Deal Alert Thread
Started by Elantric, February 17, 2011, 08:40:36 AM
Among the best home speakers for using DSP Guitar Modelers at lower volume
Klipsch Promedia 2.1 THX Speaker system  $99
https://www.klipsch.com/products/klipsch-promedia-2-1-thx-computer-speaker-refurbished
Stage Right by Monoprice 15-Watt 1x12 Guitar Combo Tube Amp with Celestion Speaker and Spring Reverb $202.30 w/Coupon.
$202.30
CODE:  EXTRA15OFF
https://slickdeals.net/f/16580468-stage-right-by-monoprice-15-watt-1x12-guitar-combo-tube-amp-with-celestion-speaker-and-spring-reverb-202-30-w-coupon
Stage Right™ by Monoprice™
15‑Watt 1x12 Guitar Combo Tube Amp with Celestion Speaker and Spring Reverb
World's best reviewed and and most affordable 15‑watt 1x12 all‑tube guitar amp
The Monoprice™ Stage Right™ 15‑Watt 1x12 Guitar Combo Tube Amp has gained fame and incredible praise for combining superior tone and unparalleled affordability. With its dual EL84 and triple 12AX7 tube design, the Stage Right 15W Guitar Combo Tube Amp delivers the tone and features of guitar amps costing several times its price. It includes a genuine spring reverb, 3‑band EQ section, 1‑watt mode and switch, and a Celestion® Seventy 80 12" speaker. Simply put, the Stage Right 15‑Watt 1x12 Guitar Combo Tube Amp is the best‑reviewed and most affordable all‑tube guitar combo amp in the world, for good reason.
All‑tube design, driven by two EL84 and three 12AX7 tubes
Features a Celestion® Seventy 80 12" speaker
1‑watt mode for quiet playing without compromising tone
Genuine spring reverb with foot switch control
3‑band EQ section
FX loop and external cabinet output
mods
https://www.thegearpage.net/board/index.php?threads/monoprice-stage-right-15w-circuit-modification.2270680/
Theres a global sale on all Roland gear at this time
And fwiw, $599 was the original GR-55 price back in 2011
lespauled
EVH Striped Series Stratocaster Electric Guitar, Maple Fretboard, Red with Black Stripes
$849
https://slickdeals.net/share/iphone_app/t/16854449
https://www.musiciansfriend.com/stupid
$69
decent 24/192 USB Class Compliant Audio Interface with clean instrument  / mic preamps and MIDI I/O - works with Win/Mac/Android/IOS/AKAI MPC=Live/MPC-X
2 channel IN / 2 channel Out
decent software bundle with Ablton Live Lite
No idea why they call it confusingly "192-6" - probaly the 6th version
https://m-audio.com/air-192-6
Sets the new standard with professional studio-quality and features.
With the AIR 192|6, you can create 24-bit/192kHz studio-quality recordings with an intuitive and easy-to-use audio interface. Boasting an elegant pro-grade metal chassis with a large central volume knob, the AIR 192|6 features exclusive Crystal low-noise pre-amps and pristine A/D converters that deliver the highest audio performance in its class. The AIR 192|6 enables you to record up to 2 channels at once with its two dedicated XLR+1/4" balanced combo inputs, and two 1/4" instrument inputs that have a specially designed gain and impedance stage to provide the most accurate representation of a guitar or bass plugged directly into the interface. 5-pin MIDI In and Out connections are included for connecting synths, sequencers and other external MIDI gear. The AIR 192|6 connects to your Mac or PC via a standard USB or USB-C port using one of the two included cables. This premium Hi-Speed USB connection enables you to have zero-latency monitoring of your inputs, making the recording process easier than ever.
The overall combination of professional audio performance, easy-to-use features, and included AIR Series software bundle that provides everything you need to start recording now makes the AIR 192|6 an amazingly versatile, high-performance audio interface that sets the new standard for its class. You will be amazed at the incredibly solid construction, the high resolution and the overall ease of use. For producers looking to record small-ensemble vocal/instrument combinations, there isn't a better choice on the market.
Included software to match your style
The AIR 192|6 comes complete with a software package that has everything to get you started making professional recordings right out of the box, including popular DAW Ableton Live Lite. Ableton Live Lite is one of the most popular performance and production programs available in the world. A powerful music creation tool, Ableton Live Lite enables musicians and producers to spontaneously compose, record, remix, improvise and edit musical ideas in a fluid audio/MIDI environment.
M-Audio also added an entire Effects Plug-in, Virtual Instruments and Loop package to cater to all your production needs. Whether you need a guitar tone, reverb or delay they've got your effects needs covered with Eleven Lite, 20 effect plug-ins and AIR's Creative FX Collection. With the included AIR Virtual Instrument plug-ins, you'll have a virtual drum machine, synth, strings, percussion, organ and piano plug-ins to add world-class-sounding instruments to your songs with ease.
