Amp eq setting question
Started by DrFaceFace, November 27, 2023, 06:14:23 PM
DrFaceFace
Just got Gt-100 and im new to using a preamp.
Wondering if theres an optimal way to set your actual amp eq knobs so that the gt preamps and eqs are coming through properly.
Like should i just turn all the amp knobs to 5 or something?
What do you guys do?
Start off with the preamp controls in the mid position and then adjust to your liking, then press the "write" button a couple of times (or is it 3 times) to save your settings changes.
Welcome to the group DrFaceFace!  :)
DrFaceFace
Quote from: gumtown on November 27, 2023, 06:42:45 PMStart off with the preamp controls in the mid position and then adjust to your liking, then press the "write" button a couple of times (or is it 3 times) to save your settings changes.
Sorry I meant on my physical amp. Should i set those all neutral so the preamps can work their magic?
