Looper length?
Started by sine_3000, October 05, 2023, 02:57:25 PM
sine_3000
So Roland *finally* put a looper in one of their synth pedals! Two, actually - "DJFX" and "BPM".
But for the "length" parameter (for both loopers) it simply says, "Length 230–23 (not straight) - Specifies the length of the loop".
Not sure what that means! Seconds? Not likely. Milliseconds? Also not likely. Some other obscure measurement indicator? Anybody know?
sine_3000
Quote from: Elantric on October 05, 2023, 02:59:19 PMI understand its MIDI LOOPER
Ok, that makes sense. MIDI looper, not audio looper, OK.
It still results in a loop of sound, though, yes? If so, where to find more info about inputting and managing this?
Longer thought on this, I was thinking specifically about using some of the included drum kits to get drum loops going.
Actually I was thinking about having a loop start, then switching banks and playing over it, but I guess that won't be possible if it's only MIDI info, changing banks would lose the samples.
Still, I would like to put a drum set in the bank and loop some if it.
The Roland GR-55 guitar synth has a built in (simple) audio looper, which can do overdub.
Quote from: sine_3000 on October 05, 2023, 03:18:27 PMOk, that makes sense. MIDI looper, not audio looper, OK.
Currently GM-800 Parameter Guide states all available controls of BPM Looper and DJFX Looper
These Loopers appears to be borrowed from a Roland SP-404
https://articles.roland.com/sp-404-djfx-looper-and-how-to-use-it
BPM LOOPER
DJFX LOOPER
