Boss GM-800 Videos
Started by Elantric, July 20, 2023, 02:03:13 PM
arkieboy
Quote from: gumtown on September 09, 2023, 05:47:59 PMCouldn't understand what was said in that last video, but it looks very informative.
With comparisons to previous/current synth models.
There are options in the subtitle menu to turn English translations on.
It is a good video, and very nice playing too.
BROCKSTAR
BROCKSTAR
Rolloq
#79
Rolloq
Rolloq
Quote from: Rolloq on September 21, 2023, 11:52:03 PM
Its probably best expressed as what not to do video imho.
Right off the bat  at 28 seconds he's hosting on his Google drive, "  GR-55 patches", bulk  which he obtained from Gumtowns GR-55 Floorboard app, which are originally created by VGUITARFORUMS users
He has a Strat with GK-3 setup with GK pickup too close to the bridge saddles at 10mm, when Roland/Boss recommends 20mm as ideal. No wonder he experiences a battle with poor tracking
Read " Can GK Pickup be mounted too close to bridge?
https://www.vguitarforums.com/smf/index.php?topic=13322.0
Then he mentions the GM-800 has less features for GK divided pickup configuration as its lacking the "GK Distance"  setting - (the distance of GK pickup from bridge saddles) while that setting does exist on GR-55 (@ 5:28 minutes)
In reality the GR-55  "GK Distance" setting is important for acurate COSM guitar modeling voicing, noticable on the GR-55 COSM Neck pickup model.
Since the GM-800 lacks any DSP Guitar Modeling, it has no need for a GK Distance setting . But 10mm GK pickup to bridge Distance is too close to the bridge for any GK Processor to track accurately, as there will be much higher harmonic overtones , and less fundamental pitch and lower output from a String with less physical excursion at 10mm vs 20mm
At 10:15 minutes his GK-5 on GM-800 Orchestral patch has notes that always sustain. This is probably due to incorrect Low Velocity Cut , or too high GK String sensitivity. Peaking the GK String Sensitivity VU Meters as rarely a good idea, its best to leave some margin because during actual performance most players have more aggressive string excursions mid song. He mentions tried the "Play feel to no avail , never mentioning the GM-800 's Low Velocity  Cut  parameter, and clearly is confused on GM-800 SYSTEM PARAMETERS cs GUITAR TO MIDI parameters, which are separate settings - instead he just blames the GK-5
Review Brock's comment
Review GM-800 Parameter Guide Page 9 SYSTEM PARAMETERS for Global Low Velocity Cut, Play Feel , etc - its separate from Guitar to MIDI
At 29 minutes he demonstrates how he is hosting and redistributing Colin Wilcox's Gumtown GR-55 Floorboard App, on his Google Drive.
Discuss Gumtown GR-55 Floorboard App at the source
https://www.vguitarforums.com/smf/index.php?topic=2951.0
Rolloq
Rolloq
BROCKSTAR
🚀 FALL COSMO IMPROV 🚀
#bossgm800 #eventideh90 #merislvx #line6helix #luminitefx #prs
MIDI Guitarist
I have just released the first of a five part video series about different uses of the GM-800. Maybe you guys are interested.
Nice, thanks I'll follow,
mchad
Quote from: MIDI Guitarist on October 15, 2023, 08:23:12 AMI have just released the first of a five part video series about different uses of the GM-800. Maybe you guys are interested.
Good stuff. Well done.
pasha811
Very useful and informative - Thank you!
MIDI Guitarist
Thanks a lot for the positive feedback - here is the second part of the series. I hope you like it.
BROCKSTAR
Gear that was used during this live recording: PRS Zach Myers SE guitar, Meris LVX, Meris MercuryX, Empress Effects ZOIA, Eventide H90, Boss GM-800, Boss SY-1000, Luminite Graviton M1 Wireless Midi Controller, El Garatge WEX Wireless Expression device.
BROCKSTAR
MIDI Guitarist
Here is part 3 of the series with a down to earth example  showing audio & MIDI input from the GM into a DAW:
Rolloq
Rolloq
BROCKSTAR
Piano thing I did on the Boss gm-800 with my prs. Only used one piano tone for this. I use my luminite wireless midi controller to turn attack and decay on and use that as a "pad" like sound and then turn it off to go back to the normal piano sound. Meris Mercury X reverb pedal also added for ambience.
MIDI Guitarist
This is part 4 of my series - it deals with notation into  Dorico, improving your  improvisation with a harmonica sound and getting inspired by self-made ambient sounds:
BROCKSTAR
A super lo-fi Chase Bliss LOSSY short.
Using my PRS guitar into my BOSS GM-800 guitar synth for piano, violin and pad into Lossy.
Bluesbird
Gear: Yamaha Revstar II RSS20, Squier Tele Deluxe 70s Fishman Tripleplay Controller, D'Adarrio EXL130 Strings, Novation Launchkey 49, Line 6 Helix Native, NDSP Tone King Imperial, Focusrite Saffire Pro 14, and tons of audio effect and synthesizer plug-ins.
