Katana MKII MIDI Address Map /w BTS SysEx examples
Started by CodeSmart, February 10, 2020, 01:35:36 PM
CodeSmart
Here ya go! CodeSmart/Robert Fransson Feb-10-2020 - KATANA MKII MIDI MAP
PART (I)
'Out:' = What BTS sends out
'In:' = Example of Katana response
GENERAL IDENTIFICATION
Out: Request ID   F0 7E 7F 06 01 F7
In: Katana MKI V3   F0 7E 00 06 02 41 33 03 00 00 03 01 00 00 F7
In: Katana MKI V4   F0 7E 00 06 02 41 33 03 00 00 03 01 00 00 F7
In: Katana MKII   F0 7E 00 06 02 41 33 03 00 00 08 00 00 00 F7
SYSTEM AREA
Out: F0 41 00 00 00 00 33 11 00 00 00 00 00 00 00 2E 52 F7
In : F0 41 00 00 00 00 33 12 00 00 00 00 00 14 32 19 01 00 00 32 00
     00 00 00 00 00 00 00 00 00 01 00 14 0D 01 14 17 01 14 14 0E 14
     18 18 18 18 18 18 18 18 18 18 18 00 00 00 00 14 39 F7
Address   Size   Ofs   Init   Min   Max   Name   Comment
0x00000000   INTEGER1x7        0   0   0   0   'USB IN OUT MODE'       PRM_SYS_USB_IN_OUT_MODE
0x00000001   INTEGER1x7        20   0   -20   20   'USB INPUT LEVEL'       PRM_SYS_USB_INPUT_LEVEL
0x00000002   INTEGER1x7        0   50   0   100   'USB OUT LEVEL'         PRM_SYS_USB_OUT_LEV
0x00000003   INTEGER1x7        0   25   0   100   'USB MIX LEVEL'         PRM_SYS_USB_MIX_LEV
0x00000004   INTEGER1x7        0   1   1   1   'USB DIR MONITOR'       PRM_SYS_USB_DIR_MONITOR
0x00000005   INTEGER1x7        0   0   0   0   'USB DIR MONITOR CMD'   PRM_SYS_USB_DIR_MONITOR_CMD
0x00000006   INTEGER1x7        0   0   0   1   'USB LOOPBACK'          PRM_SYS_USB_LOOPBACK
0x00000007   INTEGER1x7        0   50   0   100   'USB2 OUT LEVEL'        PRM_SYS_USB_2_OUT_LEV
0x00000008   (PADDING | 0x8)   0   0   0   0   ''                      (padding)
                     (padding)
                     (padding)
                     (padding)
                     (padding)
                     (padding)
                     (padding)
                     (padding)
0x00000010   INTEGER1x7        0   0   0   1   'SW'                    PRM_SYS_EQ_SW
0x00000011   INTEGER1x7        0   0   0   1   'TYPE'                  PRM_SYS_EQ_TYPE
0x00000012   INTEGER1x7        0   1   0   1   'POSITION'              PRM_SYS_EQ_POSITION
0x00000013   INTEGER1x7        0   0   0   17   'LOW CUT'               PRM_SYS_EQ_PEQ_LOW_CUT
0x00000014   INTEGER1x7        20   0   -20   20   'LOW GAIN'              PRM_SYS_EQ_PEQ_LOW_GAIN
0x00000015   INTEGER1x7        0   13   0   27   'LOW-MID FREQ'          PRM_SYS_EQ_PEQ_LOWMID_FREQ
0x00000016   INTEGER1x7        0   1   0   5   'LOW-MID Q'             PRM_SYS_EQ_PEQ_LOWMID_Q
0x00000017   INTEGER1x7        20   0   -20   20   'LOW-MID GAIN'          PRM_SYS_EQ_PEQ_LOWMID_GAIN
0x00000018   INTEGER1x7        0   23   0   27   'HIGH-MID FREQ'         PRM_SYS_EQ_PEQ_HIGHMID_FREQ
0x00000019   INTEGER1x7        0   1   0   5   'HIGH-MID Q'            PRM_SYS_EQ_PEQ_HIGHMID_Q
0x0000001a   INTEGER1x7        20   0   -20   20   'HIGH-MID GAIN'         PRM_SYS_EQ_PEQ_HIGHMID_GAIN
0x0000001b   INTEGER1x7        20   0   -20   20   'HIGH GAIN'             PRM_SYS_EQ_PEQ_HIGH_GAIN
0x0000001c   INTEGER1x7        0   14   0   14   'HIGH CUT'              PRM_SYS_EQ_PEQ_HIGH_CUT
0x0000001d   INTEGER1x7        20   0   -20   20   'LEVEL'                 PRM_SYS_EQ_PEQ_LEVEL
0x0000001e   INTEGER1x7        24   0   -24   24   '31Hz'                  PRM_SYS_EQ_GEQ_BAND1
0x0000001f   INTEGER1x7        24   0   -24   24   '62Hz'                  PRM_SYS_EQ_GEQ_BAND2
0x00000020   INTEGER1x7        24   0   -24   24   '125Hz'                 PRM_SYS_EQ_GEQ_BAND3
0x00000021   INTEGER1x7        24   0   -24   24   '250Hz'                 PRM_SYS_EQ_GEQ_BAND4
0x00000022   INTEGER1x7        24   0   -24   24   '500Hz'                 PRM_SYS_EQ_GEQ_BAND5
0x00000023   INTEGER1x7        24   0   -24   24   '1KHz'                  PRM_SYS_EQ_GEQ_BAND6
0x00000024   INTEGER1x7        24   0   -24   24   '2KHz'                  PRM_SYS_EQ_GEQ_BAND7
0x00000025   INTEGER1x7        24   0   -24   24   '4KHz'                  PRM_SYS_EQ_GEQ_BAND8
0x00000026   INTEGER1x7        24   0   -24   24   '8KHz'                  PRM_SYS_EQ_GEQ_BAND9
0x00000027   INTEGER1x7        24   0   -24   24   '16KHz'                 PRM_SYS_EQ_GEQ_BAND10
0x00000028   INTEGER1x7        24   0   -24   24   'LEVEL'                 PRM_SYS_EQ_GEQ_LEVEL
0x00000029   INTEGER1x7        0   0   0   2   'LINE OUT AIR FEEL'     PRM_SYS_LINE_OUT_MODE
0x0000002a   INTEGER1x7        0   0   0   1   'EXPAND MODE'           PRM_SYS_EXPAND_MODE
0x0000002b   INTEGER1x7        0   0   0   4   'TYPE'                  PRM_SYS_PWR_CAB_EQ_TYPE
0x0000002c   INTEGER1x7        -1   1   1   100   'FREQ'                  PRM_SYS_PWR_CAB_EQ_FREQ
0x0000002d   INTEGER1x7        20   0   -20   20   'LEVEL'                 PRM_SYS_PWR_CAB_EQ_LEVEL
Info properties
Out: F0 41 00 00 00 00 33 11 00 01 00 00 00 00 00 02 7D F7
In : F0 41 00 00 00 00 33 12 00 01 00 00 00 01 7E F7 00 00
0x00010000   INTEGER2x7   0   0   0   8   'PATCH NUM'   PRM_SYS_PATCH_SEL
MIDI properties
Out: F0 41 00  00 00 00 33 11 00 02 00 00 00 00 00 15 69 F7
In : F0 41 00 00 00 00 33 12 00 02 00 00 00 10 11 12 13 14 15 30 31
     32 33 34 04 00 01 02 03 05 06 07 08 71 F7 00
0x00020000   INTEGER1x7   0   0   0   15   'RX CHANNEL'         PRM_SYS_MIDI_RX_CH
0x00020001   INTEGER1x7   1   15   0   62   'RxCcBoosterSw'      PRM_SYS_MIDI_CC_BOOST_SW
0x00020002   INTEGER1x7   1   16   0   62   'RxCcModSw'          PRM_SYS_MIDI_CC_MOD_SW
0x00020003   INTEGER1x7   1   17   0   62   'RxCcFxSw'           PRM_SYS_MIDI_CC_FX_SW
0x00020004   INTEGER1x7   1   18   0   62   'RxCcDelaySw'        PRM_SYS_MIDI_CC_DELAY_SW
0x00020005   INTEGER1x7   1   19   0   62   'RxCcReverbSw'       PRM_SYS_MIDI_CC_REVERB_SW
0x00020006   INTEGER1x7   1   20   0   62   'RxCcSendReturnSw'   PRM_SYS_MIDI_CC_XLP_SW
0x00020007   INTEGER1x7   1   47   0   62   'RxCcExpPedal'       PRM_SYS_MIDI_CC_EXPPEDAL
0x00020008   INTEGER1x7   1   48   0   62   'RxCcGafcExp1'       PRM_SYS_MIDI_CC_GAFCEXP1
0x00020009   INTEGER1x7   1   49   0   62   'RxCcGafcExp2'       PRM_SYS_MIDI_CC_GAFCEXP2
0x0002000a   INTEGER1x7   1   50   0   62   'RxCcGafcFs1'        PRM_SYS_MIDI_CC_GAFCFS1
0x0002000b   INTEGER1x7   1   51   0   62   'RxCcGafcFs2'        PRM_SYS_MIDI_CC_GAFCFS2
0x0002000c   INTEGER1x7   0   4   0   127   'RxPcPanel'          PRM_SYS_MIDI_PC_PANEL
0x0002000d   INTEGER1x7   0   0   0   127   'RxPcACh1'           PRM_SYS_MIDI_PC_A1
0x0002000e   INTEGER1x7   0   1   0   127   'RxPcACh2'           PRM_SYS_MIDI_PC_A2
0x0002000f   INTEGER1x7   0   2   0   127   'RxPcACh3'           PRM_SYS_MIDI_PC_A3
0x00020010   INTEGER1x7   0   3   0   127   'RxPcACh4'           PRM_SYS_MIDI_PC_A4
0x00020011   INTEGER1x7   0   5   0   127   'RxPcBCh1'           PRM_SYS_MIDI_PC_B1
0x00020012   INTEGER1x7   0   6   0   127   'RxPcBCh2'           PRM_SYS_MIDI_PC_B2
0x00020013   INTEGER1x7   0   7   0   127   'RxPcBCh3'           PRM_SYS_MIDI_PC_B3
0x00020014   INTEGER1x7   0   8   0   127   'RxPcBCh4'           PRM_SYS_MIDI_PC_B4
PATCH AREA
   Start Address
User Patch(1)   0x10000000
User Patch(2)   0x10010000
User Patch(3)   0x10020000
User Patch(4)   0x10030000
User Patch(5)   0x10040000
User Patch(6)   0x10050000
User Patch(7)   0x10060000
User Patch( 8  )   0x10070000
User Patch(9)   0x10080000
Temporary   0x60000000
TEMPORARY PATCH  (0x60000000) MEMORY LAYOUT
PATCH NAME
Out: F0 41 00 00 00 00 33 11 60 00 00 00 00 00 00 10 10 F7
In:  F0 41 00 00 00 00 33 12 60 00 00 00 4C 65 61 64 20 53 68 72 65
     64 20 20 20 20 20 20 54 F7
0x60000000   16 bytes   0   'KATANA Mk2      '   0   1   'PATCH NAME'   PRM_PATCH_NAME0
PATCH PROPERTIES
Out: F0 41 00 00 00 00 33 11 60 00 00 10 00 00 00 48 48 F7
In:  F0 41 00 00 00 00 33 12 60 00 00 10 00 0A 2E 3C 32 00 32 34 00
     00 32 32 32 32 32 00 01 1D 1B 0A 50 3D 3B 5E 5C 00 01 00 32 00
     01 01 05 64 00 00 32 32 05 05 32 32 32 07 0A 0A 02 00 00 00 00
     14 0E 01 14 17 01 14 14 0E 14 18 18 18 18 18 18 18 18 18 18 18
     65 F7
0x60000010   INTEGER1x7       0   0   0   1   'SW'                  PRM_ODDS_SW
0x60000011   INTEGER1x7       0   10   0   22   'TYPE'                PRM_ODDS_TYPE
0x60000012   INTEGER1x7       0   50   0   120   'DRIVE'               PRM_ODDS_DRIVE
0x60000013   INTEGER1x7       50   10   -50   50   'BOTTOM'              PRM_ODDS_BOTTOM
0x60000014   INTEGER1x7       50   0   -50   50   'TONE'                PRM_ODDS_TONE
0x60000015   INTEGER1x7       0   0   0   1   'SOLO SW'             PRM_ODDS_SOLO_SW
0x60000016   INTEGER1x7       0   50   0   100   'SOLO LEVEL'          PRM_ODDS_SOLO_LEVEL
0x60000017   INTEGER1x7       0   40   0   100   EFFECT LEVEL'        PRM_ODDS_EFFECT_LEVEL
