Selecting VG-99 GK Settings via MIDI
Started by steadystate, December 09, 2023, 07:27:19 PM
steadystate
The title says it all.  Does anyone know of a way to select among the ten GK pickup settings in the VG-99 using external MIDI commands?  Even sysex would be useful.  Thanks.
The VG-99 will bulk dump just the GK settings. Controllers can be saved with a patch or work system wide depending on how it is set.
steadystate
Quote from: Brent Flash on December 09, 2023, 08:37:55 PMThe VG-99 will bulk dump just the GK settings. Controllers can be saved with a patch or work system wide depending on how it is set.
Being able to select it with an external command is what I'm looking to do.  I don't think it's possible.
It can be done through sysex messages. I can find out which ones if you are interested...
steadystate
#5
Quote from: sixeight on December 10, 2023, 04:07:14 AMIt can be done through sysex messages. I can find out which ones if you are interested...
Totally interested.  My foot controller can send sysex.
I've looked at the MIDI Implementation PDF (thanks Elantric).  I found the GK Settings Table, which looks like it allows individual control of each setting parameter.  I'm really looking for a message that will simply select one of the 10 presets.
I also see the GK SETTING section of the Address Block Map.  It shows the address used for individual parameter control in the other table, but not the data to select a preset as a whole.  Not sure if this will let me simply recall one of the 10 presets.
Hi, the format is:
F0, 41, 00, 00, 00, 1C, 12, 00, 00, 10, 02, 00, 6E, F7 for guitar 1
F0, 41, 00, 00, 00, 1C, 12, 00, 00, 10, 02, 01, 6D, F7 for guitar 2
F0, 41, 00, 00, 00, 1C, 12, 00, 00, 10, 02, 02, 6C, F7 for guitar 3
f0, 41, 00, 00, 00, 1c, 12, 00, 00, 10, 02, 03, 6b, f7 for guitar 4
etc.
All numbers are hexadecimal.
steadystate
Quote from: sixeight on December 10, 2023, 11:29:21 AMHi, the format is:
etc.
Thanks so much!  Using this, I easily worked backward and understood how this works.  It would have taken me forever otherwise.
