Sy1000 midi question
Started by solo624, December 10, 2023, 07:34:10 AM
solo624
Hello Has anyone tried these types of mini midi keyboards to trigger piano sounds with the sy1000 ? If yes or know what happens , signal chain info or whats the problem . Thanks I know there inexpensive but does it work because I havent seen anything or posts thanks .
 Harvey
M-Audio Oxygen Pro Mini – 32 Key USB MIDI Keyboard Controller
midiplus AKM320 Midi Keyboard Controller
AKAI Professional MPK Mini MK3
Not possible , SY-1000 does not respond to MIDI NOTE ON/OFF
The SY-1000 does not have PCM sampled synth tones like 'piano', you are looking at the wrong product.
The GM-800 might be what you need, and yes, the GM-800 will play piano sounds from an external midi controller.
