How to save a new preset created from scratch without overwriting existing ones?
Started by paulwave88, April 20, 2023, 07:34:43 AM
paulwave88
Hi, I just bought the Boss GX-100, one question is that there are 50 banks and each bank has 4 slots so totally 200 slots, they are all loaded with the factory default presets from u01-1 to u50-4, if I build a new preset from scratch, I do not want to overwrite any of the 200 existing preloaded presets, so where and how should I save without overwrite any existing one? Thanks!
Boisdelac
I asume it is similar to other Boss units... You got 200 factory presets p1-1 ... p20-4  which are write protectet, and you got 200 user patches u1-1 ... u20-4 which are preloaded with the factory presets. The User patches are not write protected and you can edit or overwrite them. In case you edited one user patch you can reload it with the factory preset.
Select the certain factory preset and write it to the desired user patch.
Boisdelac
Concerning the Boss GX100 Reference Manual Page 14 there are 200 User Patches and 100  Factory Presets...
paulwave88
Oh, ok, there are one hundreds System presets from P01-1 to P25-4, which are read-only, and there are 200 User memories from U01-01 to U50-4, which are writable, but all the 200 memories are already loaded with effects, I want to keep them without overwriting them, so if I build a new patch, is there a way to store it somewhere else instead of overwriting one of the 200 memories which are already loaded with effects? or I have to overwrite one in order to save it?
You can use the Tone Studio software to save patch files to disk, but you will still need to use just one User patch memory slot to use as a save and transfer point.
Boisdelac
Only a questions to the pros...please don't hit me.
Are the factory presets different to the preloaded patches in the user memories? 100 vs. 200??? Are there really 300 different sounds??? Or are the factory presets also loaded to the user memories?
Quote from: Boisdelac on April 20, 2023, 10:22:31 PMOnly a questions to the pros...please don't hit me.
One would assume that the established protocol would be continued...   Don't know because I don't own one.
Magic Russ
The factory presets are also loaded into the user memories.
