FC-300FloorBoard editor
Started by gumtown, June 19, 2023, 02:30:44 PM
Work has begun on a FC-300FloorBoard editor,
the FC-300 is deceptively deeper than expected, but also marginally crippled by its own design,
so could take a bit of time to get around this.
Have posted a Windows sneaky preview, which doesn't allow for too much editing at this stage, System/Utility settings, Standard Mode, and you can play around with SYSEX Mode, but Patch Mode is the 'Biggy' and will take time to master.
https://sourceforge.net/projects/fxfloorboard/files/FC-300FloorBoard/
Here is another incremental update, versions for Windows, Mac OS, and Linux.
sysex mode is fun to play with the pressed pedals are displayed in the editor, and the editor controls the FC-300 displays.
CC# Control mode works, but at this stage you need to hit the Write button on the FC-300 itself to save settings.
Standard mode works too, same thing, use the Write button on the FC-300 panel.
Patch Mode is still being constructed, but you can enter patch names currently, and save with the FC-300 write button.
The editor modes change when either the buttons are pressed in the editor, or the mode changed on the FC-300 panel.
Download link here:
Enjoy
Rolloq
Quote from: Rolloq on June 25, 2023, 05:29:55 AMThis is good work. 8)
Also always looking for user input too,
 hints, suggestions, wish-list, feedback.
Started using a new feature, time limited Alpha and Beta versions.
After 6 months, these pre-release versions will die, like in Blade Runner.
fokof
Haven't been able to make contact with the FC300
Midi I/O of the FC300 > USB to midi > CPU
( VB99 RRC2 unplugged )
OSX 10.14.6
Looks like a good start !
