SY-1000- New Cello Sample Modelling SWAM
Started by Nobulusprime, September 27, 2020, 12:47:15 PM
Nobulusprime
So I modelled this Cello on the Sample Modelling SWAM Cello's by using a spectrum analyser and my ears.
This is pretty good, but sounds really good through IR cello in the Axe FXII, The sample is just straight out of the Sy1000 with no cello IR so it's more accurate to what you get with the patch - feel free to play - cod classical noodling - I went down to a low F to give an idea of what it sounds like in the lower registers..
Ludek
Thought I might try the patch to text feature in SY-1000FloorBoard editor on your patch.  ;)
Mon Sep 28 09:52:24 2020
Boss SY-1000 Complete Patch Summary
a list of all parameters with-in this patch.
Patch name = CELLO-MODELED
Patch Mode = Guitar
Patch Common***********
[NUM 1 Patch Function] = *NUMBER 1
[NUM 1 Patch Mode] = TOGGLE
[NUM 2 Patch Function] = *NUMBER 2
[NUM 2 Patch Mode] = TOGGLE
[NUM 3 Patch Function] = *NUMBER 3
[NUM 3 Patch Mode] = TOGGLE
[NUM 4 Patch Function] = *NUMBER 4
[NUM 4 Patch Mode] = TOGGLE
[BANK DOWN Patch Function] = *BANK DOWN
[BANK DOWN Patch Mode] = TOGGLE
[BANK UP Patch Function] = *BANK UP
[BANK UP Patch Mode] = TOGGLE
[CTL1 Patch Function] = INST 3 ON/OFF
[CTL1 Patch Mode] = TOGGLE
[CTL2 Patch Function] = FX2
[CTL2 Patch Mode] = TOGGLE
[CTL3 Patch Function] = OFF
[CTL3 Patch Mode] = TOGGLE
[CTL4 Patch Function] = OFF
[CTL4 Patch Mode] = TOGGLE
[CTL5 Patch Function] = OFF
[CTL5 Patch Mode] = TOGGLE
[CTL6 Patch Function] = OFF
[CTL6 Patch Mode] = TOGGLE
[CNUM Patch Function] = OFF
[CNUM Patch Mode] = TOGGLE
[EXP1 Patch Function] = OFF
[EXP2 Patch Function] = OFF
[GK VOL Patch Function] = PATCH LEVEL 100
[GK S1 Patch Function] = LEVEL -20
[GK S1 Patch Mode] = TOGGLE
[GK S2 Patch Function] = LEVEL -10
[GK S2 Patch Mode] = TOGGLE
[NUM 1 Patch Function] = INST 1 ON/OFF
[NUM 2 Patch Function] = INST 2 ON/OFF
[NUM 3 Patch Function] = INST 3 ON/OFF
[NUM 4 Patch Function] = NORMAL
Patch Effect***********
[Patch Type] = gk_plug
[Normal] = OFF
[Volume] = 6
[Cable Sim] = 3m/10ft
[Phase] = NORMAL
[Foot Volume1 Volume Min] = 00
[Foot Volume1 Volume Max] = 100
[Foot Volume1 Pedal Position] = 100
[FV1 Volume Curve] = NORMAL
[Foot Volume2 Volume Min] = 00
[Foot Volume2 Volume Max] = 100
[Foot Volume2 Pedal Position] = 100
[FV2 Volume Curve] = NORMAL
[Divider Mode] = SINGLE
[Divider CH Select] = A
[Mix1 A/B Balance] = A100:B100
[Mix1 A Pan] = Center
[Mix1 B Pan] = Center
[Balancer1 A/B Balance] = A100:B100
[Balancer1 A Pan] = Center
[Balancer1 B Pan] = Center
[Balancer2 A/B Balance] = A100:B98
[Balancer2 A Pan] = Center
[Balancer2 B Pan] = Center
[Balancer3 A/B Balance] = A100:B100
[Balancer3 A Pan] = Center
[Balancer3 B Pan] = Center
[Send/Return Sw] = OFF
[Send/Return Mode] = NORMAL
[Send/Return Send] = 6
