fcb1010 eurkaprom pedal push multiple times to change issue?
Started by drewnitro, November 12, 2023, 12:51:35 PM
drewnitro
Hello,
i just hooked up this to my gr55 and have most of it figured out as far as getting it to have 5 top preset sounds and 5 lower effects (cc) on off and what volume stuff.  my issue is that you have to double push the pedals to make the midi command send??  anyone know if this is a global setting i can change back to?
thanks in advance!
drew
DREWNITR :)
/\m/\        /\m/\
Current Gear:
Parker Fly MOJO Red/Trans
Gibson SG (Black Beauty)
Epiphone (Dave Rudd) Flying V
HeadRush Pedalboard W/Headrush FRFR112 Speaker
GR55/FCB1010 Eurekaprom/GK3 on Parker Fly Mojo W/FRFR112 Speaker
Practice: (We talkin practice?) Anygig Electric Guitar
Depends on the Assigns setup in the GR-55, If the FCB1010 sends cc# by toggling on/off each step, then the GR-55 Assign mode needs to be set as "Momentary" and not "toggle".
drewnitro
Quote from: gumtown on November 12, 2023, 08:17:21 PMDepends on the Assigns setup in the GR-55, If the FCB1010 sends cc# by toggling on/off each step, then the GR-55 Assign mode needs to be set as "Momentary" and not "toggle".
OK thank you for this as i will try this tonight after work!  I was using momentary for all stuff that needed changes in a range like volume and wah.  so i think what you are saying is on/off and momentary should change the effect on or off each time with one touch?  i read somewhere that the eurekaprom 3.2 has a 3 position toggle so i think that is what is was doing when i had to push more than 1 time but not sure as i cant find any really good instructions (mapping document) on the eureka.  i had to watch a bunch of 3 minute videos and get frustrated RRRRR....i still dont remember how i programmed the original presets to the top 5 pedals (oh well).  I dont have a midi usb interface so i have to do everything manual on he board.  thanks gumtown!!!
DREWNITR :)
/\m/\        /\m/\
Current Gear:
drewnitro
DREWNITR :)
/\m/\        /\m/\
Current Gear:
Awesome !!!
Now go forth and control that GR-55 beast !!  ;)