0x60000018   INTEGER1x7       0   0   0   100   'DIRECT MIX'          PRM_ODDS_DIRECT_LEVEL
0x60000019   INTEGER1x7       0   0   0   8   ''                    Sneaky: CUSTOM TYPE
0x6000001a   INTEGER1x7       0   50   0   100   ''                    Sneaky: CUSTOM BOTTOM
0x6000001b   INTEGER1x7       0   50   0   100   ''                    Sneaky: CUSTOM TOP
0x6000001c   INTEGER1x7       0   50   0   100   ''                    Sneaky: CUSTOM LOW
0x6000001d   INTEGER1x7       0   50   0   100   ''                    Sneaky: CUSTOM HIGH
0x6000001e   INTEGER1x7       0   50   0   100   ''                    Sneaky: CUSTOM CHARACTER
0x6000001f   (PADDING | 0x1)   0   0   0   0   ''                    (padding)
0x60000020   INTEGER1x7       0   1   1   1   ''
0x60000021   INTEGER1x7       0   8   0   32   'TYPE'                PRM_PREAMP_A_TYPE
0x60000022   INTEGER1x7       0   60   0   120   'GAIN'                PRM_PREAMP_A_GAIN
0x60000023   INTEGER1x7       0   10   10   10   ''
0x60000024   INTEGER1x7       0   50   0   100   'BASS'                PRM_PREAMP_A_BASS
0x60000025   INTEGER1x7       0   50   0   100   'MIDDLE'              PRM_PREAMP_A_MIDDLE
0x60000026   INTEGER1x7       0   50   0   100   'TREBLE'              PRM_PREAMP_A_TREBLE
0x60000027   INTEGER1x7       0   50   0   100   'PRESENCE'            PRM_PREAMP_A_PRESENCE
0x60000028   INTEGER1x7       0   50   0   100   'LEVEL'               PRM_PREAMP_A_LEVEL
0x60000029   INTEGER1x7       0   0   0   1   'BRIGHT'              PRM_PREAMP_A_BRIGHT
0x6000002a   INTEGER1x7       0   1   1   1   ''
0x6000002b   INTEGER1x7       0   0   0   1   'SOLO SW'             PRM_PREAMP_A_SOLO_SW
0x6000002c   INTEGER1x7       0   50   0   100   'SOLO LEVEL'          PRM_PREAMP_A_SOLO_LEVEL
0x6000002d   INTEGER1x7       0   0   0   0   ''
0x6000002e   INTEGER1x7       0   1   0   4   ''
0x6000002f   INTEGER1x7       0   1   0   1   ''
0x60000030   INTEGER1x7       0   5   0   10   ''
0x60000031   INTEGER1x7       0   100   0   100   ''
0x60000032   INTEGER1x7       0   0   0   100   ''
0x60000033   INTEGER1x7       0   0   0   6   ''
0x60000034   INTEGER1x7       0   50   0   100   ''
0x60000035   INTEGER1x7       0   50   0   100   ''
0x60000036   INTEGER1x7       0   5   0   10   ''
0x60000037   INTEGER1x7       0   5   0   10   ''
0x60000038   INTEGER1x7       0   50   0   100   ''
0x60000039   INTEGER1x7       0   50   0   100   ''
0x6000003a   INTEGER1x7       0   50   0   100   ''
0x6000003b   INTEGER1x7       0   7   0   10   ''
0x6000003c   INTEGER1x7       0   10   0   20   ''
0x6000003d   INTEGER1x7       0   10   0   20   ''
0x6000003e   INTEGER1x7       0   2   0   3   ''
0x6000003f   INTEGER1x7       0   0   0   1   ''
0x60000040   INTEGER1x7       0   0   0   1   'SW'                  PRM_EQ_SW
0x60000041   INTEGER1x7       0   0   0   1   'TYPE'                PRM_EQ_TYPE
0x60000042   INTEGER1x7       0   0   0   17   'LOW CUT'             PRM_EQ_LOW_CUT
0x60000043   INTEGER1x7       20   0   -20   20   'LOW GAIN'            PRM_EQ_LOW_GAIN
0x60000044   INTEGER1x7       0   14   0   27   'LOW-MID FREQ'        PRM_EQ_LOWMID_FREQ
0x60000045   INTEGER1x7       0   1   0   5   'LOW-MID Q'           PRM_EQ_LOWMID_Q
0x60000046   INTEGER1x7       20   0   -20   20   'LOW-MID GAIN'        PRM_EQ_LOWMID_GAIN
0x60000047   INTEGER1x7       0   23   0   27   'HIGH-MID FREQ'       PRM_EQ_HIGHMID_FREQ
0x60000048   INTEGER1x7       0   1   0   5   'HIGH-MID Q'          PRM_EQ_HIGHMID_Q
0x60000049   INTEGER1x7       20   0   -20   20   'HIGH-MID GAIN'       PRM_EQ_HIGHMID_GAIN
0x6000004a   INTEGER1x7       20   0   -20   20   'HIGH GAIN'           PRM_EQ_HIGH_GAIN
0x6000004b   INTEGER1x7       0   14   0   14   'HIGH CUT'            PRM_EQ_HIGH_CUT
0x6000004c   INTEGER1x7       20   0   -20   20   'LEVEL'               PRM_EQ_LEVEL
0x6000004d   INTEGER1x7       24   0   -24   24   '31Hz'                PRM_EQ_GEQ_BAND1
0x6000004e   INTEGER1x7       24   0   -24   24   '62Hz'                PRM_EQ_GEQ_BAND2
0x6000004f   INTEGER1x7       24   0   -24   24   '125Hz'               PRM_EQ_GEQ_BAND3
0x60000050   INTEGER1x7       24   0   -24   24   '250Hz'               PRM_EQ_GEQ_BAND4
0x60000051   INTEGER1x7       24   0   -24   24   '500Hz'               PRM_EQ_GEQ_BAND5
0x60000052   INTEGER1x7       24   0   -24   24   '1KHz'                PRM_EQ_GEQ_BAND6
0x60000053   INTEGER1x7       24   0   -24   24   '2KHz'                PRM_EQ_GEQ_BAND7
0x60000054   INTEGER1x7       24   0   -24   24   '4KHz'                PRM_EQ_GEQ_BAND8
0x60000055   INTEGER1x7       24   0   -24   24   '8KHz'                PRM_EQ_GEQ_BAND9
0x60000056   INTEGER1x7       24   0   -24   24   '16KHz'               PRM_EQ_GEQ_BAND10
0x60000057   INTEGER1x7       24   0   -24   24   'LEVEL'               PRM_EQ_GEQ_LEVEL
CodeSmart
PART II
FX1
Out: F0 41 00 00 00 00 33 11 60 00 01 00 00 00 01 00 1E F7
In:  F0 41 00 00 00 00 33 12 60 00 01 00 00 23 01 01 32 23 23 00 32
     01 23 32 32 3C 00 32 00 64 00 64 64 00 00 32 32 32 32 00 00 1E
     0B 0A 1E 14 14 14 14 14 14 14 14 14 14 14 00 14 0D 01 14 17 01
     14 14 0E 14 00 32 32 32 32 2D 32 3C 00 28 1E 28 32 32 19 00 00
     3E 64 00 01 18 3C 00 00 46 01 18 28 00 00 46 00 64 01 0C 00 00
     46 07 00 00 50 00 64 18 18 18 18 18 18 18 18 18 18 18 18 18 18
     18 18 18 18 18 18 18 18 18 18 01 32 32 10 68 F7
0x60000100   INTEGER1x7   0   0   0   1   'SW'                 PRM_FX1_SW
0x60000101   INTEGER1x7   0   29   0   39   'TYPE'               PRM_FX1_FXTYPE
0x60000102   INTEGER1x7   0   1   0   1   'MODE'               PRM_FX1_TWAH_MODE
0x60000103   INTEGER1x7   0   1   0   1   'POLARITY'           PRM_FX1_TWAH_POLARITY
0x60000104   INTEGER1x7   0   50   0   100   'SENS'               PRM_FX1_TWAH_SENS
0x60000105   INTEGER1x7   0   35   0   100   'FREQ'               PRM_FX1_TWAH_FREQ
0x60000106   INTEGER1x7   0   35   0   100   'PEAK'               PRM_FX1_TWAH_PEAK
0x60000107   INTEGER1x7   0   0   0   100   'DIRECT MIX'         PRM_FX1_TWAH_D_LEVEL
0x60000108   INTEGER1x7   0   50   0   100   'EFFECT LEVEL'       PRM_FX1_TWAH_LEVEL
0x60000109   INTEGER1x7   0   1   0   1   'MODE'               PRM_FX1_AWAH_MODE
0x6000010a   INTEGER1x7   0   35   0   100   'FREQ'               PRM_FX1_AWAH_FREQ
0x6000010b   INTEGER1x7   0   50   0   100   'PEAK'               PRM_FX1_AWAH_PEAK
0x6000010c   INTEGER1x7   0   50   0   100   'RATE'               PRM_FX1_AWAH_RATE
0x6000010d   INTEGER1x7   0   60   0   100   'DEPTH'              PRM_FX1_AWAH_DEPTH
0x6000010e   INTEGER1x7   0   0   0   100   'DIRET MIX'          PRM_FX1_AWAH_D_LEVEL
0x6000010f   INTEGER1x7   0   50   0   100   'EFFECT LEVEL'       PRM_FX1_AWAH_LEVEL
0x60000110   INTEGER1x7   0   0   0   5   'TYPE'               PRM_FX1_SUBWAH_TYPE
0x60000111   INTEGER1x7   0   100   0   100   'PEDAL POS'          PRM_FX1_SUBWAH_PDLPOS
0x60000112   INTEGER1x7   0   0   0   100   'PEDAL MIN'          PRM_FX1_SUBWAH_MIN
0x60000113   INTEGER1x7   0   100   0   100   'PEDAL MAX'          PRM_FX1_SUBWAH_MAX
0x60000114   INTEGER1x7   0   100   0   100   'EFFECT LEVEL'       PRM_FX1_SUBWAH_E_LEVEL
0x60000115   INTEGER1x7   0   0   0   100   'DIRECT MIX'         PRM_FX1_SUBWAH_D_LEVEL
0x60000116   INTEGER1x7   0   0   0   6   'TYPE'               PRM_FX1_ADCOMP_TYPE
0x60000117   INTEGER1x7   0   50   0   100   'SUSTAIN'            PRM_FX1_ADCOMP_SUSTAIN
0x60000118   INTEGER1x7   0   50   0   100   'ATTACK'             PRM_FX1_ADCOMP_ATTACK
0x60000119   INTEGER1x7   50   0   -50   50   'TONE'               PRM_FX1_ADCOMP_TONE
0x6000011a   INTEGER1x7   0   50   0   100   'LEVEL'              PRM_FX1_ADCOMP_LEVEL
0x6000011b   INTEGER1x7   0   0   0   2   'TYPE'               PRM_FX1_LIMITER_TYPE
0x6000011c   INTEGER1x7   0   0   0   100   'ATTACK'             PRM_FX1_LIMITER_ATTACK
0x6000011d   INTEGER1x7   0   30   0   100   'THRESHOLD'          PRM_FX1_LIMITER_THRESHOLD
0x6000011e   INTEGER1x7   0   11   0   17   'RATIO'              PRM_FX1_LIMITER_RATIO
0x6000011f   INTEGER1x7   0   10   0   100   'RELEASE'            PRM_FX1_LIMITER_RELEASE
0x60000120   INTEGER1x7   0   30   0   100   'LEVEL'              PRM_FX1_LIMITER_LEVEL
0x60000121   INTEGER1x7   20   0   -20   20   '31Hz'               PRM_FX1_GEQ_BAND1
0x60000122   INTEGER1x7   20   0   -20   20   '62Hz'               PRM_FX1_GEQ_BAND2
0x60000123   INTEGER1x7   20   0   -20   20   '125Hz'              PRM_FX1_GEQ_BAND3
0x60000124   INTEGER1x7   20   0   -20   20   '250Hz'              PRM_FX1_GEQ_BAND4
0x60000125   INTEGER1x7   20   0   -20   20   '500Hz'              PRM_FX1_GEQ_BAND5
0x60000126   INTEGER1x7   20   0   -20   20   '1kHz'               PRM_FX1_GEQ_BAND6
