Roland Ready Strat 13 pin female replacement
Started by palermodmd@gmail.com, February 19, 2023, 08:53:35 AM
Cheers all!
Broke the female 13 pin jack on my Roland Ready Strat and need a replacement. I'd like to stay stock if at all possible.
Can anyone tell me if/where I might find this?
Thanks very much!
roachone
Need "GUMBO" OR "Mojo" Both work on these type problems.
roachone
2 Of the forum guys here. Seem to have good connections for getting parts.
Thanks for the referral roachone...I can supply a Synth-Linx Jack that will replace the actual Roland JACK, but it is designed to bolt to the back of the original Roland jack mounting plate..
If this (plate) is what is broken, then you have to source the mounting plate elsewhere.
By all means PM me for further information.
Regards,
Peter
susbemol
#5
I've got a spare original one but I'm in the UK so probably not ideal for you.
Boisdelac
If the original part cannot be purchased  ...what about of buying a complete GT3 Kit. Ok, it is expensive...119€ at Thomann. But you can repair your guitar.
Quote from: Boisdelac on March 06, 2023, 01:28:24 AMIf the original part cannot be purchased  ...what about of buying a complete GT3 Kit. Ok, it is expensive...119€ at Thomann. But you can repair your guitar.
Have offered a replacement Synth-Linx Jack assembly (model SL13JRR) that is available from USA stock and tailored specifically for a Roland-Ready Strat....a lot cheaper, and a lot less complicated than effectively trying to 'update' a Roland-Ready Strat from GK2A electronics to GK3...
No reply from poster so I assume he has either fixed his problem elsewhere or decided that my alternative (at 68USD including USA postage) is beyond his budget.
....just saying.
