Harley - Benton - DNAfx GiT Pro
Started by admin, December 06, 2021, 10:28:44 AM
Seems to be based on MOOER GE 250- I suspect MOOER designed it  - same features
http://www.mooeraudio.com/product/GE250-232.html
https://www.thomann.de/de/harley_benton_dnafx_git_pro.htm
owners manual
https://images.static-thomann.de/pics/atg/atgdata/document/manual/c_517099_en_online.pdf
Multi-effects pedal for electric guitar
with advanced amp modeling, multi-effects processor and IR loader
large selection of professional amp models
IR loudspeaker simulations for recording and FOH use
Expression / Volume Pedal
all effects can also be selected in stereo and in different order
stable aluminum housing
5 "color display
AMP control for channel switching
IR loader
Editor software
USB audio recording for PC and Mac
Incl. power supply
Connections:
2 balanced outputs: XLR
2 unbalanced outputs: 6.3 mm jack
MIDI In / Out
Headphone connection: 3.5 mm jack
Stereo FX loop for external effects: 2x 6.3 mm jack
AUX In: 3.5 mm jack
Connection for external expression pedal: 6.3 mm jack
Including various high-quality digital and analog effects such as:
compressor
EQ
Wah - Auto Wah or with Expression Pedal
Harmonizer
Overdrive
Distortion
Chorus
Flanger
Phasers
Rotary Speaker
tremolo
Reverb with different settings like Room / Plate / Spring / Hall / Church, etc.
Delay with various settings such as ping / pong, ducking, reverse, tape, modulation, etc.
Noise suppressor
Harley Benton has just launched its new, more powerful DNAfx GiT Pro. This expanded version of the DNAfx GiT is designed to give players even more tones in an affordable floor pedal board package, while offering more power and flexibility.
Harley Benton DNAfx Git Pro
The Harley Benton DNAfx Git Pro is a multi-effect unit with built-in amp simulation and cab modelling via IRs, and has enough power to handle most situations. But unsurprisingly for a Harley Benton product, it doesn't cost a fortune. The unit contains 51 amp models and 31 cabs, along with 64 effects. You can also load your own IRs.
DNAfx GiT Pro Photo Top
FX
Effects included range from distortion to all manner of modulations, plus reverbs/delays, through to pitch shifters and even a noise gate, to help tame your hiss. It also features a handy FX loop that can be placed anywhere as a slot, making it easy to do things like placing the internal effects of the DNAfx GiT Pro where you want, like placing a distortion before the preamp of your amplifier, then looping in a reverb effect after the preamp before sending it back out to your amp. With the built-in foot rocker or an external expression pedal, any effect parameter can also be manipulated on the fly.
Harley Benton DNAfx Git Pro rear panel
Features
The unit comes in an aluminium enclosure and has 4 foot switches, and a foot rocker treadle. You get a master volume control (not endless), along with five encoders (endless) under the coloured 5′′ display. There are also 5 pressure switches and a select push pot for added control.
On the rear of the unit you'll find connectivity for Input, Dual Mono outputs, an FX loop with Dual Mono Return, Dual Mono XLR Out, MIDI In/Out as a 5-pin DIN connection as well as a USB Type B, for use with the upcoming PC/Mac editor, for recording and for backups and firmware updates. Also onboard is an Expression In for connecting an additional expression pedal and an Amp Ctrl connector. The latter Amp Control feature lets you switch channels on your amp directly from the pedal. The AUX In and Headphones Out are on mini jacks, as the back panel is quite cramped.
The price point is very appealing and the unit offers a lot of useful features for the money. I can see them being popular for anyone on a limited budget.
Appears to be a spinoff based on a  MOOER GE 250
I expect a FLAMMA version soon
https://flammainnovation.com/
we know these are the same unit - different paint
Flamma FX-100
Flamma is Re- badged version of Harley- Benton DNA GiT Mobile with vol control moved to the side
https://harleybenton.com/product/dnafx-git-mobile/
