Newbie question re: Godin Multiac MIDI output
Started by goffredo, December 07, 2023, 11:14:21 AM
goffredo
Hello guys, first time post here.  I live in Switzerland and I fell in love with the nylon string Godin Multiac and Grand Concert at my local guitar store in Winterthur.  I've been reading a lot of information here but I must admit I'm a bit lost with the terminology and have never really worked with MIDI before.  I hope someone can gently help guide me.
I don't gig, I plan only to record and practice at home on a Mac (2023 Mac Mini M2 Pro). I am interested in using my guitar to simulate bass guitar, 12-string, piano / synth, and to record this into and arrange on my Mac.  I play on nylon strings and touch on classical, neoclassical thrash, flamenco style and gypsy.  Think Bach / Segovia, Yngwie, Jason Becker, Al DiMeola, Django Reinhardt.
I also don't have ANY gear right other than the Mac.  I'm starting fresh and need advice.
First is the guitar.  If I plan to do "midi stuff" as per above, when purchasing a Godin Multiac (or Grand Concert), is it advantageous for my plans to opt for a Godin Multiac that has the "SA" option -- that is, the 13-pin MIDI output that is integrated into the 6 independent 'hex' pickups on the guitar?  Or has MIDI technology advanced to the point where I can accomplish the same thing without needing the guitar itself to host the special MIDI pickups and output?
I ask because I must decide upon a Multiac with either the "SA" MIDI output option, --OR-- no MIDI output, but a fancy LR Baggs internal body pickup, which is great for percussive guitar work like string & body slaps, and which sounds really good when blended in with the string pickups using the guitar's built-in pickup blend slider.
Quote from: goffredo on December 07, 2023, 11:14:21 AMFirst is the guitar.  If I plan to do "midi stuff" as per above, when purchasing a Godin Multiac (or Grand Concert), is it advantageous for my plans to opt for a Godin Multiac that has the "SA" option -- that is, the 13-pin MIDI output that is integrated into the 6 independent 'hex' pickups on the guitar?  Or has MIDI technology advanced to the point where I can accomplish the same thing without needing the guitar itself to host the special MIDI pickups and output?
I really wish they (the powers that be that came up with 13 pin equipment) would never have used MIDI as a term associated with the divided pickup used today. The 13 pin output of divided pickups is not a Musical Instrument Digital Iinterface = MIDI. That being said the 13 pin equipment does open a vast range of things you can do with the right equipment once you plug it into them. I am sure more replies are coming to answer your specific questions.
 I have a Multiac and my advice is to get the hex SA + try a GP-10 for both modeling instruments and as a guitar to midi converter for softsynths etc
( imho one of the better gtm ) via usb.
You can record ( or play live ) both Audio and Midi with the GP-10 simultaneously , GP-10 works as soundcard.
The Godins with RCM hex piezo works best imho.
goffredo
Thanks for the input folks.
So in terms of the sound processing performed by a GP-10 pedal, how would a Godin Multiac with the "SA" option (built-in 13-pin output) compare to the exact same Godin guitar without the "SA" option (NO built-in 13-pin output) but, for example, with the aftermarket GP-3 pickup installed on it?
Or to put it more simply, is the 13-pin output from Godin's factory installed bridge pickups going to be much better than an aftermarket customer-installed GP-3 pickup, for sound processing through, for example, the GP-10?
My motivation in asking this is because I have to pick between the built-in 13-pin output ("SA" option) OR a nice Lyric body pickup ("Deluxe" option) but no built-in 13-pin output.
#5
Quote from: goffredo on December 09, 2023, 02:53:31 AMThanks for the input folks.
You said nylon strings in the thread start so I'm guessing that's the Q
A GK 3 PU is a magnetic PU so , not with regular nylon strings.
Nylon with steel core strings ( I believe these ones Thomastik KR 116 if my memory serves me right)
can however be an option but the sound of these strings are a bit different imho
So better try them first.
also the response from the PU can be uneven.
The Multiac with hex piezo works with regular nylon strings.
goffredo
Aha.  Thank you for showing me the rather obvious, now that I think about it, advantage of using the built-in bridge hex piezos in the Godin "SA" package.  With the add-on GP-3 pickup I'd be limited to using special steel-core nylon strings.
I'll probably still get the pickup option with the GP-10, so I can put the pickup on a steel-string guitar in the future.
I guess the next thing I need to figure out is what kind of software to get for my Mac to record and sequence.
Tosh
The Mac comes with Garage Band. It works very well, for a free application. Many Mac users are happy with Logic Pro X (myself included).
There is no limit to what you can acquire, but at what cost?
Nickertronix
This is pretty good studio software, and most importantly - free!
https://www.tracktion.com/products/waveform-free
Although GarageBand is a capable DAW, and you already have that in MacOS.
A second-hand Roland GI-10 would allow you to connect your 13-pin to the Mac via USB. They are a bit old now, but might be a cheap option.