[Send/Return Return] = 6
[Send/Return Adjust] = 0
[Send/Return Phase] = NORMAL
[Main Stereo Link] = ON
[Main Left Phase] = NORMAL
[Main Right Phase] = NORMAL
[Sub Stereo Link] = ON
[Sub Left Left Phase] = NORMAL
[Sub Right Right Phase] = NORMAL
[Master Patch Level] = 6
[Master TEMPO] = 120
[Master Key] = C(Am)
[Control/Assign Tempo Hold] = OFF
[Control/Assign Input Sense] = 50
[Input Box1] = 0
[Input Box2] = INST2
[Input Box3] = INST3
[Input Box4] = NORMAL
[Chain Element1] = 28
[Chain Element2] = SPLIT
[Chain Element3] = SEND_RETURN
[Chain Element4] = SPLIT
[Chain Element5] = NOISE_SUPPRESSOR
[Chain Element6] = EQUALIZER1
[Chain Element7] = COMPRESSOR
[Chain Element8] = AMP
[Chain Element9] = DISTORTION
[Chain Element10] = FX2
[Chain Element11] = EQUALIZER2
[Chain Element12] = SPLIT
[Chain Element13] = FX3
[Chain Element14] = FX1
[Chain Element15] = MASTER_DELAY
[Chain Element16] = FOOT_VOLUME1
[Chain Element17] = DELAY1
[Chain Element18] = SPLIT
[Chain Element19] = CHORUS
[Chain Element20] = FOOT_VOLUME2
[Chain Element21] = DELAY2
[Chain Element22] = SPLIT
[Chain Element23] = REVERB
[Chain Element24] = DIVIDER
[Chain Element25] = BRANCH_AB
[Chain Element26] = MIXER
[Chain Element27] = SUB_OUT_L
[Chain Element28] = SUB_OUT_R
[Chain Element29] = MAIN_OUT_L
[Chain Element30] = MAIN_OUT_R
INSTRUMENT 2***********
[Inst INST On/Off] = ON
[Inst INST Type] = DYNAMIC SYNTH
[Inst INST Level] = 98
[Inst Nor Mix Sw] = OFF
[Inst Nor Mix Level] = 6
[String 1 Level] = 100
[String 2 Level] = 100
[String 3 Level] = 100
[String 4 Level ] = 100
[String 5 Level] = 100
[String 6 Level] = 100
[String 1 Pan] = Center
[String 2 Pan] = Center
[String 3 Pan] = Center
[String 4 Pan] = Center
[String 5 Pan] = Center
[String 6 Pan] = Center
Dynamic Synth 2***********
[Dynamic Synth Waveform] = TRIANGLE
[Dynamic Synth Pitch] = 0
[Dynamic Synth Fine] = 0
[Dynamic Synth Pulse Width] = 70
[Dynamic Synth PWM ENV Attack] = 0
[Dynamic Synth PWM ENV Depth] = 0
[Dynamic Synth Detune] = +10
[Dynamic Synth Sharpness] = 65
[Dynamic Synth Feedback] = 50
[Dynamic Synth Harmonics] = 70
[Dynamic Synth S-SAW Detune] = 20
[Dynamic Synth Pitch Env Attack] = 0
[Dynamic Synth Pitch Env Depth] = 0
[Dynamic Synth Pitch Bend Depth] = 0
[Dynamic Synth Pitch Bend CTL] = 0
[Filter Filter On/Off] = ON
[Filter Filter Type] = PKG
[Filter Slope] = -12dB
[Filter CutOff] = 71
[Filter Resonance] = 54
[Filter Flt Env Attack] = 0
[Filter Flt Env Depth] = 0
[Filter Amp ENV Attack] = -6
[Filter Low Cut] = 400Hz
[Filter High Cut] = 6.30kHz
[LFO LFO1 Off/On] = OFF
[LFO Shape] = SINE
[LFO Rate] = 82
[LFO Dynamic Depth] = ON
[Pitch Pitch Depth] = 1
[Pitch Filter Depth] = 16
[AMP Depth] = 0
[Pitch PWM Depth] = 2
[Pitch Fade Time] = 30
[Pitch Sync] = OFF
[LFO LFO2 Off/On] = OFF
[LFO Shape] = SQUARE
[LFO Rate] = 50
[LFO Dynamic Depth] = OFF
