GM-800 lessons learned & yet another GM-800 vs GR-55 PCM tracking comparison
Started by shawnb, September 05, 2023, 10:15:07 PM
Rolloq
Quote from: Kitko on November 28, 2023, 08:26:44 AMhttps://www.vguitarforums.com/smf/index.php?topic=36156.msg268081#msg268081
https://www.amazon.de/dp/B083R5BJ6Q?ref=ppx_yo2ov_dt_b_product_details&th=1
As suggested by Elantric as reasonable pre-made substitute - has AL and CU shielding, drain wire.
I hade a 50 cm (20 inch) version made from https://shop.sommercable.com/en/Cable/Bulk-Cable-Audio/DMX-Binary-234-AES-EBU-MKII-520-0051.html by a company that's a Roland seller and also does audio/video installations. They offer custom cable building, called them with the specs, they suggested options and made the cable.
I got most details from this thread: https://www.vguitarforums.com/smf/index.php?topic=36026.0
I've experienced no intereference so I guess both work.
Hope this helps.
Could it be that the patch cable is shorter that makes the tracking faster?
Kitko
Boss SY-1000
Roland VG-99
Boss RC-600
Roland FC-300
Ibanez RGA 7 with GK3
Ibanez RGA 72QM with GK3 kit
Ibanez RGA 121 Prestige JD Craft
Quote from: Rolloq on November 28, 2023, 01:17:48 PMCould it be that the patch cable is shorter that makes the tracking faster?
Cable length makes no difference to tracking or latency delay (unless it was more than 100,000km long).
Tosh
Quote from: Tosh on November 29, 2023, 08:52:18 PMfor those lengths you use fiber optic
even excluding the effects of gravity, red-shift, and time dilation, all fiber-optic succumbs to the speed limits of the universe.  8)
 the important thing with high-speed serial data is the structure/quality of the cable/patch lead.
IMH1234
Quote from: gumtown on November 29, 2023, 03:33:50 PMCable length makes no difference to tracking or latency delay (unless it was more than 100,000km long).
And don't forget anything over a couple of thousand km is a nightmare to untangle when you need to patch it in a hurry  :)