0x60000127   INTEGER1x7   20   0   -20   20   '2kHz'               PRM_FX1_GEQ_BAND7
0x60000128   INTEGER1x7   20   0   -20   20   '4kHz'               PRM_FX1_GEQ_BAND8
0x60000129   INTEGER1x7   20   0   -20   20   '8kHz'               PRM_FX1_GEQ_BAND9
0x6000012a   INTEGER1x7   20   0   -20   20   '16kHz'              PRM_FX1_GEQ_BAND10
0x6000012b   INTEGER1x7   20   0   -20   20   'LEVEL'              PRM_FX1_GEQ_LEVEL
0x6000012c   INTEGER1x7   0   0   0   17   'LOW CUT'            PRM_FX1_PEQ_LOW_CUT
0x6000012d   INTEGER1x7   20   0   -20   20   'LOW GAIN'           PRM_FX1_PEQ_LOW_GAIN
0x6000012e   INTEGER1x7   0   13   0   27   'LOW-MID FREQ'       PRM_FX1_PEQ_LOWMID_FREQ
0x6000012f   INTEGER1x7   0   1   0   5   'LOW-MID Q'          PRM_FX1_PEQ_LOWMID_Q
0x60000130   INTEGER1x7   20   0   -20   20   'LOW-MID GAIN'       PRM_FX1_PEQ_LOWMID_GAIN
0x60000131   INTEGER1x7   0   23   0   27   'HIGH-MID FREQ'      PRM_FX1_PEQ_HIGHMID_FREQ
0x60000132   INTEGER1x7   0   1   0   5   'HIGH-MID Q'         PRM_FX1_PEQ_HIGHMID_Q
0x60000133   INTEGER1x7   20   0   -20   20   'HIGH-MID GAIN'      PRM_FX1_PEQ_HIGHMID_GAIN
0x60000134   INTEGER1x7   20   0   -20   20   'HIGH GAIN'          PRM_FX1_PEQ_HIGH_GAIN
0x60000135   INTEGER1x7   0   14   0   14   'HIGH CUT'           PRM_FX1_PEQ_HIGH_CUT
0x60000136   INTEGER1x7   20   0   -20   20   'LEVEL'              PRM_FX1_PEQ_LEVEL
0x60000137   INTEGER1x7   0   0   0   7   'TYPE'               PRM_FX1_GTRSIM_TYPE
0x60000138   INTEGER1x7   50   0   -50   50   'LOW'                PRM_FX1_GTRSIM_LOW
0x60000139   INTEGER1x7   50   0   -50   50   'HIGH'               PRM_FX1_GTRSIM_HIGH
0x6000013a   INTEGER1x7   0   50   0   100   'LEVEL'              PRM_FX1_GTRSIM_LEVEL
0x6000013b   INTEGER1x7   0   50   0   100   'BODY'               PRM_FX1_GTRSIM_BODY
0x6000013c   INTEGER1x7   0   45   0   100   'SENS'               PRM_FX1_SLOWGEAR_SENS
0x6000013d   INTEGER1x7   0   50   0   100   'RISE TIME'          PRM_FX1_SLOWGEAR_RISETIME
0x6000013e   INTEGER1x7   0   60   0   100   'LEVEL'              PRM_FX1_SLOWGEAR_LEVEL
0x6000013f   INTEGER1x7   0   0   0   1   'WAVE'               PRM_FX1_WAVESYN_WAVE
0x60000140   INTEGER1x7   0   40   0   100   'CUTOFF'             PRM_FX1_WAVESYN_CUTOFF
0x60000141   INTEGER1x7   0   30   0   100   'RESONANCE'          PRM_FX1_WAVESYN_RESONANCE
0x60000142   INTEGER1x7   0   40   0   100   'FILTER SENS'        PRM_FX1_WAVESYN_FLT_SENS
0x60000143   INTEGER1x7   0   50   0   100   'FILTER DECAY'       PRM_FX1_WAVESYN_FLT_DECAY
0x60000144   INTEGER1x7   0   50   0   100   'FILTER DEPTH'       PRM_FX1_WAVESYN_FLT_DEPTH
0x60000145   INTEGER1x7   0   25   0   100   'SYNTH LEVEL'        PRM_FX1_WAVESYN_SYN_LEVEL
0x60000146   INTEGER1x7   0   0   0   100   'DIRECT MIX'         PRM_FX1_WAVESYN_D_LEVEL
0x60000147   INTEGER1x7   0   0   0   3   'RANGE'              PRM_FX1_OCTAVE_RANGE
0x60000148   INTEGER1x7   0   62   0   100   'EFFECT LEVEL'       PRM_FX1_OCTAVE_LEVEL
0x60000149   INTEGER1x7   0   100   0   100   'DIRECT MIX'         PRM_FX1_OCTAVE_D_LEVEL
0x6000014a   INTEGER1x7   0   0   0   1   'VOICE'              PRM_FX1_PITCHSHIFT_VOICE
0x6000014b   INTEGER1x7   0   1   0   3   'PS1:MODE'           PRM_FX1_PITCHSHIFT_MODE1
0x6000014c   INTEGER1x7   24   0   -24   24   'PS1:PITCH'          PRM_FX1_PITCHSHIFT_PITCH1
0x6000014d   INTEGER1x7   50   10   -50   50   'PS1:FINE'           PRM_FX1_PITCHSHIFT_FINE1
0x6000014e   INTEGER2x7   0   0   0   300   'PS1:PRE DELAY'      PRM_FX1_PITCHSHIFT_PREDELAY1
0x60000150   INTEGER1x7   0   70   0   100   'PS1:LEVEL'          PRM_FX1_PITCHSHIFT_LEVEL1
0x60000151   INTEGER1x7   0   1   0   3   'PS2:MODE'           PRM_FX1_PITCHSHIFT_MODE2
0x60000152   INTEGER1x7   24   0   -24   24   'PS2:PITCH'          PRM_FX1_PITCHSHIFT_PITCH2
0x60000153   INTEGER1x7   50   -10   -50   50   'PS2:FINE'           PRM_FX1_PITCHSHIFT_FINE2
0x60000154   INTEGER2x7   0   0   0   300   'PS2:PRE DELAY'      PRM_FX1_PITCHSHIFT_PREDELAY2
0x60000156   INTEGER1x7   0   70   0   100   'PS2:LEVEL'          PRM_FX1_PITCHSHIFT_LEVEL2
0x60000157   INTEGER1x7   0   0   0   100   'PS1:FEEDBACK'       PRM_FX1_PITCHSHIFT_FEEDBACK
0x60000158   INTEGER1x7   0   100   0   100   'DIRECT MIX'         PRM_FX1_PITCHSHIFT_D_LEVEL
0x60000159   INTEGER1x7   0   1   0   1   'VOICE'              PRM_FX1_HARMONIST_VOICE
0x6000015a   INTEGER1x7   0   12   0   29   'HR1:HARMONY'        PRM_FX1_HARMONIST_HARMONY1
0x6000015b   INTEGER2x7   0   0   0   300   'HR1:PRE DELAY'      PRM_FX1_HARMONIST_PREDELAY1
0x6000015d   INTEGER1x7   0   70   0   100   'HR1:LEVEL'          PRM_FX1_HARMONIST_LEVEL1
0x6000015e   INTEGER1x7   0   7   0   29   'HR2:HARMONY'        PRM_FX1_HARMONIST_HARMONY2
0x6000015f   INTEGER2x7   0   0   0   300   'HR2:PREDELAY'       PRM_FX1_HARMONIST_PREDELAY2
0x60000161   INTEGER1x7   0   80   0   100   'HR2:LEVEL'          PRM_FX1_HARMONIST_LEVEL2
0x60000162   INTEGER1x7   0   0   0   100   'HR1:FEEDBACK'       PRM_FX1_HARMONIST_FEEDBACK
0x60000163   INTEGER1x7   0   100   0   100   'DIRECT MIX'         PRM_FX1_HARMONIST_D_LEVEL
0x60000164   INTEGER1x7   24   0   -24   24   'HR1:C'              PRM_FX1_HARMONIST_V1_HARM_1
0x60000165   INTEGER1x7   24   0   -24   24   'HR1:Db'             PRM_FX1_HARMONIST_V1_HARM_2
0x60000166   INTEGER1x7   24   0   -24   24   'HR1:D'              PRM_FX1_HARMONIST_V1_HARM_3
0x60000167   INTEGER1x7   24   0   -24   24   'HR1:Eb'             PRM_FX1_HARMONIST_V1_HARM_4
0x60000168   INTEGER1x7   24   0   -24   24   'HR1:E'              PRM_FX1_HARMONIST_V1_HARM_5
0x60000169   INTEGER1x7   24   0   -24   24   'HR1:F'              PRM_FX1_HARMONIST_V1_HARM_6
0x6000016a   INTEGER1x7   24   0   -24   24   'HR1:F#'             PRM_FX1_HARMONIST_V1_HARM_7
0x6000016b   INTEGER1x7   24   0   -24   24   'HR1:G'              PRM_FX1_HARMONIST_V1_HARM_8
0x6000016c   INTEGER1x7   24   0   -24   24   'HR1:Ab'             PRM_FX1_HARMONIST_V1_HARM_9
0x6000016d   INTEGER1x7   24   0   -24   24   'HR1:A'              PRM_FX1_HARMONIST_V1_HARM_10
0x6000016e   INTEGER1x7   24   0   -24   24   'HR1:Bb'             PRM_FX1_HARMONIST_V1_HARM_11
0x6000016f   INTEGER1x7   24   0   -24   24   'HR1:B'              PRM_FX1_HARMONIST_V1_HARM_12
0x60000170   INTEGER1x7   24   0   -24   24   'HR2:C'              PRM_FX1_HARMONIST_V2_HARM_1
0x60000171   INTEGER1x7   24   0   -24   24   'HR2:Db'             PRM_FX1_HARMONIST_V2_HARM_2
0x60000172   INTEGER1x7   24   0   -24   24   'HR2:D'              PRM_FX1_HARMONIST_V2_HARM_3
0x60000173   INTEGER1x7   24   0   -24   24   'HR2:Eb'             PRM_FX1_HARMONIST_V2_HARM_4
0x60000174   INTEGER1x7   24   0   -24   24   'HR2:E'              PRM_FX1_HARMONIST_V2_HARM_5
0x60000175   INTEGER1x7   24   0   -24   24   'HR2:F'              PRM_FX1_HARMONIST_V2_HARM_6
0x60000176   INTEGER1x7   24   0   -24   24   'HR2:F#'             PRM_FX1_HARMONIST_V2_HARM_7
0x60000177   INTEGER1x7   24   0   -24   24   'HR2:G'              PRM_FX1_HARMONIST_V2_HARM_8
0x60000178   INTEGER1x7   24   0   -24   24   'HR2:Ab'             PRM_FX1_HARMONIST_V2_HARM_9
0x60000179   INTEGER1x7   24   0   -24   24   'HR2:A'              PRM_FX1_HARMONIST_V2_HARM_10
0x6000017a   INTEGER1x7   24   0   -24   24   'HR2:Bb'             PRM_FX1_HARMONIST_V2_HARM_11
0x6000017b   INTEGER1x7   24   0   -24   24   'HR2:B'              PRM_FX1_HARMONIST_V2_HARM_12
0x6000017c   INTEGER1x7   0   1   0   3   'TYPE'               PRM_FX1_ACPROCESS_TYPE
0x6000017d   INTEGER1x7   50   0   -50   50   'BASS'               PRM_FX1_ACPROCESS_BASS
0x6000017e   INTEGER1x7   50   0   -50   50   'MIDDLE'             PRM_FX1_ACPROCESS_MID
0x6000017f   INTEGER1x7   0   16   0   27   'MIDDLE FREQ'        PRM_FX1_ACPROCESS_MID_F
Out: F0 41 00 00 00 00 33 11 60 00 02 00 00 00 00 5D 41 F7
In:  F0 41 00 00 00 00 33 12 60 00 02 00 32 32 32 00 46 28 37 00 00
     64 00 1F 28 52 32 00 00 3C 00 46 55 41 32 01 1E 55 00 00 3C 32
     46 3C 64 00 32 32 32 00 50 2D 01 00 32 00 32 64 64 01 00 02 32
     50 64 32 64 04 2B 2E 03 4B 21 30 03 41 50 32 32 32 32 32 01 1F
     2D 32 32 50 64 00 64 64 00 00 32 32 03 10 32 64 32 00 64 00 64
     25 F7 00
0x60000200   INTEGER1x7   50   0   -50   50   'TREBLE'             PRM_FX1_ACPROCESS_TREBLE
0x60000201   INTEGER1x7   50   0   -50   50   'PRESENCE'           PRM_FX1_ACPROCESS_PRESENCE
0x60000202   INTEGER1x7   0   50   0   100   'LEVEL'              PRM_FX1_ACPROCESS_LEVEL
0x60000203   INTEGER1x7   0   0   0   3   'TYPE'               PRM_FX1_PHASER_TYPE
0x60000204   INTEGER1x7   0   70   0   100   'RATE'               PRM_FX1_PHASER_RATE
0x60000205   INTEGER1x7   0   40   0   100   'DEPTH'              PRM_FX1_PHASER_DEPTH