[Pitch Pitch Depth] = 50
[Pitch Filter Depth] = 0
[Pitch AMP Depth] = 0
[Pitch PWM Depth] = 0
[Pitch Sync] = OFF
[Pitch Pitch Target] = OFF
[Pitch CutOff Target] = OFF
[Pitch Level Target] = OFF
[SEQ 1 SEQ1 Off/On] = ON
[SEQ 1 Sync] = ON
[SEQ 1 Loop Length] = 4
[SEQ 1 Rate] = 1/4
[SEQ 1 1 Shot] = OFF
[SEQ 1 Turbo] = OFF
[SEQ 2 SEQ2 Off/On] = ON
[SEQ 2 Sync] = ON
[SEQ 2 Loop Length] = 4
[SEQ 2 Rate] = 1/4
[SEQ 2 1 Shot] = OFF
[SEQ 2 Turbo] = OFF
[Range LWR Fade] = 1
[Range Lower] = A0
[Range Upper] = E6
[Range UPPR Fade] = 1
INSTRUMENT 3***********
[Inst INST Level] = 100
[Inst Nor Mix Level] = 5
Dynamic Synth 3***********
[Dynamic Synth Waveform] = SAW
[Dynamic Synth Pulse Width] = 50
[Dynamic Synth PWM ENV Depth] = +30
[Dynamic Synth Sharpness] = 0
[Filter CutOff] = 45
[Filter Resonance] = 37
[Filter Amp ENV Attack] = -23
[Filter Low Cut] = 50.0Hz
[Filter High Cut] = 12.5kHz
[LFO LFO1 Off/On] = ON
[LFO Shape] = SINE
[LFO Rate] = 51
[Pitch Pitch Depth] = 4
[AMP Depth] = 0
[Pitch Fade Time] = 41
[Pitch Sync] = OFF
[LFO Rate] = 50
[Pitch Sync] = OFF
[SEQ 1 Sync] = ON
[SEQ 1 Rate] = 1/4
[SEQ 1 Turbo] = OFF
[SEQ 2 Sync] = ON
[SEQ 2 Rate] = 1/4
[SEQ 2 Turbo] = OFF
[Range Lower] = A0
[Range Upper] = E6
Compressor***********
[Comp On/Off] = ON
[Comp Type] = BOSS COMP
[Comp Sustain] = 90
[Comp Attack] = 33
[Comp Effect Level] = 45
[Comp Direct Level] = 26
[Comp Tone] = 0
Amplifier and Cabinet***********
[AMP Off/On] = ON
[AMP Type] = NATURAL
[AMP Gain] = 52
[AMP Sag] = -4
[AMP Resonance] = +10
[AMP Level] = 50
[AMP Bass] = 50
[AMP Middle] = 50
[AMP Treble] = 56
[AMP Presence] = 13
[AMP Bright] = ON
[AMP Gain Sw] = MIDDLE
[AMP Solo Sw] = OFF
[AMP Solo Level] = 51
[SPKR SP Type] = 1x8"
[SPKR Mic Type] = CND87
[SPKR Mic Distance] = MEDIUM
[SPKR Mic Position] = 10cm
[SPKR Mic Level] = 89
[SPKR Direct Level] = 70
Noise Suppressor***********
[NS On/Off] = ON
[NS Threshold] = 31
[NS Release] = 43
[NS Detect] = GK INPUT
Equalizer 1***********
[EQ EQ. On/Off] = ON
[EQ Low Gain] = -1dB
[EQ High Gain] = -3dB
[EQ Low Mid Freq] = 400Hz
[EQ Low Mid Q] = 1
[EQ Low Mid Gain] = -18dB
[EQ High Mid Freq] = 8.00kHz
[EQ High Mid Q] = 1
[EQ High Mid Gain] = -14dB
[EQ Low Cut] = 160Hz
[EQ High Cut] = 16.0kHz
[EQ Level] = +7dB
Equalizer 2***********
[EQ Low Gain] = -2dB
[EQ High Gain] = -4dB
[EQ Low Mid Freq] = 160Hz
[EQ Low Mid Q] = 4
[EQ Low Mid Gain] = -2dB
[EQ High Mid Freq] = 10.0kHz
[EQ High Mid Q] = 2
[EQ High Mid Gain] = +7dB
[EQ Low Cut] = FLAT
[EQ Level] = +2dB
Master Delay***********
[Mst Delay Off/On] = ON
[Mst Delay Type] = STEREO 2
[Delay Time] = 27ms
[Delay Feedback] = 31
[Delay High Cut] = 2.00kHz
[Delay Effect] = 54
[Delay Direct] = 100
[D1 Time] = 100ms
[D1 Feedback] = 20
[D1 High Cut] = FLAT
[D1 Effect] = 50
[D2 Time] = 400ms
[D2 Feedback] = 20
[D2 High Cut] = FLAT
