BOSS GX-100 Reference Docs
Started by admin, March 03, 2022, 12:53:07 AM
Boss Tone Studio EDITOR (soon)
IR Loader app
GX-100 REFERENCE GUIDE
https://static.roland.com/assets/media/pdf/GX-100_Reference_eng01_W.pdf
CONTROL ASSIGN SETTINGS (6 pages)
GX-100 PARAMETER GUIDE
https://static.roland.com/assets/media/pdf/GX-100_prm_eng01_W.pdf
* Includes GX-100 "SOUND LIST" FACTORY PATCH DESCRIPTION (PG 170-172)
** GX-100 is also suitable for BASS - Has a Complement of AIRD BASS CABS - see "SP TYPE"
Download link below is a modified version of the Windows driver installer.
as the GX-100 only supports Windows 10 and 11, I have added support for
32 bit = Windows 98SE, 2000, Xp, 7, 8, 8.1
64 bit = Windows 7, 8, 8.1
https://sourceforge.net/projects/fxfloorboard/files/drivers/GX-100/gx100_wXp~11d_v100DL.zip/download
Now note!!!
as the folder contents are now modified the driver signing is now invalid, so if the installed operating system does not support unsigned drivers, then you need to reboot in unsigned driver mode.
Alternatively the driver can be installed manually by searching the install folders (unzip first) when installing the GX-100 USB.
https://www.howtogeek.com/167723/how-to-disable-driver-signature-verification-on-64-bit-windows-8.1-so-that-you-can-install-unsigned-drivers/#:~:text=Click%20the%20%E2%80%9CRestart%E2%80%9D%20button%20to,able%20to%20install%20unsigned%20drivers.
For Windows 10 and Windows 11 use the file provided by Boss from the Boss GX-100 webpage.
Also a repackaged installer for Tone Studio for GX-100 which now eliminates the minimum requirement of Windows 10 to install.
I will now install and run on Windows 7 and upwards.
download from
https://sourceforge.net/projects/fxfloorboard/files/drivers/GX-100/BTS_GX-100_Win7~11.zip/download
BTS for GX-100 (Android) @ Google Play store
jozart
For more information about most of the GX-100 effects, and tips and tricks for control assignments, I recommend the following titles, which can be found on this site:
BOSS GT-8 Brilliance! Ed. Tonealicious
Free Tutorials on the GT-5 and GP100 by Simon Lees
GT-x Guitar Effects Processors Set-up by Barry Pearce
tumad
Quote from: gumtown on March 08, 2022, 08:23:32 PMDownload link below is a modified version of the Windows driver installer.
Now note!!!
Tried this method but it doesn't work for me on windows 7 64 unfortunately :(
Quote from: tumad on June 04, 2022, 05:59:46 AMTried this method but it doesn't work for me on windows 7 64 unfortunately :(
Disable Driver Signing.
Follow these steps to disable driver signing using the Group Policy Editor.
Hit the Win+R keys together to open the run dialog. Type gpedit.msc to open the local groups policy editor.
Expand 'User Configuration' -> 'Administrative Templates' -> 'System'. Click 'Driver Installation'.
In the right panel, double click on 'Code Signing for Device Drivers'.
Choose 'Enabled' in the window that appears. In the underlying options, choose 'Ignore'. This disables drivers signing in Windows 7, and now you can install unsigned drivers in Windows 7.
Click Apply. Restart your computer to install unsigned drivers.
Quote from: gumtown on March 09, 2022, 11:38:50 PMAlso a repackaged installer for Tone Studio for GX-100 which now eliminates the minimum requirement of Windows 10 to install.
download from
I tried instaling this patched BTS for GX-100 on Win 8.1 64 Pro
Only get error - " Not compatible with this OS " midway through the install.
I realize Win 7/Win 8.1 are out of date - but this is one advantage of Every other DSP MFX company in 2022 still provides USB drivers and Editor apps that work with Win 7 / Win 8.1 /  and Win 10
While Roland / Boss latest 2022  gear editors  / USB drivers refuse to run on anything less than Win 10  - IMHO its going to restrict sales of new Roland/ Boss gear , and force many to return the Boss unit and seek Line-6/ NUX/ Hotone  / Fractal / MOOER who still support Win7/Win 8.1 on all their latest product releases
Magic Russ
Means improved stability, and eliminated bugs with a few Amp control assignments.
Be sure to read the SY-1000 Reference Manual
https://www.boss.info/global/products/sy-1000/