0x60000206   INTEGER1x7   0   55   0   100   'MANUAL'             PRM_FX1_PHASER_MANUAL
0x60000207   INTEGER1x7   0   0   0   100   'RESONANCE'          PRM_FX1_PHASER_RESONANCE
0x60000208   INTEGER1x7   1   -1   -1   100   'STEP RATE'          PRM_FX1_PHASER_STEPRATE
0x60000209   INTEGER1x7   0   100   0   100   'EFFECT LEVEL'       PRM_FX1_PHASER_E_LEVEL
0x6000020a   INTEGER1x7   0   0   0   100   'DIRECT MIX'         PRM_FX1_PHASER_D_LEVEL
0x6000020b   INTEGER1x7   0   31   0   100   'RATE'               PRM_FX1_FLANGER_RATE
0x6000020c   INTEGER1x7   0   40   0   100   'DEPTH'              PRM_FX1_FLANGER_DEPTH
0x6000020d   INTEGER1x7   0   82   0   100   'MANUAL'             PRM_FX1_FLANGER_MANUAL
0x6000020e   INTEGER1x7   0   50   0   100   'RESONANCE'          PRM_FX1_FLANGER_RESONANCE
0x6000020f   INTEGER1x7   0   0   0   0   ''
0x60000210   INTEGER1x7   0   0   0   10   'LOW CUT'            PRM_FX1_FLANGER_LOWCUT
0x60000211   INTEGER1x7   0   60   0   100   'EFFECT LEVEL'       PRM_FX1_FLANGER_E_LEVEL
0x60000212   INTEGER1x7   0   0   0   100   'DIRECT MIX'         PRM_FX1_FLANGER_D_LEVEL
0x60000213   INTEGER1x7   0   70   0   100   'WAVE SHAPE'         PRM_FX1_TREMOLO_WAVESHAPE
0x60000214   INTEGER1x7   0   85   0   100   'RATE'               PRM_FX1_TREMOLO_RATE
0x60000215   INTEGER1x7   0   65   0   100   'DEPTH'              PRM_FX1_TREMOLO_DEPTH
0x60000216   INTEGER1x7   0   50   0   100   'LEVEL'              PRM_FX1_TREMOLO_LEVEL
0x60000217   INTEGER1x7   0   1   1   1   ''
0x60000218   INTEGER1x7   0   30   0   100   ''
0x60000219   INTEGER1x7   0   85   0   100   'RATE'               PRM_FX1_ROTARY_RATE_FAST
0x6000021a   INTEGER1x7   0   0   0   0   ''
0x6000021b   INTEGER1x7   0   0   0   0   ''
0x6000021c   INTEGER1x7   0   60   0   100   'DEPTH'              PRM_FX1_ROTARY_DEPTH
0x6000021d   INTEGER1x7   0   50   0   100   'LEVEL'              PRM_FX1_ROTARY_LEVEL
0x6000021e   INTEGER1x7   0   70   0   100   'RATE'               PRM_FX1_UNI_V_RATE
0x6000021f   INTEGER1x7   0   60   0   100   'DEPTH'              PRM_FX1_UNI_V_DEPTH
0x60000220   INTEGER1x7   0   100   0   100   'LEVEL'              PRM_FX1_UNI_V_LEVEL
0x60000221   INTEGER1x7   0   0   0   19   'PATTERN'            PRM_FX1_SLICER_PATTERN
0x60000222   INTEGER1x7   0   50   0   100   'RATE'               PRM_FX1_SLICER_RATE
0x60000223   INTEGER1x7   0   50   0   100   'TRIGGER SENS'       PRM_FX1_SLICER_TRIGSENS
0x60000224   INTEGER1x7   0   50   0   100   'EFFECT LEVEL'       PRM_FX1_SLICER_EFFECT_LEVEL
0x60000225   INTEGER1x7   0   0   0   100   'DIRECT MIX'         PRM_FX1_SLICER_DIRECT_LEVEL
0x60000226   INTEGER1x7   0   80   0   100   'RATE'               PRM_FX1_VIBRATO_RATE
0x60000227   INTEGER1x7   0   45   0   100   'DEPTH'              PRM_FX1_VIBRATO_DEPTH
0x60000228   INTEGER1x7   0   1   1   1   ''
0x60000229   INTEGER1x7   0   0   0   0   ''
0x6000022a   INTEGER1x7   0   50   0   100   'LEVEL'              PRM_FX1_VIBRATO_LEVEL
0x6000022b   INTEGER1x7   0   0   0   1   'MODE'               PRM_FX1_RINGMOD_MODE
0x6000022c   INTEGER1x7   0   50   0   100   'FREQUENCY'          PRM_FX1_RINGMOD_FREQ
0x6000022d   INTEGER1x7   0   100   0   100   'EFFECT LEVEL'       PRM_FX1_RINGMOD_E_LEVEL
0x6000022e   INTEGER1x7   0   100   0   100   'DIRECT MIX'         PRM_FX1_RINGMOD_D_LEVEL
0x6000022f   INTEGER1x7   0   1   0   1   'MODE'               PRM_FX1_HUMANIZER_MODE
0x60000230   INTEGER1x7   0   0   0   4   'VOWEL1'             PRM_FX1_HUMANIZER_VOWEL1
0x60000231   INTEGER1x7   0   2   0   4   'VOWEL2'             PRM_FX1_HUMANIZER_VOWEL2
0x60000232   INTEGER1x7   0   50   0   100   'SENS'               PRM_FX1_HUMANIZER_SENS
0x60000233   INTEGER1x7   0   80   0   100   'RATE'               PRM_FX1_HUMANIZER_RATE
0x60000234   INTEGER1x7   0   100   0   100   'DEPTH'              PRM_FX1_HUMANIZER_DEPTH
0x60000235   INTEGER1x7   0   50   0   100   'MANUAL'             PRM_FX1_HUMANIZER_MANUAL
0x60000236   INTEGER1x7   0   100   0   100   'LEVEL'              PRM_FX1_HUMANIZER_LEVEL
0x60000237   INTEGER1x7   0   4   0   16   'XOVER FREQUENCY'    PRM_FX1_2x2CHORUS_XOVERF
0x60000238   INTEGER1x7   0   43   0   100   'LOW RATE'           PRM_FX1_2x2CHORUS_LOW_RATE
0x60000239   INTEGER1x7   0   46   0   100   'LOW DEPTH'          PRM_FX1_2x2CHORUS_LOW_DEPTH
0x6000023a   INTEGER1x7   0   3   0   80   'LOW PRE DELAY'      PRM_FX1_2x2CHORUS_LOW_PREDELAY
0x6000023b   INTEGER1x7   0   75   0   100   'LOW LEVEL'          PRM_FX1_2x2CHORUS_LOW_LEVEL
0x6000023c   INTEGER1x7   0   33   0   100   'HIGH RATE'          PRM_FX1_2x2CHORUS_HIGH_RATE
0x6000023d   INTEGER1x7   0   48   0   100   'HIGH DEPTH'         PRM_FX1_2x2CHORUS_HIGH_DEPTH
0x6000023e   INTEGER1x7   0   3   0   80   'HIGH PRE DELAY'     PRM_FX1_2x2CHORUS_HIGH_PREDELAY
0x6000023f   INTEGER1x7   0   65   0   100   'HIGH LEVEL'         PRM_FX1_2x2CHORUS_HIGH_LEVEL
0x60000240   INTEGER1x7   0   80   0   100   'DIRECT MIX'         PRM_FX1_2x2CHORUS_DIRECT_LEVEL
0x60000241   INTEGER1x7   50   0   -50   50   'HIGH'               PRM_FX1_ACSIM_TOP
0x60000242   INTEGER1x7   0   50   0   100   'BODY'               PRM_FX1_ACSIM_BODY
0x60000243   INTEGER1x7   50   0   -50   50   'LOW'                PRM_FX1_ACSIM_LOW
0x60000244   INTEGER1x7   50   0   -50   50   ''
0x60000245   INTEGER1x7   0   50   0   100   'LEVEL'              PRM_FX1_ACSIM_LEVEL
0x60000246   INTEGER1x7   0   1   0   1   'SCRIPT'             PRM_FX1_EVH_PHASER_SCRIPT
0x60000247   INTEGER1x7   0   50   0   100   'SPEED'              PRM_FX1_EVH_PHASER_SPEED
0x60000248   INTEGER1x7   0   45   0   100   'MANUAL'             PRM_FX1_EVH_FLANGER_MANUAL
0x60000249   INTEGER1x7   0   50   0   100   'WIDTH'              PRM_FX1_EVH_FLANGER_WIDTH
0x6000024a   INTEGER1x7   0   50   0   100   'SPEED'              PRM_FX1_EVH_FLANGER_SPEED
0x6000024b   INTEGER1x7   0   80   0   100   'REGEN.'             PRM_FX1_EVH_FLANGER_REGEN
0x6000024c   INTEGER1x7   0   100   0   100   'PEDAL POS'          PRM_FX1_EVH_WAH_PEDAL_POS
0x6000024d   INTEGER1x7   0   0   0   100   'PEDAL MIN'          PRM_FX1_EVH_WAH_PEDAL_MIN
0x6000024e   INTEGER1x7   0   100   0   100   'PEDAL MAX'          PRM_FX1_EVH_WAH_PEDAL_MAX
0x6000024f   INTEGER1x7   0   100   0   100   'EFFECT LEVEL'       PRM_FX1_EVH_WAH_EFFECT_LEVEL
0x60000250   INTEGER1x7   0   0   0   100   'DIRECT MIX'         PRM_FX1_EVH_WAH_DIRECT_MIX
0x60000251   INTEGER1x7   0   0   0   1   'SELECT'             PRM_FX1_DC30_SELECTOR
0x60000252   INTEGER1x7   0   50   0   100   'INPUT VOLUME'       PRM_FX1_DC30_INPUT_VOLUME
0x60000253   INTEGER1x7   0   50   0   100   'CHORUS INTENSITY'   PRM_FX1_DC30_CHORUS_INTENSITY
0x60000254   INTEGER2x7   0   400   40   600   'ECHO REPEAT RATE'   PRM_FX1_DC30_ECHO_REPEAT_RATE
0x60000256   INTEGER1x7   0   50   0   100   'ECHO INTENSISTY'    PRM_FX1_DC30_ECHO_INTENSITY
0x60000257   INTEGER1x7   0   100   0   100   'ECHO VOLUME'        PRM_FX1_DC30_ECHO_VOLUME
0x60000258   INTEGER1x7   0   50   0   100   'TONE'               PRM_FX1_DC30_TONE
0x60000259   INTEGER1x7   0   0   0   1   'OUTPUT'             PRM_FX1_DC30_OUTPUT
0x6000025a   INTEGER1x7   0   50   0   100   '1OCT LEVEL'         PRM_FX1_HEAVY_OCTAVE_1OCT_LEVEL
0x6000025b   INTEGER1x7   0   0   0   100   '2OCT LEVEL'         PRM_FX1_HEAVY_OCTAVE_2OCT_LEVEL
0x6000025c   INTEGER1x7   0   100   0   100   'DIRECT MIX'         PRM_FX1_HEAVY_OCTAVE_DIRECT_LEVEL
CodeSmart
PART III
FX2
Out: F0 41 00 00 00 00 33 11 60 00 03 00 00 00 01 00 1C F7
In:  F0 41 00 00 00 00 33 12 60 00 03 00 00 27 01 01 32 23 04 23 00 32
     01 23 32 32 3C 00 32 00 64 00 64 64 00 00 32 32 32 32 04 00 00 1E
     0B 0A 1E 14 14 14 14 14 14 14 14 14 14 14 00 14 0D 01 04 14 17 01
     14 14 0E 14 00 32 32 32 32 2D 32 3C 00 28 1E 28 32 32 04 19 00 00
     3E 64 00 01 18 3C 00 00 46 01 18 28 00 00 46 00 64 01 04 0C 00 00
     46 07 00 00 50 00 64 18 18 18 18 18 18 18 18 18 18 18 04 18 18 18
     18 18 18 18 18 18 18 18 18 18 01 32 32 10 62 F7
0x60000300   INTEGER1x7   0   0   0   1   'SW'                 PRM_FX2_SW
0x60000301   INTEGER1x7   0   29   0   39   'TYPE'               PRM_FX2_FXTYPE
0x60000302   INTEGER1x7   0   1   0   1   'MODE'               PRM_FX2_TWAH_MODE
0x60000303   INTEGER1x7   0   1   0   1   'POLARITY'           PRM_FX2_TWAH_POLARITY
0x60000304   INTEGER1x7   0   50   0   100   'SENS'               PRM_FX2_TWAH_SENS
0x60000305   INTEGER1x7   0   35   0   100   'FREQ'               PRM_FX2_TWAH_FREQ
0x60000306   INTEGER1x7   0   35   0   100   'PEAK'               PRM_FX2_TWAH_PEAK
0x60000307   INTEGER1x7   0   0   0   100   'DIRECT MIX'         PRM_FX2_TWAH_D_LEVEL
0x60000308   INTEGER1x7   0   50   0   100   'EFFECT LEVEL'       PRM_FX2_TWAH_LEVEL
