Dual Delay Expression Control
Started by Tone Jones, January 17, 2024, 05:53:49 PM
Tone Jones
I have some patches that utilize a dual delay (Delay 1 + Delay 2). Is it possible to assign the effect level of BOTH delays to a single expression pedal?
In theory, you should be able to.
In tone studio, the ASSIGN tab on the far right near and under the Contour knob,
select the Katana EXP page, and select the Delay/Delay2 option and set it to effect level.
Tone Jones
Quote from: gumtown on January 17, 2024, 06:28:15 PMIn theory, you should be able to.
Thanks for your reply. I tried that before my initial post. The problem I'm running into is it appears you have to assign the expression pedal under the "function" drop down menu that only allows you to select Delay 1 OR Delay 2, not both. Am I missing something?
Tone Jones