Crystal preamps, pristine A/D converters and premium components
Engineers designed the Crystal Preamps to provide engineers, producers and musicians with a transparent, low-noise preamp that guarantees the best sound from your microphones and captures your performance exactly the way you intended. The AIR 192|6 incorporates pristine A/D converters to provide 24-bit resolution digital audio for explosive dynamic range that captures every nuance and subtlety of your performance. When combined with the class-leading sample rates of up to 192kHz, you can be sure your recordings are completely clear and true to the performance. With layout and component choices that were carefully crafted by the engineering team in America, they've made sure you're getting the best sound available.
Hear the performance now—not a second later
When recording, you want to focus on capturing that perfect moment, and getting the best performance out of your artist and talent. You don't want to be bogged down by "clicks," "pops" or latency. The AIR 192|6 not only features a high-speed USB connection for providing the lowest round trip latency (2.59ms*) between your machine and your hardware, but it also features monitor mix control for listening directly to the source inputs, providing you with zero-latency technology.
Features
24-bit/192kHz resolution for professional recording and monitoring
Hi-Speed USB circuitry for fastest connection, with class-leading round-trip latency of 2.59ms*
Transparent Crystal preamps and ultrapristine A/D converters for unsurpassed audio recording quality
VU LED meters for dialing in the perfect level
Flexible inputs: (2) XLR+1/4" TRS combo or 1/4" instrument inputs
Use any combination of TRS combo or 1/4" instrument input on the two channels:
(2) TRS, (2) instrument or (1) of each
5-pin MIDI input/output for connecting virtually any external MIDI gear
Stereo 1/4" outs; 1/4" headphone out with independent level control
Rugged metal chassis; large central control for easy volume adjustment
USB/Direct knob for balancing between the input signal and the computer signal
*Round trip latency is dependent on buffer settings, and computer hardware
Included software:
Ableton Live Lite
Eleven Lite
Avid Effects Collection
AIR Music Tech Creative FX Collection
AIR Music Tech Xpand!2
AIR Music Tech Mini Grand
AIR Music Tech Vacuum
AIR Music Tech BOOM
AIR Music Tech DB33
2GB of Touch Loops Content
Stage Right by Monoprice 15-Watt 1x12 Guitar Combo Tube Amp $175
coupon code BF25
https://www.monoprice.com/product?p_id=611815
szilard
Tone Junkie 80% Off
Captures for Tonex, Kemper, Helix, and more. It says one day only, but worked for me today.
https://tonejunkiestore.com/
szilard
Black Friday
IKM Tonex SE Software $39.99
JRR Shop
https://www.jrrshop.com/ik-multimedia-tonex-se
Should be the same at the IKM store.
Quote from: Elantric on January 07, 2013, 01:48:27 PMAvid / M-Audio Venom Synth @ $167
http://www.amazon.com/gp/product/B004J96JTO/ref=oh_details_o02_s00_i00
This 49 key synth keyboard also features a 2in / 2 out Audio interface and 5pin MIDI I/O Interface and it allows you to feed external audio into its effects and filters with MIDI control.
Works as a Protools interface too.
Has a Guitar Input and a TRS Mic input too.
I picked one up on Saturday when the price was $167 with free shipping.
Typical Amazon - the price of this item is fluctuating each day lately between $150 and $350
Their is a rumor that with the recent activities of Avid selling off the M-Audio division to Numark / Alesis - that future support may soon be dropped for this model, but at $167 i could not resist.
10 years later, M-Audio is out of the Synth business , but I still have the Venom
Discovered the original M-Audio Design Engineer,  Taiho Yamada has a blog with tips & tricks , and links.
http://www.venom-synth.com/taiho/
https://soundcloud.com/paulmehlhaff/may-rain-m-audio-venom-demo
https://www.bhphotovideo.com/c/product/1381744-REG/zoom_zh1n_h1n_handy_recorder.html
$59
24 bit Stereo Recorder
USB STEREO AUDIO CLASS COMPLIANT INTERFACE ( WIN/MAC/IOS/ANDROID)
Features of the H1n
One-touch button controls
1.25" monochrome LCD display
Intuitive menus for easy operation
Stereo X/Y 90˚microphones handle up to 120 dB SPL
Stereo ⅛" Mic/Line In mini phone jack
Stereo ⅛" Phone/Line Output jack with dedicated volume control
Limiter button for input signal up to 120 dB SPL
Playback Speed Control, Voice Emphasize Filter, and Stereo Bounce functions
Auto-Record, Pre-Record, and Self-Timer functions
Supports up to 24-bit/96 kHz audio in BWF-compliant WAV or a variety of MP3 formats
Tone generator for filmmaking use with DSLR and video cameras
Records directly to SD and SDHC cards up to 32 GB
Micro USB port for data exchange to and from computer and use as an audio interface
Runs on only 2 standard AAA alkaline, Lithium, or NiMH rechargeable batteries, or AC adapter (AD-17)
Up to 10 hours of operation with alkaline batteries
https://zoomcorp.com/en/jp/handy-recorders/handheld-recorders/h1n-handy-recorder/
IPAD PRO/ANDROID USB micro to USB-C  AUDIO INTERFACE CABLE for Zoom H1n
https://www.amazon.com/dp/B07CHGK4G7?ref=ppx_yo2ov_dt_b_product_details&th=1
