SY1000 SWAM Cello through an Cello IR - what difference an IR can make!!
Started by Nobulusprime, October 05, 2020, 01:05:19 PM
Nobulusprime
So I took the SY1000 SWAM cello I created and stuck it through a Cello IR loaded on my AXE FXii.
It makes a world of difference, it's a shame that the SY1000 can't load IRs as this would make it amazing.
lumena
EarthToJonFrancis
Sounds great! Believe it or not, quite a few synth patches (especially the flute sounds) are enhanced by acoustic IRs.  It gives them a warmth and takes off that overly digital edge.
Piing
I shared a Cello IR here: https://forum.fractalaudio.com/threads/cello-preset-tone-match-and-ir-included.164770/
I used Kontakt Emotive Strings Library, tonematched against a sawtooth signal
I recorded this track using the SY-1000 sawtooth synth processed through the Axe-FX III
https://forum.fractalaudio.com/threads/cello-preset-tone-match-and-ir-included.164770/post-1978489
lumena
Thanks for reposting, i will play with it on my fm3. Really super sounds you are making
Yea that does make a difference as it takes some of the synthyness sound out of it.
what brand rosin are you using for the bow? ;D
Nobulusprime
Quote from: chrish on October 09, 2020, 02:52:36 PM
Ha ha!  ;D
Kitko
Quote from: Nobulusprime on October 05, 2020, 01:05:19 PMSo I took the SY1000 SWAM cello I created and stuck it through a Cello IR loaded on my AXE FXii.
I dropped the AMP module in the chain and tried a couple of amp/cab/etc combinations. One can get a pretty realistic sound with that.
Boss SY-1000
Roland VG-99
Boss RC-600
Roland FC-300
Ibanez RGA 7 with GK3
Ibanez RGA 72QM with GK3 kit
Ibanez RGA 121 Prestige JD Craft
jozart
3 Sigma Audio is one source of cello body IR.
The TC Electronic Impulse works well in the SY-1000 FX loop.
Kitko
I guess using IR-200 or IR-2 in the loop with that cello IR would do the trick :)
While Boss laughs all the way to the bank and our pedalboards are getting bigger and heavier.
Boss SY-1000
Roland VG-99
Boss RC-600
Roland FC-300
stub
In short-format cab convolution, an IR is little more than an EQ curve.
The EQ in the SY-1000 is pretty decent-- not surgical but good for general purpose shaping.
GCaturano
Quote from: Piing on October 06, 2020, 06:27:45 PMI shared a Cello IR here: https://forum.fractalaudio.com/threads/cello-preset-tone-match-and-ir-included.164770/
Sounds fantastic!
Could you share the IR file itself in WAV or AIF format, if that's feasible?
(I don't have an Axe Fx)
Thanks anyway! :)
Ciao,
  GiO
Hmmm - this gives me an idea to play with the Flamma FS07 with the SY for some things.   I primarily was using it with the VG-99 to make the guitar amps more palatable but for the last 3 months it's been plugged into the SY but was using it mostly with some overdrive to give it a more bottom end kick in the pants.
