SY 1K Patches tuned at different hertz than 440
Started by RSKruse, February 05, 2024, 05:26:44 PM
RSKruse
Hello all. I am hard pressed to make a patch with (approx) 432 hz instead of 440 without significant artifacts.
Wanting to do "Sailing Nights" By Bob Seger and thats the tuning.
I realize we cant do exactly 432 but I would like to come as close as possible.
If someone in here knows of prexisting patches I could work with or if someone wants to make a few bucks off this noob, let me know.
admin_shawnb
Are you trying to use the midi out?  Alt tunings?
If not, just tune your guitar to 432.
admin_shawnb
I don't do a lot of alt tunings, so I don't have a patch...
But...  If you want to attempt this via alt-tuning, I do know that the SY-1000 fine tuning is in "cents", i.e., 1/100th of a semitone.
From the manual, p24: "Finely adjusts the pitch of each string. -50 is half a semitone down;  50 is half a semitone up."  I.e., 100 goes a full semitone, which is pretty standard.
If you do the math, it just kinda works out that for each Hz off of A440 you use a fine tuning parameter of +/- 4.
So...  In the SY-1000, for a guitar instrument, on the alt tuning tab, change the TUNING TYPE to USER, and change all of the Fine 1-6 values to -32.  Leave the pitch values at 0, as you're not moving more than a semitone.
The guitar models on the SY-1000 have some clicks when you do alt tunings; this has been discussed elsewhere.  You may need to try to bury the artifacts under some overdrive.
The 432 question has come up earlier, cents calculations may be found here:
Quote from: shawnb on September 03, 2016, 10:15:34 AMBottom line:  4 clicks per Hz...
I'm pretty sure this is it:
Tune                  MIDI Fine-tune RPN
Base    Freq                CC#6    CC#38
-100    415.3046976    0    0        (Ab when A=440)
-99    415.5446563    0    96
-98    415.7847536    1    32
-97    416.0249897    2    0
-96    416.2653646    2    64
-95    416.5058783    3    32
-94    416.746531    3    96
-93    416.9873228    4    64
-92    417.2282537    5    0
-91    417.4693238    5    96
-90    417.7105332    6    64
-89    417.951882    7    0
-88    418.1933702    7    96
-87    418.4349979    8    32
-86    418.6767653    9    0
-85    418.9186723    9    64
-84    419.1607191    10    32
-83    419.4029058    11    0
-82    419.6452324    11    64
-81    419.887699    12    32
-80    420.1303057    12    96
-79    420.3730526    13    64
-78    420.6159397    14    0
-77    420.8589672    14    96
-76    421.1021351    15    32
-75    421.3454435    16    0
-74    421.5888925    16    96
-73    421.8324821    17    32
-72    422.0762125    18    0
-71    422.3200837    18    64
-70    422.5640958    19    32
-69    422.8082489    19    96
-68    423.0525431    20    64
-67    423.2969784    21    0
-66    423.541555    21    96
-65    423.7862728    22    64
-64    424.0311321    23    0
-63    424.2761328    23    96
-62    424.5212751    24    32
-61    424.7665591    25    0
-60    425.0119847    25    64
-59    425.2575522    26    32
-58    425.5032615    27    0
-57    425.7491129    27    64
-56    425.9951062    28    32
-55    426.2412417    28    96
-54    426.4875195    29    64
-53    426.7339395    30    0
-52    426.9805019    30    96
-51    427.2272067    31    32
-50    427.4740541    32    0
-49    427.7210441    32    96
-48    427.9681769    33    32
-47    428.2154524    34    0
-46    428.4628708    34    64
-45    428.7104321    35    32
-44    428.9581365    35    96
-43    429.205984    36    64
-42    429.4539747    37    0
-41    429.7021087    37    96
-40    429.9503861    38    64
-39    430.1988069    39    0
-38    430.4473713    39    96
-37    430.6960793    40    32
-36    430.9449309    41    0
-35    431.1939264    41    64
-34    431.4430657    42    32
-33    431.692349    43    0
-32    431.9417763    43    64        A=432
-31    432.1913477    44    32
-30    432.4410634    44    96
-29    432.6909233    45    64
-28    432.9409275    46    0
-27    433.1910763    46    96
-26    433.4413695    47    32
-25    433.6918074    48    0
-24    433.94239    48    96
-23    434.1931173    49    32
-22    434.4439896    50    0
