Boss GT-100 Patch Work
Started by slh2536, December 04, 2023, 04:11:56 PM
slh2536
I am currently working with a patch I prefer to use. I would like to use a harmonizer with the patch but it does not appear to be within the patch anywhere. I'm sure there's a way to add it to the patch but it's beyond me. Could someone advise me how to add this effect or how to add any effect to any patch. Thanks!
You will find the Harmonist effect resides in FX1 and FX2,
but if FX1 and FX2 effects are already in use, then hard luck, as only one effect at one time can be used from each FX section.
You can use an "ASSIGN" to swap out between effects in FX1 and FX2 with a CTL pedal.