[D2 Effect] = 50
[MOD Mod Rate] = 40
[MOD Mod Depth] = 50
[MOD Trigger] = OFF
[TWIST Mode] = Rise>Fall
[TWIST Rise Time] = 50
[TWIST Fall Time] = 50
[TWIST Fade Time] = 50
[Pan Tap Time] = 50%
[Mst Delay Carry Over] = ON
FX 1***********
[FX Off/On] = ON
[FX Type] = VIBRATO
FX1 Vibrato***********
[Vibrato Rate] = 49
[Vibrato Depth] = 30
[Vibrato Trigger] = ON
[Vibrato Rise Time] = 95
[Vibrato Effect] = 75
[Vibrato Direct] = 8
FX 2***********
[FX Off/On] = ON
[FX Type] = AC RESONANCE
FX2 Acoustic Resonator***********
[AcReso Type] = NATURAL
[AcReso Resonance] = 88
[AcReso Tone] = -19
[AcReso Level] = 81
FX 3***********
[FX Off/On] = ON
[FX Type] = GRAPHIC EQ
FX3 Graphic EQ***********
[GEQ 100Hz] = +1dB
[GEQ 200Hz] = -3dB
[GEQ 400Hz] = +9dB
[GEQ 800Hz] = +1dB
[GEQ 1.6kHz] = +3dB
[GEQ 3.2kHz] = +5dB
[GEQ 6.4kHz] = -5dB
[GEQ Level] = -7dB
Reverb***********
[Reverb Off/On] = ON
[Reverb Type] = PLATE
[Reverb Time] = 3.4s
[Reverb Carry Over] = ON
[Reverb Pre-Delay] = 00ms
[Reverb Effect] = 51
[Reverb Low Cut] = 315Hz
[Reverb High Cut] = FLAT
[Reverb Density] = 10
[Reverb Direct] = 100
[Reverb Spring Sense] = 50
Nobulusprime
Quote from: gumtown on September 27, 2020, 02:01:28 PM
Ha ha, wow, I threw a lot at that patch! It proves I can't spell 'Modelled' too!
Looking forward to your editor, it will make my patch creation life so much easier ;)
Sounds good. Wish I had a 64x computer so I load up this patch and some of the others offered on this site.
Not sure about trying to patch all those parameters in the text version.
jozart
I like the patch dump. Why are NUM X Patch Function and Mode listed twice?
arkieboy
Nicely done.  It's obviously a synth but really has that cello feel to it.  Very nice!
Nobulusprime
Quote from: aliensporebomb on September 28, 2020, 06:09:33 AM
Yeah definitely, subtractive synths with 3 oscillators are never going to get to that close. It sounds much more like a piezo bridge pick up on a cello would sound,
That said I will post it again through Axe FX II Cello IR and a comb filter as that does brings it to life. I wish we could load IRs into the SY1000, maybe one day Roland....?
Yanko
Quote from: Nobulusprime on September 29, 2020, 05:21:55 AM
WOW! :D Just great! Yes since the new Boss GT-1000CORE can load IRs one would hope Boss would implement this on SY-1000. I was hoping one could atleast pair the two in a smart way via USB or something like that...
Kitko
@gumtown
Which of your Sourceforge editors is SY-1000FloorBoard editor.
Boss SY-1000
Roland VG-99
Boss RC-600
Roland FC-300
Ibanez RGA 7 with GK3
Ibanez RGA 72QM with GK3 kit
Ibanez RGA 121 Prestige JD Craft
Kitko
@Elantric Thank you.
Apparently, one of the ad blockers hid the Expand button on the gumtownbassman's page that lists all the editors.
Boss SY-1000
Roland VG-99
Boss RC-600
Roland FC-300
