Sy-1000 soundhold block bug ?
Started by Brak(E)man, February 19, 2020, 01:09:45 PM
This is the soundhold block used with wavepedal and controller.
Both do the same thing, I thought it was due to the wave pedal but nop..
Sometimes there's a click sound when trigger goes off and sometimes not.
Doesn't matter if it's a picked, swelled , single or more note(s)
I haven't found any reason why it's not consistent.
BROCKSTAR
This is exactly the sound I was getting when I used the sound hold block after the fx loop block, but once I put the sound hold block before the fx loop block it went to normal....
Quote from: BROCKSTAR on February 24, 2020, 03:39:25 AM
Thanx I will check again but I think I had this on the normal PU
and the send/return block was on one or two of the instruments
and it was definitely not on.
But in any case it's confirmed, it's a bug.
If it's correlated with the reverb and the send/return block is an open question so far.
Btw do you mean the stutter or the digital click ?
I moved the Send Return and Sound hold everywhere but same thing.
Sometimes there a stutter sometimes not but the worst part is that
sometimes there's a digital click , other times not...
There should be a release setting as well.
But I feel it's confirmed, it's a bug
Wow that's strange!  Brak(e)man what type of controller?
Quote from: aliensporebomb on November 09, 2022, 10:09:31 AMWow that's strange!  Brak(e)man what type of controller?
The one on the unit.
But what I'm saying is that it doesn't matter if I use the wave pedal or controller
to trig the sound hold fx , there's a click when it releases at times and not all the time.
Frank
Quote from: Brak(E)man on November 09, 2022, 11:26:14 AMBut what I'm saying is that it doesn't matter if I use the wave pedal or controller
I've found this too and that the Hold block is basically useless, especially as there is no release unlike the the VG-99 Freeze.
Perfect - now I just need to add some delays and other wild stuff to it!   Crazy!
Quote from: aliensporebomb on March 26, 2024, 06:04:17 AMPerfect - now I just need to add some delays and other wild stuff to it!  Crazy!
You can hear it on this tune.
https://brakophonic.bandcamp.com/track/two-fast
