Another rehousing question..this time for the SY 1000 and GT-10
Started by luca9583, January 02, 2024, 05:44:57 AM
luca9583
Hi all
I've seen some cool rehousing projects/mods of the Behringer FCB 1010 and was looking at the boards of both the SY 1000 and GT-10.
Do you think these could be rehoused but with much smaller buttons for the preset selectors/pedal sections or with no pedals at all and an expression input instead?
I'd like to make these "brain" only to reduce the size considerably, but to make sure they function properly i'm thinking all preset buttons would still need to be connected.
Also, would anyone here on the forum in the UK be intereted in doing the mods?
Mods..feel free to move this post to another section if needed.
Most of these units will require the switch button board to be connected as part of a hardware startup check.
So you are also still confined to the size of those circuit boards,
 although extra smaller foot switches can be 'bootstrapped' off the existing ones on the boards,
 but you also have the pedal LEDS on these boards too.
luca9583
Quote from: gumtown on January 02, 2024, 01:46:17 PMMost of these units will require the switch button board to be connected as part of a hardware startup check.
Ah ok yeah that's a shame. Much appreciated.
I wish Boss/Roland could come up with a modular 13 pin system at some point, or even just an "SY-1000 core" like they did for the GT 1000.
stub
I can understand wanting it to be more compact, but I have to wonder about things like heat, and ease of repair, etc.
luca9583
luca9583
Quote from: stub on January 02, 2024, 07:45:53 PMI can understand wanting it to be more compact, but I have to wonder about things like heat, and ease of repair, etc.
Yeah for sure.
fokof
luca9583
Quote from: fokof on January 03, 2024, 07:08:44 AMYou could rack it with some drawers .... ??
Sure but i want it all on a pedalboard. So having these devices as brains only would be ideal.
I have to resize them they are to big a file , I'll try and get them in the morning
LinzHenderson
SY-1000 is very straightforward to re-house as a 'brain'. I've done it for my main rig. No footswitch PCB required for it to run properly. I've 3D printed a rough enclosure. It's mounted in an old radio shell along with a Mac Mini, monitor and audio interface.
I use a custom MIDI controller routed through the Mac for everything and run Gig Performer and Ableton Live, but it could be just the SY and controller via 5-pin.
luca9583
Quote from: LinzHenderson on January 03, 2024, 08:14:10 PMSY-1000 is very straightforward to re-house as a 'brain'. I've done it for my main rig. No footswitch PCB required for it to run properly. I've 3D printed a rough enclosure. It's mounted in an old radio shell along with a Mac Mini, monitor and audio interface.
Oh wow. Can we see some pics?
LinzHenderson
#12
Quote from: luca9583 on January 03, 2024, 08:33:14 PMOh wow. Can we see some pics?
The 3D printed enclosure is pretty rough because it's too big to print in one piece on my printer. It was supposed to be temporary, but it's actually holding up just fine, so I'll keep it like this for now.
luca9583
Quote from: LinzHenderson on January 04, 2024, 05:04:55 AM
Incredible work.
pasha811
Amazing!
jongrant
kevorkian
eldenkellymusic
Quote from: whippinpost91850 on January 02, 2024, 07:26:28 PM1 did this with my GR55
Hey there, Interested in your GR55 Rehouse. Do you have any info on it you can share? Thanks!
eldenkellymusic
