DIY GK 13 Y SPLITTER CABLE
Started by Elantric, February 06, 2024, 01:58:27 PM
IMPORTANT - CONNECT THE CABLE SHIELDS TO THE LARGE CIRCULAR DIN SHELL AT EACH CONNECTION
Verify on B Output ,
* Insert Diodes on S1, S2 switch connections  on Pins 10, 11
* Do not connect DC Power pins 12, 13
Verified same circuit as
Roland GK-P2 Y cable
https://www.roland.com/ca/products/gkp-2/
Allows one GK 13 guitar to drive two separate GK 13 processors
Gumtowns version
Here is my DIY GK splitter, you could get a regular GK 13 cable and cut it in half, then fit a GK socket into a small box and solder wires.
Looks a bit rough inside, but it works great !
Nobulusprime
Quote from: Elantric on February 07, 2024, 01:48:50 PMGumtowns version
I basic question - Ss there any way of differentiating between the colours e.g. multiple yellow and red with numbering on the pins ? Are the cores of regular GK leads usually numbered?
Use a multimeter to test each end for 0 ohm  continuity on each wire
Nobulusprime
Of course, continuity makes sense anyways.
