [again] 1.13 .... each of them with IR Loader 1.01.
Did a full factory system reset for each and reloaded a known working test IR fresh for each FW.
Same dull-muffled-IR-tone  on all the different FW's using the supposedly  "fixed"  1.01 IR Loader.
Its impossible to think that Boss dont know about this issue.
Maybe (?)  the next FW update will fix it (?)
Ben
benifin
Right here
gx100_ir_w100.zip
https://static.roland.com/assets/media/zip/gx100_ir_w100.zip
What I do is search up the current file download page, right click on the download button and select "inspect", which in Chrome, brings up the site code displaying the download file address.
Copy that into a new browser window and change the file title to what you expect might have been an earlier version.
Can be a bit hit & miss sometimes.
benifin
Quote from: gumtown on February 27, 2024, 07:39:39 PMRight here
gx100_ir_w100.zip
Huge thanks !!!!
Didn't fix the problem though :(
Time for Boss to step up and fix this issue !
Ben
Quote from: benifin on February 28, 2024, 08:58:17 PMHuge thanks !!!!
Ben
Be sure to let them know through the "Roland Backstage" site where you register your GX-100 serial, then you can easily send complaints on faulty equipment.
