NUX - MG-300 Firmware
Started by admin, October 18, 2020, 11:00:08 PM
NUX MG-300 FW 2.01.01
1.Extra Function: MASTER VOLUME SAVE & LOCK in GLOBAL setting.
2.Extra Function: In EDIT mode, press both " GROUP MODULE" buttons, you can ENGAGE/DISENGAGE current block.
3.Extra Function: In GLOBAL setting, press "SAVE" to save current OUTPUT MODE & GLOBAL EQ.
4.Extra Function: In PRESET mode, press SAVE, you can save current patch location as default reboot patch location.
5.Fixed Function: All the system settings, if there is no HINT, press "EDIT/EXIT" to quit, press "SAVE" to save.
6.Fixed Function: While you save current patch to other patch location, the current patch name will rewrite target patch location name.
See bottom of page
https://www.nuxefx.com/mg-300.html
FW Update Guide
http://v2sources.siiite.com//enclosure/sources/BgthLXDsrLFPCVau/NUX%20MG-300%20Firmware%20Update%20Guide.pdf
https://www.facebook.com/groups/879966155822846
What's NEW in Firmware V3?
1. Stageman Acoustic Amp Model
2. Acoustic IRs: T814,M OM28
3. P.L (Patch Level)
4. More accurate Output Modes
5. Loopback USB routing for live streaming
Nana
Hi. Sorry for necroing this... but due to experience it may be of importance to others as well.
When trying to update the firmware to V4.02.23 of May, 15th 2023, the MG (global version) stopped emitting sound with most of the patches!
I've boiled it down to the "NUX Device Updater.exe" in the recent "Firmware_NUX_MG300_EN_Windows_V4.02.23.zip".
This updater seems to be faulty, maybe even be for the "domestic version", who knows.
In the older firmware file "Firmware_NUX_MG-300_EN_V3.10.13-2021_Windows.zip" is the "NUX Device Firmware Updater v20813.exe", which works perfectly to send the "MG300_EN_V4.02.23.bin" update and the device works perfectly with all presets and effects.
Just because the original ZIP is no longer available on the NUX site and usually it makes no sense to keep old updates, I'd like to append the working older updater here, but sadly it looks like it's not possible.
One more issue with PC drivers and software updates:
Uninstall every NUX driver and QuickTone and delete all .CFG from "%USERPROFILE%\My Documents\NUX\" before installing the updated version. Otherwise QuickTone will stall on searching for the device.
Another issue with the lousy USB-implementation of the MG 300:
Turn off the MG before connecting USB to either device or PC and do not disconnect USB while the MG is running, otherwise the driver will lock up or the MG will lock up until power-cycle.
Nana
edit:
On https://www.nuxefx.com/support.html under Firmware & Software, tools, is a NUX Device Firmware Updater (DFU), which the same as in the V4 package and actually does not work.
Sorry.
Try at your own risk:
5256832 Bytes (5133 KiB)
SHA256: 4363a37f0ff4cfbbc738aec1b4e7513426bfbdcfc68bf83705a8980d24bd46ff
Quote from: Nana on July 18, 2023, 04:36:46 AMHi. Sorry for necroing this... but due to experience it may be of importance to others as well.
Must recalibrate Expression pedal after applying firmware update - restores audio output
Nana
Well, this is an assumption i already made. Everytime the firmware is updated and even every time a factory reset is performed, the pedal has to be calibrated afterwards, otherwise there will most likely be no sound at all.
But with the V4 update and the bundled updater, it did not make sounds, despite of a succesful pedal calibration.
kaiserflame
#6
For the domestic version, this should work. I almost gave up on this when NUX support replied to my email
https://imgur.com/a/UB9ZyYH
- https://cn.nuxaudio.com/mg300.html
Everything works fine for me with V4.02.23
Edit: Sorry I had to post on this. I was looking everywhere and there wasn't an answer for my domestic device getting messed up by the update with the device prompt "this device is domestic version please update with domestic firmware" .
Quote from: kaiserflame on January 18, 2024, 12:23:45 AMFor the domestic version, this should work. I almost gave up on this when NUX support replied to my email
NUX MG-300 Domestic Version= China domestic Market version = Chrome Knobs
NUX MG-300 Global Market Version = White Knobs
