expression pedal for SY1000
Started by myksara, October 27, 2020, 12:16:39 PM
myksara
Hi all,
I have just ordered my SY1000 and wanted to know the expression pedal that is recommended to be used with it.
Is there a pedal that works similar to an expression pedal on a multifx unit with a hard press on the toe to turn on the switch beneath the expression pedal to activate an effect- say  a wah?
I see Mission Engineering do a toe switch Expression pedal (model SP1) which is 10k TRS, and with another jack for the switch,
but I do not know if it is Boss compatible.
Another option is to get a Boss EXP pedal and glue a rubber block under the toe end of the pedal so it is offering resistance to the last 2% of pedal travel,
then use SY-1000 assigns so the last few numbers of the Source Min/Max range actuate the Assign target as the rubber block is compressed, acting like a toe switch.
BROCKSTAR
I don't know about any of that but if you want a cheap solution that works fine get a M-Audio EX-P... can find them around $30 new or $20 used and works perfectly fine. I use them for my sy-1000 and works for my hardware synths as well etc..
bobruz
Hey gang,
I need to configure the SY to respond to Midi CC messages for volume control.
Seem to be a challenge for me to find where I set this up.
Can someone point me to the right menu.  I'd like to set CC#7, 0-127 to control either FV2 or Master volume level on Midi chan. 2.
bobruz
Quote from: bobruz on November 04, 2020, 02:02:57 PM
Hey gang,
bobruz
Its in the CTRL/Assignment area - create an assignment with your desired MIDI CC# as SOURCE
FAQ
https://www.vguitarforums.com/smf/index.php?topic=26924.0
bobruz
Thanx!  I did get it going once I figured out the menu system.
Work great and sounds great too!
stuey99
Quote from: BROCKSTAR on October 27, 2020, 02:41:47 PM
Just ordered one of these on your recommendation from Amazon for £12.90!!!  Seems impossibly cheap but if it works I'll not complain
Learn All about expression pedals that work with Rolabd/Boss gear
https://www.vguitarforums.com/smf/index.php?topic=33.0
kimyo
Quote from: stuey99 on June 02, 2021, 09:03:23 AMJust ordered one of these on your recommendation from Amazon for £12.90!!!  Seems impossibly cheap but if it works I'll not complain
i have an m-audio ex-p and cannot get the full range out of it.  the low end never gets below 27 (on a scale of 0 - 100), regardless of how the knob is adjusted.
Quote from: kimyo on June 02, 2021, 09:58:25 AM
Which is typical
There is a mod to correct that
Bypass R2 (1k resistor) with a straight wire
= full EV-5 treadle sweep
kimyo
my apologies to m-audio, i do not have an ex-p.   the pedal which has the range limitation is an onstage kep-100.
i opened it up this evening and it has no resistors - is there anything else i can do?  it's just got the two potentiometers and the switch.
fwiw, the construction is pretty solid.
i guess it's kinda pointless to ask roland to add expression pedal calibration to the sy-1000 as that would eat into ev-5 sales.
stuey99
Thanks for the knowledge.
I'm guessing it's this resister shown here:
Quote from: admin on June 02, 2021, 10:15:43 AM
Which is typical
Psalm 150
The Boss EV-30 is a solid choice...more expensive than the M-Audio no doubt, but solid metal construction and dual outs...
I think I paid around $89 last year for mine...Looks like they are in the $75 to $95 range used on Reverb.com right now ($103 new).
The footprint is smaller than a typical Mission expression pedal, which I believe some people don't like, but it works for me!
...praise Him with stringed instruments....Psalm 150:4
drjoness2001
I uploaded a YouTube video with a comparison of various pedal used with the SY-1000:
https://www.joness.com/gr300/sy-1000-expression-pedal-roland-ev-5_boss-ev-30_moog-ep-3_mission-engineering-sp-1.html
Roland EV-5
Boss EV-30
Moog EP-3
Mission Engineering SP-1
stub
From that video, it looked like both EV pedals had a range of inactivity at the beginning of the range from heel-down to the first registering of a non-zero. The Moog and Mission seemed to start changing right away and therefore spread their range over the entire sweep.
Probably not a big issue. Just like a clutch, you get to know how it engages. But it did seem easier to get a smooth/gradual sweep with the last two.
These days I travel Lite, so been using $19  Proline /Nektar Expression pedals, they are 3/4 size of M-Audio Expression pedal
https://www.vguitarforums.com/smf/index.php?topic=33.msg120430#msg120430
littletardis
I have just configured my old Mission SP1 to work using MIDI via a Disaster area DMC-3XL Gen 3.
I set the Expression pedal of the SP1 to use MIDI CC 7 and then the toe switch on the SP1 to use midi cc 17 and then configured those into my patches instead of exp1 and ctl2 ( which I was using to change expression from volume to wah )
Now I can switch from volume to wah by operating the toe switch.... Which is nice.
Toddantho
It appears this thread got off track.... I am looking for same thing as OP.
An expression pedal that will activate wah (effect) with hard press ( toe switch), then use the pedal travel to control range parameter ..
It seems like the m audio , or the nectar don't have a toe switch .
I am looking for the pedal to have one cord into the sy 1000. Otherwise the Ampero press would do it with two cords into SY... Ampero press has a toe switch.
Still  enjoying the 13 pin world !
Toddantho
Just saw Gumtown's post on assigning effect on/off to the act range of 1 and 2.
That works nicely! Then you don't need a toe switch!