0x60000309   INTEGER1x7   0   1   0   1   'MODE'               PRM_FX2_AWAH_MODE
0x6000030a   INTEGER1x7   0   35   0   100   'FREQ'               PRM_FX2_AWAH_FREQ
0x6000030b   INTEGER1x7   0   50   0   100   'PEAK'               PRM_FX2_AWAH_PEAK
0x6000030c   INTEGER1x7   0   50   0   100   'RATE'               PRM_FX2_AWAH_RATE
0x6000030d   INTEGER1x7   0   60   0   100   'DEPTH'              PRM_FX2_AWAH_DEPTH
0x6000030e   INTEGER1x7   0   0   0   100   'DIRET MIX'          PRM_FX2_AWAH_D_LEVEL
0x6000030f   INTEGER1x7   0   50   0   100   'EFFECT LEVEL'       PRM_FX2_AWAH_LEVEL
0x60000310   INTEGER1x7   0   0   0   5   'TYPE'               PRM_FX2_SUBWAH_TYPE
0x60000311   INTEGER1x7   0   100   0   100   'PEDAL POS'          PRM_FX2_SUBWAH_PDLPOS
0x60000312   INTEGER1x7   0   0   0   100   'PEDAL MIN'          PRM_FX2_SUBWAH_MIN
0x60000313   INTEGER1x7   0   100   0   100   'PEDAL MAX'          PRM_FX2_SUBWAH_MAX
0x60000314   INTEGER1x7   0   100   0   100   'EFFECT LEVEL'       PRM_FX2_SUBWAH_E_LEVEL
0x60000315   INTEGER1x7   0   0   0   100   'DIRECT MIX'         PRM_FX2_SUBWAH_D_LEVEL
0x60000316   INTEGER1x7   0   0   0   6   'TYPE'               PRM_FX2_ADCOMP_TYPE
0x60000317   INTEGER1x7   0   50   0   100   'SUSTAIN'            PRM_FX2_ADCOMP_SUSTAIN
0x60000318   INTEGER1x7   0   50   0   100   'ATTACK'             PRM_FX2_ADCOMP_ATTACK
0x60000319   INTEGER1x7   50   0   -50   50   'TONE'               PRM_FX2_ADCOMP_TONE
0x6000031a   INTEGER1x7   0   50   0   100   'LEVEL'              PRM_FX2_ADCOMP_LEVEL
0x6000031b   INTEGER1x7   0   0   0   2   'TYPE'               PRM_FX2_LIMITER_TYPE
0x6000031c   INTEGER1x7   0   0   0   100   'ATTACK'             PRM_FX2_LIMITER_ATTACK
0x6000031d   INTEGER1x7   0   30   0   100   'THRESHOLD'          PRM_FX2_LIMITER_THRESHOLD
0x6000031e   INTEGER1x7   0   11   0   17   'RATIO'              PRM_FX2_LIMITER_RATIO
0x6000031f   INTEGER1x7   0   10   0   100   'RELEASE'            PRM_FX2_LIMITER_RELEASE
0x60000320   INTEGER1x7   0   30   0   100   'LEVEL'              PRM_FX2_LIMITER_LEVEL
0x60000321   INTEGER1x7   20   0   -20   20   '31Hz'               PRM_FX2_GEQ_BAND1
0x60000322   INTEGER1x7   20   0   -20   20   '62Hz'               PRM_FX2_GEQ_BAND2
0x60000323   INTEGER1x7   20   0   -20   20   '125Hz'              PRM_FX2_GEQ_BAND3
0x60000324   INTEGER1x7   20   0   -20   20   '250Hz'              PRM_FX2_GEQ_BAND4
0x60000325   INTEGER1x7   20   0   -20   20   '500Hz'              PRM_FX2_GEQ_BAND5
0x60000326   INTEGER1x7   20   0   -20   20   '1kHz'               PRM_FX2_GEQ_BAND6
0x60000327   INTEGER1x7   20   0   -20   20   '2kHz'               PRM_FX2_GEQ_BAND7
0x60000328   INTEGER1x7   20   0   -20   20   '4kHz'               PRM_FX2_GEQ_BAND8
0x60000329   INTEGER1x7   20   0   -20   20   '8kHz'               PRM_FX2_GEQ_BAND9
0x6000032a   INTEGER1x7   20   0   -20   20   '16kHz'              PRM_FX2_GEQ_BAND10
0x6000032b   INTEGER1x7   20   0   -20   20   'LEVEL'              PRM_FX2_GEQ_LEVEL
0x6000032c   INTEGER1x7   0   0   0   17   'LOW CUT'            PRM_FX2_PEQ_LOW_CUT
0x6000032d   INTEGER1x7   20   0   -20   20   'LOW GAIN'           PRM_FX2_PEQ_LOW_GAIN
0x6000032e   INTEGER1x7   0   13   0   27   'LOW-MID FREQ'       PRM_FX2_PEQ_LOWMID_FREQ
0x6000032f   INTEGER1x7   0   1   0   5   'LOW-MID Q'          PRM_FX2_PEQ_LOWMID_Q
0x60000330   INTEGER1x7   20   0   -20   20   'LOW-MID GAIN'       PRM_FX2_PEQ_LOWMID_GAIN
0x60000331   INTEGER1x7   0   23   0   27   'HIGH-MID FREQ'      PRM_FX2_PEQ_HIGHMID_FREQ
0x60000332   INTEGER1x7   0   1   0   5   'HIGH-MID Q'         PRM_FX2_PEQ_HIGHMID_Q
0x60000333   INTEGER1x7   20   0   -20   20   'HIGH-MID GAIN'      PRM_FX2_PEQ_HIGHMID_GAIN
0x60000334   INTEGER1x7   20   0   -20   20   'HIGH GAIN'          PRM_FX2_PEQ_HIGH_GAIN
0x60000335   INTEGER1x7   0   14   0   14   'HIGH CUT'           PRM_FX2_PEQ_HIGH_CUT
0x60000336   INTEGER1x7   20   0   -20   20   'LEVEL'              PRM_FX2_PEQ_LEVEL
0x60000337   INTEGER1x7   0   0   0   7   'TYPE'               PRM_FX2_GTRSIM_TYPE
0x60000338   INTEGER1x7   50   0   -50   50   'LOW'                PRM_FX2_GTRSIM_LOW
0x60000339   INTEGER1x7   50   0   -50   50   'HIGH'               PRM_FX2_GTRSIM_HIGH
0x6000033a   INTEGER1x7   0   50   0   100   'LEVEL'              PRM_FX2_GTRSIM_LEVEL
0x6000033b   INTEGER1x7   0   50   0   100   'BODY'               PRM_FX2_GTRSIM_BODY
0x6000033c   INTEGER1x7   0   45   0   100   'SENS'               PRM_FX2_SLOWGEAR_SENS
0x6000033d   INTEGER1x7   0   50   0   100   'RISE TIME'          PRM_FX2_SLOWGEAR_RISETIME
0x6000033e   INTEGER1x7   0   60   0   100   'LEVEL'              PRM_FX2_SLOWGEAR_LEVEL
0x6000033f   INTEGER1x7   0   0   0   1   'WAVE'               PRM_FX2_WAVESYN_WAVE
0x60000340   INTEGER1x7   0   40   0   100   'CUTOFF'             PRM_FX2_WAVESYN_CUTOFF
0x60000341   INTEGER1x7   0   30   0   100   'RESONANCE'          PRM_FX2_WAVESYN_RESONANCE
0x60000342   INTEGER1x7   0   40   0   100   'FILTER SENS'        PRM_FX2_WAVESYN_FLT_SENS
0x60000343   INTEGER1x7   0   50   0   100   'FILTER DECAY'       PRM_FX2_WAVESYN_FLT_DECAY
0x60000344   INTEGER1x7   0   50   0   100   'FILTER DEPTH'       PRM_FX2_WAVESYN_FLT_DEPTH
0x60000345   INTEGER1x7   0   25   0   100   'SYNTH LEVEL'        PRM_FX2_WAVESYN_SYN_LEVEL
0x60000346   INTEGER1x7   0   0   0   100   'DIRECT MIX'         PRM_FX2_WAVESYN_D_LEVEL
0x60000347   INTEGER1x7   0   0   0   3   'RANGE'              PRM_FX2_OCTAVE_RANGE
0x60000348   INTEGER1x7   0   62   0   100   'EFFECT LEVEL'       PRM_FX2_OCTAVE_LEVEL
0x60000349   INTEGER1x7   0   100   0   100   'DIRECT MIX'         PRM_FX2_OCTAVE_D_LEVEL
0x6000034a   INTEGER1x7   0   0   0   1   'VOICE'              PRM_FX2_PITCHSHIFT_VOICE
0x6000034b   INTEGER1x7   0   1   0   3   'PS1:MODE'           PRM_FX2_PITCHSHIFT_MODE1
0x6000034c   INTEGER1x7   24   0   -24   24   'PS1:PITCH'          PRM_FX2_PITCHSHIFT_PITCH1
0x6000034d   INTEGER1x7   50   10   -50   50   'PS1:FINE'           PRM_FX2_PITCHSHIFT_FINE1
0x6000034e   INTEGER2x7   0   0   0   300   'PS1:PRE DELAY'      PRM_FX2_PITCHSHIFT_PREDELAY1
0x60000350   INTEGER1x7   0   70   0   100   'PS1:LEVEL'          PRM_FX2_PITCHSHIFT_LEVEL1
0x60000351   INTEGER1x7   0   1   0   3   'PS2:MODE'           PRM_FX2_PITCHSHIFT_MODE2
0x60000352   INTEGER1x7   24   0   -24   24   'PS2:PITCH'          PRM_FX2_PITCHSHIFT_PITCH2
0x60000353   INTEGER1x7   50   -10   -50   50   'PS2:FINE'           PRM_FX2_PITCHSHIFT_FINE2
0x60000354   INTEGER2x7   0   0   0   300   'PS2:PRE DELAY'      PRM_FX2_PITCHSHIFT_PREDELAY2
0x60000356   INTEGER1x7   0   70   0   100   'PS2:LEVEL'          PRM_FX2_PITCHSHIFT_LEVEL2
0x60000357   INTEGER1x7   0   0   0   100   'PS1:FEEDBACK'       PRM_FX2_PITCHSHIFT_FEEDBACK
0x60000358   INTEGER1x7   0   100   0   100   'DIRECT MIX'         PRM_FX2_PITCHSHIFT_D_LEVEL
0x60000359   INTEGER1x7   0   1   0   1   'VOICE'              PRM_FX2_HARMONIST_VOICE
0x6000035a   INTEGER1x7   0   12   0   29   'HR1:HARMONY'        PRM_FX2_HARMONIST_HARMONY1
0x6000035b   INTEGER2x7   0   0   0   300   'HR1:PRE DELAY'      PRM_FX2_HARMONIST_PREDELAY1
0x6000035d   INTEGER1x7   0   70   0   100   'HR1:LEVEL'          PRM_FX2_HARMONIST_LEVEL1
0x6000035e   INTEGER1x7   0   7   0   29   'HR2:HARMONY'        PRM_FX2_HARMONIST_HARMONY2
0x6000035f   INTEGER2x7   0   0   0   300   'HR2:PREDELAY'       PRM_FX2_HARMONIST_PREDELAY2
0x60000361   INTEGER1x7   0   80   0   100   'HR2:LEVEL'          PRM_FX2_HARMONIST_LEVEL2
0x60000362   INTEGER1x7   0   0   0   100   'HR1:FEEDBACK'       PRM_FX2_HARMONIST_FEEDBACK
0x60000363   INTEGER1x7   0   100   0   100   'DIRECT MIX'         PRM_FX2_HARMONIST_D_LEVEL
0x60000364   INTEGER1x7   24   0   -24   24   'HR1:C'              PRM_FX2_HARMONIST_V1_HARM_1
0x60000365   INTEGER1x7   24   0   -24   24   'HR1:Db'             PRM_FX2_HARMONIST_V1_HARM_2
0x60000366   INTEGER1x7   24   0   -24   24   'HR1:D'              PRM_FX2_HARMONIST_V1_HARM_3
0x60000367   INTEGER1x7   24   0   -24   24   'HR1:Eb'             PRM_FX2_HARMONIST_V1_HARM_4
0x60000368   INTEGER1x7   24   0   -24   24   'HR1:E'              PRM_FX2_HARMONIST_V1_HARM_5
0x60000369   INTEGER1x7   24   0   -24   24   'HR1:F'              PRM_FX2_HARMONIST_V1_HARM_6
0x6000036a   INTEGER1x7   24   0   -24   24   'HR1:F#'             PRM_FX2_HARMONIST_V1_HARM_7
0x6000036b   INTEGER1x7   24   0   -24   24   'HR1:G'              PRM_FX2_HARMONIST_V1_HARM_8
0x6000036c   INTEGER1x7   24   0   -24   24   'HR1:Ab'             PRM_FX2_HARMONIST_V1_HARM_9
0x6000036d   INTEGER1x7   24   0   -24   24   'HR1:A'              PRM_FX2_HARMONIST_V1_HARM_10
0x6000036e   INTEGER1x7   24   0   -24   24   'HR1:Bb'             PRM_FX2_HARMONIST_V1_HARM_11
