Katana 50MKII EX - no Sound in "Clean" and "Lead" when "Variation" is on...
Started by Faolan, January 12, 2024, 11:29:01 AM
Faolan
Hello,
my new Katana 50MKII EX has no sound when on "clean" and "Lead" when
- Variation = ON
- Gain, Volume is on 100 (full), Master start with 0 (up to 100 there is on mine)
- Bass, Middle and Treble is on "0"
- Effects are "off"
- Power Control is 25W and also 50W
3 different Guitars
Factory Reset is done (2x)
is this "normal"?
Thank you!
Contact dealer where purchased first.
And  Roland Backstage and locate a local service center
Should be a  free warranty  repair.
https://www.roland.com/backstage/
Faolan
I bought it on amaz* warehouse... if defunct -> return (not repair)...
Contact Amazon and return
does it have sound in the other amp model selections ? (Brown, Crunch, acoustic)
Faolan
Yes, all other does have sound.just got it from amazon whd, unpacking, testing and here we are.
Kind of "odd" behavior, and it will be most likely in the firmware,
 so if the factory reset didn't resolve it,
 then the only option is to return it for exchange or refund.
Quote from: Faolan on January 12, 2024, 08:54:07 PMYes, all other does have sound.just got it from amazon whd, unpacking, testing and here we are.
Realize "Amazon Warehouse" items are used customer returns, and Amazon has zero qualifications to fully test returned merchandize
Often there is high risk of recieving a defective product ordering the "Amazon Warehouse" , at the reduced price .
Faolan
Maybe one of the Katana 50/100 MKII (EX) users out there can reproduce this for me before I send it back
Power Control: start with 0,5W!
- All settings to 0
- Gain + Volume: 100 and Master start with 0 (up to 10 should be enought). Up to 100 I hear no sound.
- Amp Type: clear + Variation: ON bzw. Lead + Vari: ON
= No Sound
Thank you!
I have a Katana 50 Mk2 and it works as it should on a amp models with/with-out Variation.
All channels and Panel work the same.
Quote from: gumtown on January 13, 2024, 09:21:48 PMI have a Katana 50 Mk2 and it works as it should on a amp models with/with-out Variation.
Hes got the different new "EX" version that accepts GAFC footswitch
https://www.boss.info/global/products/katana-50_mk2_ex/
Faolan
Answer from Roland Support:
"...we have checked this with several KATANA-50EX and here it actually behaves like your model. It is clearly a firmware problem and not a defect. We will forward this accordingly for review..."
Quote from: Faolan on January 16, 2024, 07:19:53 AMAnswer from Roland Support:
So what they are saying is all 50-EX models have this problem ?
Quote from: gumtown on January 16, 2024, 10:10:10 AMSo what they are saying is all 50-EX models have this problem ?
Yes
 - I predict Katana Firmware 2.01 arrives soon