-21    434.6950067    50    64
-20    434.946169    51    32
-19    435.1974763    51    96
-18    435.4489288    52    64
-17    435.7005266    53    0
-16    435.9522698    53    96
-15    436.2041585    54    64
-14    436.4561927    55    0
-13    436.7083725    55    96
-12    436.960698    56    32
-11    437.2131693    57    0
-10    437.4657865    57    64
-9    437.7185496    58    32
-8    437.9714588    59    0
-7    438.2245141    59    64
-6    438.4777156    60    32
-5    438.7310635    60    96
-4    438.9845577    61    64
-3    439.2381983    62    0
-2    439.4919856    62    96
-1    439.7459194    63    32
0    440                    64    0        A
1    440.2542274    64    96
2    440.5086017    65    32
3    440.7631229    66    0
4    441.0177912    66    64
5    441.2726067    67    32
6    441.5275693    67    96
7    441.7826793    68    64
8    442.0379367    69    0        A=442
9    442.2933416    69    96
10    442.5488941    70    64
11    442.8045942    71    0
12    443.060442    71    96
13    443.3164377    72    32
14    443.5725813    73    0
15    443.8288729    73    64
16    444.0853125    74    32
17    444.3419004    75    0
18    444.5986365    75    64
19    444.8555209    76    32
20    445.1125537    76    96
21    445.3697351    77    64
22    445.6270651    78    0
23    445.8845437    78    96
24    446.1421711    79    32
25    446.3999474    80    0
26    446.6578726    80    96
27    446.9159468    81    32
28    447.1741702    82    0
29    447.4325427    82    64
30    447.6910645    83    32
31    447.9497357    83    96
32    448.2085564    84    64
33    448.4675266    85    0
34    448.7266464    85    96
35    448.985916    86    64
36    449.2453353    87    0
37    449.5049046    87    96
38    449.7646238    88    32
39    450.024493    89    0
40    450.2845125    89    64
41    450.5446821    90    32
42    450.8050021    91    0
43    451.0654725    91    64
44    451.3260934    92    32
45    451.5868649    92    96
46    451.8477871    93    64
47    452.10886    94    0
48    452.3700837    94    96
49    452.6314584    95    32
50    452.8929841    96    0
51    453.1546609    96    96
52    453.4164889    97    32
53    453.6784682    98    0
54    453.9405989    98    64
55    454.202881    99    32
56    454.4653147    99    96
57    454.7279    100    64
58    454.990637    101    0
59    455.2535258    101    96
60    455.5165665    102    64
61    455.7797592    103    0
62    456.0431039    103    96
63    456.3066009    104    32
64    456.57025    105    0
65    456.8340515    105    64
66    457.0980055    106    32
67    457.3621119    107    0
68    457.6263709    107    64
69    457.8907826    108    32
70    458.1553471    108    96
71    458.4200645    109    64
72    458.6849348    110    0
73    458.9499581    110    96
74    459.2151346    111    32
75    459.4804643    112    0
76    459.7459473    112    96
77    460.0115836    113    32
78    460.2773735    114    0
79    460.5433169    114    64
80    460.809414    115    32
81    461.0756649    115    96
82    461.3420696    116    64
83    461.6086282    117    0
84    461.8753408    117    96
85    462.1422075    118    64
86    462.4092284    119    0
87    462.6764036    119    96
88    462.9437332    120    32
89    463.2112172    121    0
90    463.4788558    121    64
91    463.746649    122    32
92    464.014597    123    0
93    464.2826998    123    64
94    464.5509574    124    32
95    464.8193701    124    96
96    465.0879378    125    64
97    465.3566608    126    0
98    465.625539    126    96
99    465.8945725    127    32
100    466.1637615    128    0        (A# when A=440)
Oh boy 432 - I find it sounds really sour but some people believe the stories and want to try it.  It worked well with the VG-99 (I did two improvs, one with a 440 and one with a 432), I see no reason why the SY-1000 wouldn't be able to do it - how are you trying to do it (ALT TUNE?) and what type of sound are you going for (distorted guitar or synth sounds or guitar to midi?).
RSKruse
Thanks Shaun and Alien. Just want a couple of different gk3 friendly patches for sake of covering that particular song. This info  will do me.
