5th string not working with VG-8ex
Started by stingfan24, January 13, 2024, 05:52:24 PM
stingfan24
Hello,
Need a little troubleshooting help please. Got a VG-8EX and a Roland ready Fender. No matter the setting, the 5th string doesn't register. I pluck it and...nothing. It's not the guitar, because when I plug it straight into am amp, the 5th string sounds just fine. If anyone has any ideas, I'd be mighty grateful.
gumtownadmin
It could either be:
1: guitar, as the GK ready pickup is separate from the normal guitar out jack.
2: the GK 13 pin cable is usually the most common failure, try spraying the pins with "deOxit" contact cleaner  and repeatedly plug in/out both ends with the guitar and VG-88.
3: the VG-88 being the least likely failure, except as mentioned about cleaning the GK socket pins.
Another test is to try another 13-pin guitar in the VG-8EX....and your existing R-R into another 13-pin device....that usually is the quickest way to diagnose which item is at fault.
Fixing whichever item is found to BE at fault is then a matter of further investigation.
HTH
Peter
stingfan24
Thank you both! Will try what you suggested!
stingfan24
Thank you both again! The cable was the culprit.
Perhaps also have a read here:
https://www.vguitarforums.com/smf/index.php?topic=18487.0
...some worthwhile information about cable maintenance and protection.
Cheers,
Peter
stingfan24
Much appreciated, Peter!
Cheers,
- Gordan
