GK5 device roadmap?
Started by Best_Peasant, December 02, 2023, 12:56:54 PM
Best_Peasant
Does boss have a road map of future devices that will use gk5?
gumtownadmin
I am sure they do already have the next ten years already road mapped.
Also sure that all new GK modeling/synth units going foward will be GK Serial based, using the GK-5 and GK-5B, and maybe a GK-6 series with provision for future extra normal pickup input + GK vol, and more.
Best_Peasant
Fair answer, does that mean that other "Serial" devices will operate with each other depending on how they are ordered? For example if a GK5 version of the SY1000 was available and it was first in the chain, then a subsequent GM800 will work from the SY1000 generated sounds?
gumtownadmin
Quote from: Best_Peasant on December 08, 2023, 10:51:45 AMFair answer, does that mean that other "Serial" devices will operate with each other depending on how they are ordered? For example if a GK5 version of the SY1000 was available and it was first in the chain, then a subsequent GM800 will work from the SY1000 generated sounds?
No, the GK Serial is daisy chained at the device inputs, so any down stream processing units will have the inputs paralleled, and each device processes a clean signal separately.