0x6000036f   INTEGER1x7   24   0   -24   24   'HR1:B'              PRM_FX2_HARMONIST_V1_HARM_12
0x60000370   INTEGER1x7   24   0   -24   24   'HR2:C'              PRM_FX2_HARMONIST_V2_HARM_1
0x60000371   INTEGER1x7   24   0   -24   24   'HR2:Db'             PRM_FX2_HARMONIST_V2_HARM_2
0x60000372   INTEGER1x7   24   0   -24   24   'HR2:D'              PRM_FX2_HARMONIST_V2_HARM_3
0x60000373   INTEGER1x7   24   0   -24   24   'HR2:Eb'             PRM_FX2_HARMONIST_V2_HARM_4
0x60000374   INTEGER1x7   24   0   -24   24   'HR2:E'              PRM_FX2_HARMONIST_V2_HARM_5
0x60000375   INTEGER1x7   24   0   -24   24   'HR2:F'              PRM_FX2_HARMONIST_V2_HARM_6
0x60000376   INTEGER1x7   24   0   -24   24   'HR2:F#'             PRM_FX2_HARMONIST_V2_HARM_7
0x60000377   INTEGER1x7   24   0   -24   24   'HR2:G'              PRM_FX2_HARMONIST_V2_HARM_8
0x60000378   INTEGER1x7   24   0   -24   24   'HR2:Ab'             PRM_FX2_HARMONIST_V2_HARM_9
0x60000379   INTEGER1x7   24   0   -24   24   'HR2:A'              PRM_FX2_HARMONIST_V2_HARM_10
0x6000037a   INTEGER1x7   24   0   -24   24   'HR2:Bb'             PRM_FX2_HARMONIST_V2_HARM_11
0x6000037b   INTEGER1x7   24   0   -24   24   'HR2:B'              PRM_FX2_HARMONIST_V2_HARM_12
0x6000037c   INTEGER1x7   0   1   0   3   'TYPE'               PRM_FX2_ACPROCESS_TYPE
0x6000037d   INTEGER1x7   50   0   -50   50   'BASS'               PRM_FX2_ACPROCESS_BASS
0x6000037e   INTEGER1x7   50   0   -50   50   'MIDDLE'             PRM_FX2_ACPROCESS_MID
0x6000037f   INTEGER1x7   0   16   0   27   'MIDDLE FREQ'        PRM_FX2_ACPROCESS_MID_F
Out: F0 41 00 00 00 00 33 11 60 00 04 00 00 00 00 5D 3F F7
In:  F0 41 00 00 00 00 33 12 60 00 04 00 32 32 32 00 46 28 37 00 00
     50 64 32 64 04 2B 2E 03 4B 21 30 03 41 50 32 32 32 32 32 01 32
     2D 32 32 50 64 00 64 64 00 00 32 32 03 10 32 64 32 00 00 00 64
     74 F7
0x60000400   INTEGER1x7   50   0   -50   50   'TREBLE'             PRM_FX2_ACPROCESS_TREBLE
0x60000401   INTEGER1x7   50   0   -50   50   'PRESENCE'           PRM_FX2_ACPROCESS_PRESENCE
0x60000402   INTEGER1x7   0   50   0   100   'LEVEL'              PRM_FX2_ACPROCESS_LEVEL
0x60000403   INTEGER1x7   0   0   0   3   'TYPE'               PRM_FX2_PHASER_TYPE
0x60000404   INTEGER1x7   0   70   0   100   'RATE'               PRM_FX2_PHASER_RATE
0x60000405   INTEGER1x7   0   40   0   100   'DEPTH'              PRM_FX2_PHASER_DEPTH
0x60000406   INTEGER1x7   0   55   0   100   'MANUAL'             PRM_FX2_PHASER_MANUAL
0x60000407   INTEGER1x7   0   0   0   100   'RESONANCE'          PRM_FX2_PHASER_RESONANCE
0x60000408   INTEGER1x7   1   -1   -1   100   'STEP RATE'          PRM_FX2_PHASER_STEPRATE
0x60000409   INTEGER1x7   0   100   0   100   'EFFECT LEVEL'       PRM_FX2_PHASER_E_LEVEL
0x6000040a   INTEGER1x7   0   0   0   100   'DIRECT MIX'         PRM_FX2_PHASER_D_LEVEL
0x6000040b   INTEGER1x7   0   31   0   100   'RATE'               PRM_FX2_FLANGER_RATE
0x6000040c   INTEGER1x7   0   40   0   100   'DEPTH'              PRM_FX2_FLANGER_DEPTH
0x6000040d   INTEGER1x7   0   82   0   100   'MANUAL'             PRM_FX2_FLANGER_MANUAL
0x6000040e   INTEGER1x7   0   50   0   100   'RESONANCE'          PRM_FX2_FLANGER_RESONANCE
0x6000040f   INTEGER1x7   0   0   0   0   ''
0x60000410   INTEGER1x7   0   0   0   10   'LOW CUT'            PRM_FX2_FLANGER_LOWCUT
0x60000411   INTEGER1x7   0   60   0   100   'EFFECT LEVEL'       PRM_FX2_FLANGER_E_LEVEL
0x60000412   INTEGER1x7   0   0   0   100   'DIRECT MIX'         PRM_FX2_FLANGER_D_LEVEL
0x60000413   INTEGER1x7   0   70   0   100   'WAVE SHAPE'         PRM_FX2_TREMOLO_WAVESHAPE
0x60000414   INTEGER1x7   0   85   0   100   'RATE'               PRM_FX2_TREMOLO_RATE
0x60000415   INTEGER1x7   0   65   0   100   'DEPTH'              PRM_FX2_TREMOLO_DEPTH
0x60000416   INTEGER1x7   0   50   0   100   'LEVEL'              PRM_FX2_TREMOLO_LEVEL
0x60000417   INTEGER1x7   0   1   1   1   ''
0x60000418   INTEGER1x7   0   30   0   100   ''
0x60000419   INTEGER1x7   0   85   0   100   'RATE'               PRM_FX2_ROTARY_RATE_FAST
0x6000041a   INTEGER1x7   0   0   0   0   ''
0x6000041b   INTEGER1x7   0   0   0   0   ''
0x6000041c   INTEGER1x7   0   60   0   100   'DEPTH'              PRM_FX2_ROTARY_DEPTH
0x6000041d   INTEGER1x7   0   50   0   100   'LEVEL'              PRM_FX2_ROTARY_LEVEL
0x6000041e   INTEGER1x7   0   70   0   100   'RATE'               PRM_FX2_UNI_V_RATE
0x6000041f   INTEGER1x7   0   60   0   100   'DEPTH'              PRM_FX2_UNI_V_DEPTH
0x60000420   INTEGER1x7   0   100   0   100   'LEVEL'              PRM_FX2_UNI_V_LEVEL
0x60000421   INTEGER1x7   0   0   0   19   'PATTERN'            PRM_FX2_SLICER_PATTERN
0x60000422   INTEGER1x7   0   50   0   100   'RATE'               PRM_FX2_SLICER_RATE
0x60000423   INTEGER1x7   0   50   0   100   'TRIGGER SENS'       PRM_FX2_SLICER_TRIGSENS
0x60000424   INTEGER1x7   0   50   0   100   'EFFECT LEVEL'       PRM_FX2_SLICER_EFFECT_LEVEL
0x60000425   INTEGER1x7   0   0   0   100   'DIRECT MIX'         PRM_FX2_SLICER_DIRECT_LEVEL
0x60000426   INTEGER1x7   0   80   0   100   'RATE'               PRM_FX2_VIBRATO_RATE
0x60000427   INTEGER1x7   0   45   0   100   'DEPTH'              PRM_FX2_VIBRATO_DEPTH
0x60000428   INTEGER1x7   0   1   1   1   ''
0x60000429   INTEGER1x7   0   0   0   0   ''
0x6000042a   INTEGER1x7   0   50   0   100   'LEVEL'              PRM_FX2_VIBRATO_LEVEL
0x6000042b   INTEGER1x7   0   0   0   1   'MODE'               PRM_FX2_RINGMOD_MODE
0x6000042c   INTEGER1x7   0   50   0   100   'FREQUENCY'          PRM_FX2_RINGMOD_FREQ
0x6000042d   INTEGER1x7   0   100   0   100   'EFFECT LEVEL'       PRM_FX2_RINGMOD_E_LEVEL
0x6000042e   INTEGER1x7   0   100   0   100   'DIRECT MIX'         PRM_FX2_RINGMOD_D_LEVEL
0x6000042f   INTEGER1x7   0   1   0   1   'MODE'               PRM_FX2_HUMANIZER_MODE
0x60000430   INTEGER1x7   0   0   0   4   'VOWEL1'             PRM_FX2_HUMANIZER_VOWEL1
0x60000431   INTEGER1x7   0   2   0   4   'VOWEL2'             PRM_FX2_HUMANIZER_VOWEL2
0x60000432   INTEGER1x7   0   50   0   100   'SENS'               PRM_FX2_HUMANIZER_SENS
0x60000433   INTEGER1x7   0   80   0   100   'RATE'               PRM_FX2_HUMANIZER_RATE
0x60000434   INTEGER1x7   0   100   0   100   'DEPTH'              PRM_FX2_HUMANIZER_DEPTH
0x60000435   INTEGER1x7   0   50   0   100   'MANUAL'             PRM_FX2_HUMANIZER_MANUAL
0x60000436   INTEGER1x7   0   100   0   100   'LEVEL'              PRM_FX2_HUMANIZER_LEVEL
0x60000437   INTEGER1x7   0   4   0   16   'XOVER FREQUENCY'    PRM_FX2_2x2CHORUS_XOVERF
0x60000438   INTEGER1x7   0   43   0   100   'LOW RATE'           PRM_FX2_2x2CHORUS_LOW_RATE
0x60000439   INTEGER1x7   0   46   0   100   'LOW DEPTH'          PRM_FX2_2x2CHORUS_LOW_DEPTH
0x6000043a   INTEGER1x7   0   3   0   80   'LOW PRE DELAY'      PRM_FX2_2x2CHORUS_LOW_PREDELAY
0x6000043b   INTEGER1x7   0   75   0   100   'LOW LEVEL'          PRM_FX2_2x2CHORUS_LOW_LEVEL
0x6000043c   INTEGER1x7   0   33   0   100   'HIGH RATE'          PRM_FX2_2x2CHORUS_HIGH_RATE
0x6000043d   INTEGER1x7   0   48   0   100   'HIGH DEPTH'         PRM_FX2_2x2CHORUS_HIGH_DEPTH
0x6000043e   INTEGER1x7   0   3   0   80   'HIGH PRE DELAY'     PRM_FX2_2x2CHORUS_HIGH_PREDELAY
0x6000043f   INTEGER1x7   0   65   0   100   'HIGH LEVEL'         PRM_FX2_2x2CHORUS_HIGH_LEVEL
0x60000440   INTEGER1x7   0   80   0   100   'DIRECT MIX'         PRM_FX2_2x2CHORUS_DIRECT_LEVEL
0x60000441   INTEGER1x7   50   0   -50   50   'HIGH'               PRM_FX2_ACSIM_TOP
0x60000442   INTEGER1x7   0   50   0   100   'BODY'               PRM_FX2_ACSIM_BODY
0x60000443   INTEGER1x7   50   0   -50   50   'LOW'                PRM_FX2_ACSIM_LOW
0x60000444   INTEGER1x7   50   0   -50   50   ''
0x60000445   INTEGER1x7   0   50   0   100   'LEVEL'              PRM_FX2_ACSIM_LEVEL
0x60000446   INTEGER1x7   0   1   0   1   'SCRIPT'             PRM_FX2_EVH_PHASER_SCRIPT
0x60000447   INTEGER1x7   0   50   0   100   'SPEED'              PRM_FX2_EVH_PHASER_SPEED
0x60000448   INTEGER1x7   0   45   0   100   'MANUAL'             PRM_FX2_EVH_FLANGER_MANUAL
0x60000449   INTEGER1x7   0   50   0   100   'WIDTH'              PRM_FX2_EVH_FLANGER_WIDTH
0x6000044a   INTEGER1x7   0   50   0   100   'SPEED'              PRM_FX2_EVH_FLANGER_SPEED
0x6000044b   INTEGER1x7   0   80   0   100   'REGEN.'             PRM_FX2_EVH_FLANGER_REGEN
0x6000044c   INTEGER1x7   0   100   0   100   'PEDAL POS'          PRM_FX2_EVH_WAH_PEDAL_POS
0x6000044d   INTEGER1x7   0   0   0   100   'PEDAL MIN'          PRM_FX2_EVH_WAH_PEDAL_MIN
0x6000044e   INTEGER1x7   0   100   0   100   'PEDAL MAX'          PRM_FX2_EVH_WAH_PEDAL_MAX
0x6000044f   INTEGER1x7   0   100   0   100   'EFFECT LEVEL'       PRM_FX2_EVH_WAH_EFFECT_LEVEL
