Graviton M1 wireless MIDI controller - guitar mounted
Started by shawnb, September 13, 2023, 11:13:23 AM
Took me a while to figure out the On/Off switch for X/Y and 10 button wireless floor switch
On/Off switch for remotes are not documented anywhere - then found both are factory paired , and they expect long battery life
No "OFF"Switch
10 button footswitch LED near USB charge port glows during recharge, goes out as only  indication when battery is fully charged
A bit annoyed neither remotes have off switches , nor battery level indication
So like Scheduled Laundry day, I schedule " Battery charge day"
I miss lack of an HTML Editor (Morningstar)
Luminite
#26
Quote from: Elantric on October 13, 2023, 10:23:35 AMNo "OFF"Switch
The battery percentage is the small green number in the top right corner of the Graviton M1 screen, indicates the charge level of the last XY controller / footswitch pedal activated  8) (everytime a XY Controller or F10W / F6W send a wireless signal to the M1, it report its battery level as well)
Both the XY Controllers and Wireless Footswitch Pedals have no ON / OFF switch, but an intelligent power management instead, which automatically turns them on when pressed and off when not in use. (I'll update the manual with this so it's clearer)
I designed them with this feature because I once had a gig where I forgot turning on my other Bluetooth footswitch on, until I need to change to the solo preset and nothing happened.
If there was an off switch on the XY controller, users might forget to turn it off before putting the guitar into its case, only realizing the battery ran out when the next gig begins. (This happened with my guitar wireless so many times!)" So it's one less point of failure and simplifies everyday usage.
The battery should last for months between charge, even if you gig everyday. I havent drained my F10W ever yet  8) .
Quote from: keitht on October 13, 2023, 05:08:28 AMI am loving my Graviton M1. It took a while to get here, I found a bug with the TRS1 as midi out (don't use it, TRS2 or TRS3 work fine), but overall it is amazingly powerful and easy to use. Still working on how I will really use it, but right now when trying different CC and PC tests, it is super fast and easy.
Quote from: BROCKSTAR on October 13, 2023, 08:09:23 AMSame. I've been using mine every day with gm-800. I check daily for updates on the graviton as well lol.
I've been busy with hardware, back to software now. Next update will be available next week, with TRS 1 MIDI Out bug fix,  XY Mirroring, A / B Toggle as requested  8)
Pedal maker at luminitefx.com
Luminite
#27
Graviton M1 3.2 Software Update
https://luminitefx.com/blogs/news/graviton-m1-3-2-software-update
New Features:
- Toggling CC/PC Messages: (A/B Toggling) Switch between two different set of CC/PC Messages within the same Preset. Added Toggling CC/PC Messages will be sent when the Toggling On or Momentary On setting is enabled, and the Preset is in "Toggled Off" state (when the Preset name turns gray). Also works great with Momentary On mode for holding notes / effects.
- Invert Up / Down: swaps the functionality of the XY Controller's up and down buttons, making it so that X up becomes X down and Y up becomes Y down. This is helpful for players who prefer the up/down switching orientation to mirror the screen instead of following it.
- Toggle State Display: Preset Library / XY Controllers / Footswitch Pedals Screens now display the Toogle State (On/Off) of all Presets, which is useful for keeping track of all states at a glance. MIDI Editor Screen also highlights which MIDI Messages are active if Toggling On or Momentary On mode is enabled.
Bug Fixes:
- Fixed a bug where TRS 1 Jack has to switch to Footswitch mode and then back to MIDI Out again after restarting for MIDI Out to work again.
- Fixed Momentary On mode not working (from 3.1 update).
- Fixed last changed CC value not saved in some cases (from 3.1 update)
User Manual:
Graviton M1 Software Update 3.2.0 User Manual
How to Update:
Go to Settings > Update >  Follow the on-screen instructions.
The update process typically takes 2-3 minutes. If it hangs up or takes longer than that, tap cancel or power cycle the device and try again.
