Boss GT-100 - manual/stompbox mode
Started by Alfons, December 15, 2023, 10:00:17 AM
Alfons
I can't find a good description of how to configure the eight buttons (Bank Down, Bank Up, 1, 2, 3, 4, Phase Loop, Accel/Ctl) on the Boss GT-100-guitar processor in manual/stompbox mode so that the GT-100 becomes a pedal/stompbox board.
Mrchevy
Quote from: Alfons on December 15, 2023, 10:00:17 AMI can't find a good description of how to configure the eight buttons (Bank Down, Bank Up, 1, 2, 3, 4, Phase Loop, Accel/Ctl) on the Boss GT-100-guitar processor in manual/stompbox mode so that the GT-100 becomes a pedal/stompbox board.
Press bank up and bank down buttons together to switch to manual mode. Effects will come up on the 2 screens. They will align with the 8 knobs bellow them. Turning the knob under each position changes what that particular pedal effect will be. The pedal for that position turns it on and off. Changing an effect or its parameters itself is done in the patch mode. You set up your patch and effects chain first, then you go to manual mode to control your effects as you would regular pedals, using the knobs to select which effect is controlled by Bank Down, Bank Up, 1, 2, 3, 4, Phase Loop, Accel/Ctl
Gibson Les Paul Custom
Epi Les Paul Standard
Gibson SG 50's prototype
Squire classic vibe 60's
Epi LP Modern
Epi SG Custom
Martin acoustic
Princeton chorus 210
GT100
GR-55
Helix LT
Waza Air Headphones
Boomerang III