0x60000450   INTEGER1x7   0   0   0   100   'DIRECT MIX'         PRM_FX2_EVH_WAH_DIRECT_MIX
0x60000451   INTEGER1x7   0   0   0   1   'SELECT'             PRM_FX2_DC30_SELECTOR
0x60000452   INTEGER1x7   0   50   0   100   'INPUT VOLUME'       PRM_FX2_DC30_INPUT_VOLUME
0x60000453   INTEGER1x7   0   50   0   100   'CHORUS INTENSITY'   PRM_FX2_DC30_CHORUS_INTENSITY
0x60000454   INTEGER2x7   0   400   40   600   'ECHO REPEAT RATE'   PRM_FX2_DC30_ECHO_REPEAT_RATE
0x60000456   INTEGER1x7   0   50   0   100   'ECHO INTENSISTY'    PRM_FX2_DC30_ECHO_INTENSITY
0x60000457   INTEGER1x7   0   100   0   100   'ECHO VOLUME'        PRM_FX2_DC30_ECHO_VOLUME
0x60000458   INTEGER1x7   0   50   0   100   'TONE'               PRM_FX2_DC30_TONE
0x60000459   INTEGER1x7   0   0   0   1   'OUTPUT'             PRM_FX2_DC30_OUTPUT
0x6000045a   INTEGER1x7   0   50   0   100   '1OCT LEVEL'         PRM_FX2_HEAVY_OCTAVE_1OCT_LEVEL
0x6000045b   INTEGER1x7   0   0   0   100   '2OCT LEVEL'         PRM_FX2_HEAVY_OCTAVE_2OCT_LEVEL
0x6000045c   INTEGER1x7   0   100   0   100   'DIRECT MIX'         PRM_FX2_HEAVY_OCTAVE_DIRECT_LEVEL
CodeSmart
PART IV
DELAY1
Out: F0 41 00 00 00 00 33 11 60 00 05 00 00 00 00 1A 01 F7
In:  F0 41 00 00 00 00 33 12 60 00 05 00 00 00 03 70 23 0C 00 64 32
     00 64 16 0A 32 03 10 16 0A 32 28 37 01 00 00 00 00 68 F7
0x60000500   INTEGER1x7   0   0   0   1   'SW'               PRM_DLY_SW
0x60000501   INTEGER1x7   0   0   0   10   'TYPE'             PRM_DLY_TYPE
0x60000502   INTEGER2x7   0   400   1   2000   'DELAY TIME'       PRM_DLY_COMMON_DLY_TIME
0x60000504   INTEGER1x7   0   22   0   100   'FEEDBACK'         PRM_DLY_COMMON_FEEDBACK
0x60000505   INTEGER1x7   0   10   0   14   'HIGH CUT'         PRM_DLY_COMMON_HICUT
0x60000506   INTEGER1x7   0   50   0   120   'EFFECT LEVEL'     PRM_DLY_COMMON_EFFECT_LEVEL
0x60000507   INTEGER1x7   0   100   0   100   'DIRECT MIX'       PRM_DLY_COMMON_DIRECT_LEVEL
0x60000508   INTEGER1x7   0   50   0   100   'TAP TIME'         PRM_DLY_PAN_TAPTIME
0x60000509   INTEGER2x7   0   100   1   1000   ''
0x6000050b   INTEGER1x7   0   22   0   100   ''
0x6000050c   INTEGER1x7   0   10   0   14   ''
0x6000050d   INTEGER1x7   0   50   0   120   ''
0x6000050e   INTEGER2x7   0   400   1   1000   ''
0x60000510   INTEGER1x7   0   22   0   100   ''
0x60000511   INTEGER1x7   0   10   0   14   ''
0x60000512   INTEGER1x7   0   50   0   120   ''
0x60000513   INTEGER1x7   0   40   0   100   'MOD RATE'         PRM_DLY_MOD_RATE
0x60000514   INTEGER1x7   0   55   0   100   'MOD DEPTH'        PRM_DLY_MOD_DEPTH
0x60000515   INTEGER1x7   0   1   0   1   'RANGE'            PRM_DLY_VINTAGE_LPF
0x60000516   INTEGER1x7   0   0   0   1   'FILTER'           PRM_DLY_VINTAGE_FILTER
0x60000517   INTEGER1x7   0   0   0   1   'FEEDBACK PHASE'   PRM_DLY_VINTAGE_FEEDBACK_PHASE
0x60000518   INTEGER1x7   0   0   0   1   'DELAY PHASE'      PRM_DLY_VINTAGE_EFFECT_PHASE
0x60000519   INTEGER1x7   0   0   0   1   'MOD SW'           PRM_DLY_VINTAGE_MOD_SW
DELAY2
Out: F0 41 00 00 00 00 33 11 60 00 05 20 00 00 00 1A 61 F7
In:  F0 41 00 00 00 00 33 12 60 00 05 20 00 08 03 10 16 0A 32 64 32
     00 64 16 0A 32 03 10 16 0A 32 28 37 01 00 00 00 00 7D F7 00 00
0x60000520   INTEGER1x7   0   0   0   1   'SW'               PRM_DLY_SW
0x60000521   INTEGER1x7   0   0   0   10   'TYPE'             PRM_DLY_TYPE
0x60000522   INTEGER2x7   0   400   1   2000   'DELAY TIME'       PRM_DLY_COMMON_DLY_TIME
0x60000524   INTEGER1x7   0   22   0   100   'FEEDBACK'         PRM_DLY_COMMON_FEEDBACK
0x60000525   INTEGER1x7   0   10   0   14   'HIGH CUT'         PRM_DLY_COMMON_HICUT
0x60000526   INTEGER1x7   0   50   0   120   'EFFECT LEVEL'     PRM_DLY_COMMON_EFFECT_LEVEL
0x60000527   INTEGER1x7   0   100   0   100   'DIRECT MIX'       PRM_DLY_COMMON_DIRECT_LEVEL
0x60000528   INTEGER1x7   0   50   0   100   'TAP TIME'         PRM_DLY_PAN_TAPTIME
0x60000529   INTEGER2x7   0   100   1   1000   ''
0x6000052b   INTEGER1x7   0   22   0   100   ''
0x6000052c   INTEGER1x7   0   10   0   14   ''
0x6000052d   INTEGER1x7   0   50   0   120   ''
0x6000052e   INTEGER2x7   0   400   1   1000   ''
0x60000530   INTEGER1x7   0   22   0   100   ''
0x60000531   INTEGER1x7   0   10   0   14   ''
0x60000532   INTEGER1x7   0   50   0   120   ''
0x60000533   INTEGER1x7   0   40   0   100   'MOD RATE'         PRM_DLY_MOD_RATE
0x60000534   INTEGER1x7   0   55   0   100   'MOD DEPTH'        PRM_DLY_MOD_DEPTH
0x60000535   INTEGER1x7   0   1   0   1   'RANGE'            PRM_DLY_VINTAGE_LPF
0x60000536   INTEGER1x7   0   0   0   1   'FILTER'           PRM_DLY_VINTAGE_FILTER
0x60000537   INTEGER1x7   0   0   0   1   'FEEDBACK PHASE'   PRM_DLY_VINTAGE_FEEDBACK_PHASE
0x60000538   INTEGER1x7   0   0   0   1   'DELAY PHASE'      PRM_DLY_VINTAGE_EFFECT_PHASE
0x60000539   INTEGER1x7   0   0   0   1   'MOD SW'           PRM_DLY_VINTAGE_MOD_SW
Patch properties 1
Out: F0 41 00 00 00 00 33 11 60 00 05 40 00 00 00 32 29 F7
In:  F0 41 00 00 00 00 33 12 60 00 05 40 00 03 1D 00 0A 02 0A 0A 00
     64 05 00 00 00 00 00 00 00 00 64 00 64 64 00 24 32 64 00 64 00
     64 64 00 64 01 00 32 32 00 05 32 00 00 00 00 00 00 00 64 00 3C
     F7 00 00
0x60000540   INTEGER1x7        0   0   0   1   'SW'                   PRM_REVERB_SW
0x60000541   INTEGER1x7        0   4   0   6   'TYPE'                 PRM_REVERB_TYPE
0x60000542   INTEGER1x7        -1   30   1   100   'REVERB TIME'          PRM_REVERB_TIME
0x60000543   INTEGER2x7        0   10   0   500   'PRE DELAY'            PRM_REVERB_PREDELAY
0x60000545   INTEGER1x7        0   14   0   17   'LOW CUT'              PRM_REVERB_LOWCUT
0x60000546   INTEGER1x7        0   8   0   14   'HIGH CUT'             PRM_REVERB_HICUT
0x60000547   INTEGER1x7        0   8   0   10   'DENSITY'              PRM_REVERB_DENSITY
0x60000548   INTEGER1x7        0   35   0   100   'EFFECT LEVEL'         PRM_REVERB_EFFECT_LEVEL
0x60000549   INTEGER1x7        0   100   0   100   'DIRECT MIX'           PRM_REVERB_DIRECT_LEVEL
0x6000054a   (PADDING | 0x1)   0   0   0   0   ''                     (padding)
0x6000054b   INTEGER1x7        0   50   0   100   'SPRING COLOR'         PRM_REVERB_SPRING_COLOR
0x6000054c   (PADDING | 0x4)   0   0   0   0   ''                     (padding)
0x60000550   INTEGER1x7        0   0   0   1   'SW'                   PRM_PEDAL_FX_SW
0x60000551   INTEGER1x7        0   0   0   2   'TYPE'                 PRM_PEDAL_FX_TYPE
0x60000552   INTEGER1x7        0   0   0   5   'TYPE'                 PRM_PEDAL_FX_WAH_TYPE
0x60000553   INTEGER1x7        0   100   0   100   'PEDAL POS'            PRM_PEDAL_FX_WAH_PEDAL_POSITION
0x60000554   INTEGER1x7        0   0   0   100   'PEDAL MIN'            PRM_PEDAL_FX_WAH_PEDAL_MIN
0x60000555   INTEGER1x7        0   100   0   100   'PEDAL MAX'            PRM_PEDAL_FX_WAH_PEDAL_MAX
0x60000556   INTEGER1x7        0   100   0   100   'EFFECT LEVEL'         PRM_PEDAL_FX_WAH_EFFECT_LEVEL
0x60000557   INTEGER1x7        0   0   0   100   'DIRECT MIX'           PRM_PEDAL_FX_WAH_DIRECT_MIX
0x60000558   INTEGER1x7        24   12   -24   24   'PITCH'                PRM_PEDAL_FX_PEDAL_BEND_PITCH_MAX
0x60000559   INTEGER1x7        0   50   0   100   'PEDAL POS'            PRM_PEDAL_FX_PEDAL_BEND_PEDAL_POS
0x6000055a   INTEGER1x7        0   100   0   100   'EFFECT LEVEL'         PRM_PEDAL_FX_PEDAL_BEND_EFFECT_LE
0x6000055b   INTEGER1x7        0   0   0   100   'DIRECT MIX'           PRM_PEDAL_FX_PEDAL_BEND_DIRECT_MI
0x6000055c   INTEGER1x7        0   100   0   100   'PEDAL POS'            PRM_PEDAL_FX_EVH95_POS
0x6000055d   INTEGER1x7        0   0   0   100   'PEDAL MIN'            PRM_PEDAL_FX_EVH95_MIN
0x6000055e   INTEGER1x7        0   100   0   100   'PEDAL MAX'            PRM_PEDAL_FX_EVH95_MAX
0x6000055f   INTEGER1x7        0   100   0   100   'EFFECT LEVEL'         PRM_PEDAL_FX_EVH95_E_LEVEL
0x60000560   INTEGER1x7        0   0   0   100   'DIRECT MIX'           PRM_PEDAL_FX_EVH95_D_LEVEL
0x60000561   INTEGER1x7        0   100   0   100   'FOOT VOLUME'          PRM_FOOT_VOLUME_VOL_LEVEL
0x60000562   INTEGER1x7        0   1   0   1   'SW'                   PRM_SEND_RETURN_SW
0x60000563   INTEGER1x7        0   0   0   1   'MODE'                 PRM_SEND_RETURN_MODE
0x60000564   INTEGER1x7        0   50   0   100   'SEND LEVEL'           PRM_SEND_RETURN_SEND_LEVEL
0x60000565   INTEGER1x7        0   50   0   100   'RETURN LEVEL'         PRM_SEND_RETURN_RETURN_LEVEL
0x60000566   INTEGER1x7        0   0   0   1   'SW'                   PRM_NS1_SW
0x60000567   INTEGER1x7        0   5   0   100   'THRESHOLD'            PRM_NS1_THRESHOLD
0x60000568   INTEGER1x7        0   50   0   100   'RELEASE'              PRM_NS1_RELEASE
