Help needed with Tone Studio
Started by -BOOGIEMAN-, February 09, 2023, 03:55:43 PM
-BOOGIEMAN-
I'm needing some help with the Tone Studio. I have some patches that I purchased and have set up on the Katana Artist. I want to assign which effects I like and their settings when I use the GAFC foot switch. For example, I would like to use a digital delay and set it up accordingly but I'm not seeing how to do this in Tone Studio. Any help would be appreciated.
gumtownadmin
It depends on a few things,
Which version of Katana you have Original Mk1 or the Mk2 (with double chevron emblem under the Katana symbol)
Which version of tone Studio you installed (Mk1 or Mk2) as they are not interchangeable.
Which firmware (system program) you are running in the Katana itself (Mk1 is at firmware 4, Mk2 is at firmware 2)
Once those three things align, you should be good.
-BOOGIEMAN-
Quote from: gumtownadmin on February 09, 2023, 04:15:08 PMIt depends on a few things,
Thanks for the info. I have the Artist MK2 and the correct tone studio loaded. I'm wondering if I'm just not doing something correct. Do I need to go into the editor and select the specific effect, adjust the settings, then go to the assign tab or something like that? I'm really hoping I can figure this out because when I use the foot switch and step on the delay when I'm in the effects mode, I don't hear any delay. Are these effects on the foot switch preset and unadjustable?
For the Delay effect, a strange thing wit the Katana is, the only way to switch it is to enable it in a channel and save that channe with the delay1 or delay2 in hat off/on state.
The GAFC foot switch (or any of the other foot switches) will only control the delay "tap time".
