Pitch Bend
Started by Best_Peasant, November 02, 2023, 07:20:57 AM
Best_Peasant
Was fooling around with getting an accurate(ish) sounding guitar string bend from one of the Guitar tones, I think Guitar LP SRX.
Am I correct in that I have to set the TONE to Mono and not Polyphonic to get a more accurate bending sound? Is there another setting I am overlooking for smooth string bends?
admin_shawnb
Yes, if you're doing bends you probably want to be on Mono.
The other thing to look into is to make sure your voice has Chromatic set to OFF.  ALL FOUR PARTS...
If your voice is in Poly, the bend is shared across all strings, which makes it impossible to do many guitar bend techniques.  In Mono, the bends are unique per string.
Best_Peasant
Quote from: admin_shawnb on November 02, 2023, 10:31:41 AMYes, if you're doing bends you probably want to be on Mono.
Perfect, worked a treat. Was staring me in the face. Thank you.
