PG SPARK CAB
Started by Elantric, October 05, 2023, 06:47:33 AM
Spark CAB features a 10-inch woofer and 2 high-frequency dome tweeters, powered by a built-in 140-Watt Class D amplifier. Get clear and accurate dynamic sound reproduction, with full range flat response (FRFR).
Sound solutions.
Spark CAB is packed with convenient, intelligently designed features, making your journey from setup to performance a breeze.
A dedicated 3.5mm stereo input connects Spark smart guitar amps (Spark 40/MINI/GO), cable included.
Stereo combo XLR/TRS inputs and a balanced XLR output are perfect for connecting to other gear.
Engage the contour switch to emphasize low and high frequencies for a better sound balance at low volume.
The ground lift switch reduces unwanted hum or noise.
$269 early bird
https://www.positivegrid.com/products/spark-cab
Power to power.
DC POWER | USB-C OUTPUT
Spark CAB is a power hub. With a DC power output and a USB-C output, you can connect your Spark (40, MINI or GO), tablet or phone. No other power source needed