0x60000569   (PADDING | 0x7)   0   0   0   0   ''                     (padding)
0x60000570   INTEGER1x7        0   100   0   100   ''
0x60000571   INTEGER1x7        0   0   0   11   'MASTER KEY'           PRM_MASTER_KEY
Patch properties 2
Out: F0 41 00 00 00 00 33 11 60 00 06 20 00 00 00 24 56 F7
In : F0 41 00 00 00 00 33 12 60 00 06 20 02 00 01 00 0A 0B 0E 1D 23
     24 15 00 27 00 07 08 04 05 03 00 07 08 02 02 02 00 01 02 00 02
     02 00 02 00 04 01 76 F7 00
0x60000620   INTEGER1x7   0   1   0   3   'CHAIN'                PRM_CHAIN_PTN
0x60000621   INTEGER1x7   0   0   0   1   'POSITION'             PRM_POSITION_SEND_RETURN
0x60000622   INTEGER1x7   0   1   0   1   'POSITION'             PRM_POSITION_EQ
0x60000623   INTEGER1x7   0   0   0   1   'POSITION'             PRM_POSITION_PEDAL_FX
0x60000624   INTEGER1x7   0   10   0   22   'BOOSTER GRN'          PRM_FXBOX_ASGN_BOOSTER_G
0x60000625   INTEGER1x7   0   11   0   22   'BOOSTER RED'          PRM_FXBOX_ASGN_BOOSTER_R
0x60000626   INTEGER1x7   0   14   0   22   'BOOSTER YLW'          PRM_FXBOX_ASGN_BOOSTER_Y
0x60000627   INTEGER1x7   0   29   0   39   'MOD GRN'              PRM_FXBOX_ASGN_MOD_G
0x60000628   INTEGER1x7   0   20   0   39   'MOD RED'              PRM_FXBOX_ASGN_MOD_R
0x60000629   INTEGER1x7   0   19   0   39   'MOD YLW'              PRM_FXBOX_ASGN_MOD_Y
0x6000062a   INTEGER1x7   0   21   0   39   'FX GRN'               PRM_FXBOX_ASGN_FX_G
0x6000062b   INTEGER1x7   0   0   0   39   'FX RED'               PRM_FXBOX_ASGN_FX_R
0x6000062c   INTEGER1x7   0   14   0   39   'FX YLW'               PRM_FXBOX_ASGN_FX_Y
0x6000062d   INTEGER1x7   0   0   0   10   'DELAY GRN'            PRM_FXBOX_ASGN_DELAY_G
0x6000062e   INTEGER1x7   0   7   0   10   'DELAY RED'            PRM_FXBOX_ASGN_DELAY_R
0x6000062f   INTEGER1x7   0   8   0   10   'DELAY YLW'            PRM_FXBOX_ASGN_DELAY_Y
0x60000630   INTEGER1x7   0   4   0   6   'REVERB GRN'           PRM_FXBOX_ASGN_REVERB_G
0x60000631   INTEGER1x7   0   5   0   6   'REVERB RED'           PRM_FXBOX_ASGN_REVERB_R
0x60000632   INTEGER1x7   0   3   0   6   'REVERB YLW'           PRM_FXBOX_ASGN_REVERB_Y
0x60000633   INTEGER1x7   0   0   0   10   'DELAY2 GRN'           PRM_FXBOX_ASGN_DELAY2_G
0x60000634   INTEGER1x7   0   7   0   10   'DELAY2 RED'           PRM_FXBOX_ASGN_DELAY2_R
0x60000635   INTEGER1x7   0   8   0   10   'DELAY2 YLW'           PRM_FXBOX_ASGN_DELAY2_Y
0x60000636   INTEGER1x7   0   2   0   2   'LAYER MODE GRN'       PRM_FXBOX_DLYREV_LAYER_G
0x60000637   INTEGER1x7   0   2   0   2   'LAYER MODE RED'       PRM_FXBOX_DLYREV_LAYER_R
0x60000638   INTEGER1x7   0   2   0   2   'LAYER MODE YLW'       PRM_FXBOX_DLYREV_LAYER_Y
0x60000639   INTEGER1x7   0   0   0   2   ''                     PRM_FXBOX_SEL_BOOST
0x6000063a   INTEGER1x7   0   0   0   2   ''                     PRM_FXBOX_SEL_MOD
0x6000063b   INTEGER1x7   0   0   0   2   ''                     PRM_FXBOX_SEL_FX
0x6000063c   INTEGER1x7   0   0   0   2   ''                     PRM_FXBOX_SEL_DELAY
0x6000063d   INTEGER1x7   0   0   0   2   ''                     PRM_FXBOX_SEL_REVERB
0x6000063e   INTEGER1x7   0   2   0   9   'EXP PEDAL FUNCTION'   PRM_PEDAL_FUNCTION_EXP_PEDAL
0x6000063f   INTEGER1x7   0   0   0   9   'GAFC EXP1FUNCTION'    PRM_PEDAL_FUNCTION_GAFC_EXP1
0x60000640   INTEGER1x7   0   2   0   9   'GAFC EXP2FUNCTION'    PRM_PEDAL_FUNCTION_GAFC_EXP2
0x60000641   INTEGER1x7   0   0   0   8   'GAFC FS1FUNCTION'     PRM_FS_FUNCTION_GAFC_FS1
0x60000642   INTEGER1x7   0   4   0   8   'GAFC FS2FUNCTION'     PRM_FS_FUNCTION_GAFC_FS2
0x60000643   INTEGER1x7   0   1   0   2   'CABINET RESONANCE'    PRM_CABINET_RESONANCE
CodeSmart
PART V
Patch status
Out: F0 41 00 00 00 00 33 11 60 00 06 50 00 00 00 12 38 F7
In:  F0 41 00 00 00 00 33 12 60 00 06 50 01 09 5C 50 3D 3B 5E 00 00
     00 00 00 01 00 00 00 00 00 3D F7 00
0x60000650   INTEGER1x7   0   1   0   4   'TYPE'        PRM_KNOB_POS_TYPE
0x60000651   INTEGER1x7   0   50   0   100   'GAIN'        PRM_KNOB_POS_GAIN
0x60000652   INTEGER1x7   0   50   0   100   'VOLUME'      PRM_KNOB_POS_VOLUME
0x60000653   INTEGER1x7   0   50   0   100   'BASS'        PRM_KNOB_POS_BASS
0x60000654   INTEGER1x7   0   50   0   100   'MIDDLE'      PRM_KNOB_POS_MIDDLE
0x60000655   INTEGER1x7   0   50   0   100   'TREBLE'      PRM_KNOB_POS_TREBLE
0x60000656   INTEGER1x7   0   50   0   100   'PRESENCE'    PRM_KNOB_POS_PRESENCE
0x60000657   INTEGER1x7   1   -1   -1   100   'BOOSTER'     PRM_KNOB_POS_BOOST
0x60000658   INTEGER1x7   1   -1   -1   100   'MOD'         PRM_KNOB_POS_MOD
0x60000659   INTEGER1x7   1   -1   -1   100   'FX'          PRM_KNOB_POS_FX
0x6000065a   INTEGER1x7   1   -1   -1   100   'DELAY'       PRM_KNOB_POS_DELAY
0x6000065b   INTEGER1x7   1   -1   -1   100   'REVERB'      PRM_KNOB_POS_REVERB
0x6000065c   INTEGER1x7   0   0   0   1   'VARIATION'   PRM_LED_STATE_VARI
0x6000065d   INTEGER1x7   0   0   0   3   'BOOSTER'     PRM_LED_STATE_BOOST
0x6000065e   INTEGER1x7   0   0   0   3   'MOD'         PRM_LED_STATE_MOD
0x6000065f   INTEGER1x7   0   0   0   3   'FX'          PRM_LED_STATE_FX
0x60000660   INTEGER1x7   0   0   0   3   'DELAY'       PRM_LED_STATE_DELAY
0x60000661   INTEGER1x7   0   0   0   3   'REVERB'      PRM_LED_STATE_REVERB
Patch knob assign properties
Out: F0 41 00 00 00 00 33 11 60 00 07 00 00 00 00 21 78 F7
In : F0 41 00 00 00 00 33 12 60 00 07 00 00 00 00 00 00 00 00 00 00
     00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
     00 00 00 19 F7 00
0x60000700   INTEGER1x7   0   0   0   7   'BOOSTER'         PRM_KNOB_ASSIGN_BOOSTER
0x60000701   INTEGER1x7   0   0   0   8   'DELAY'           PRM_KNOB_ASSIGN_DELAY
0x60000702   INTEGER1x7   0   0   0   7   'REVERB'          PRM_KNOB_ASSIGN_REVERB
0x60000703   INTEGER1x7   0   0   0   10   'CHORUS'          PRM_KNOB_ASSIGN_CHORUS
0x60000704   INTEGER1x7   0   0   0   7   'FLANGER'         PRM_KNOB_ASSIGN_FLANGER
0x60000705   INTEGER1x7   0   0   0   7   'PHASER'          PRM_KNOB_ASSIGN_PHASER
0x60000706   INTEGER1x7   0   0   0   3   'UNI-V'           PRM_KNOB_ASSIGN_UNI_V
0x60000707   INTEGER1x7   0   0   0   4   'TREMOLO'         PRM_KNOB_ASSIGN_TREMOLO
0x60000708   INTEGER1x7   0   0   0   3   'VIBRATO'         PRM_KNOB_ASSIGN_VIBRATO
0x60000709   INTEGER1x7   0   0   0   3   'ROTARY'          PRM_KNOB_ASSIGN_ROTARY
0x6000070a   INTEGER1x7   0   0   0   3   'RING MOD'        PRM_KNOB_ASSIGN_RING_MOD
0x6000070b   INTEGER1x7   0   0   0   3   'SLOW GEAR'       PRM_KNOB_ASSIGN_SLOW_GEAR
0x6000070c   INTEGER1x7   0   0   0   4   'SLICER'          PRM_KNOB_ASSIGN_SLICER
0x6000070d   INTEGER1x7   0   0   0   4   'COMP'            PRM_KNOB_ASSIGN_COMP
0x6000070e   INTEGER1x7   0   0   0   5   'LIMITER'         PRM_KNOB_ASSIGN_LIMITER
0x6000070f   INTEGER1x7   0   0   0   5   'T.WAH'           PRM_KNOB_ASSIGN_T_WAH
0x60000710   INTEGER1x7   0   0   0   6   'AUTO WAH'        PRM_KNOB_ASSIGN_AUTO_WAH
0x60000711   INTEGER1x7   0   0   0   5   'PEDAL WAH'       PRM_KNOB_ASSIGN_PEDAL_WAH
0x60000712   INTEGER1x7   0   0   0   11   'GEQ'             PRM_KNOB_ASSIGN_GEQ
0x60000713   INTEGER1x7   0   0   0   11   'PEQ'             PRM_KNOB_ASSIGN_PEQ
0x60000714   INTEGER1x7   0   0   0   4   'GUITAR SIM'      PRM_KNOB_ASSIGN_GUITAR_SIM
0x60000715   INTEGER1x7   0   0   0   4   'AC.GUITAR SIM'   PRM_KNOB_ASSIGN_AC_GUITAR_SIM
0x60000716   INTEGER1x7   0   0   0   6   'AC.PROCESSOR'    PRM_KNOB_ASSIGN_AC_PROCESSOR
0x60000717   INTEGER1x7   0   0   0   7   'WAVE SYNTH'      PRM_KNOB_ASSIGN_WAVE_SYNTH
0x60000718   INTEGER1x7   0   0   0   2   'OCTAVE'          PRM_KNOB_ASSIGN_OCTAVE
0x60000719   INTEGER1x7   0   0   0   10   'PITCH SHIFTER'   PRM_KNOB_ASSIGN_PITCH_SHIFTER
0x6000071a   INTEGER1x7   0   0   0   9   'HARMONIST'       PRM_KNOB_ASSIGN_HARMONIST
0x6000071b   INTEGER1x7   0   0   0   5   'HUMANIZER'       PRM_KNOB_ASSIGN_HUMANIZER
0x6000071c   INTEGER1x7   0   0   0   1   'PHASE 90E'       PRM_KNOB_ASSIGN_EVH_PHASER
0x6000071d   INTEGER1x7   0   0   0   4   'FLANGER 117E'    PRM_KNOB_ASSIGN_EVH_FLANGER
0x6000071e   INTEGER1x7   0   0   0   5   'WAH 95E'         PRM_KNOB_ASSIGN_EVH_WAH
0x6000071f   INTEGER1x7   0   0   0   6   'DC-30'           PRM_KNOB_ASSIGN_DC30
0x60000720   INTEGER1x7   0   0   0   3   'HEAVY OCT'       PRM_KNOB_ASSIGN_HEAVY_OCT
Unknown
0x60000800                     Unknown area - But 33d bytes requested by BTS
Out: F0 41 00 00 00 00 33 11 60 00 08 00 00 00 00 21 77 F7
In : F0 41 00 00 00 00 33 12 60 00 08 00 00 00 00 00 00 00 00 00 00
     00 00 00 18 F7 00
Patch assign minmax
Out: F0 41 00 00 00 00 33 11 60 00 08 30 00 00 00 4C 1C F7
In : F0 41 00 00 00 00 33 12 60 00 08 30 00 64 00 00 00 64 00 00 00
     64 00 64 00 64 00 64 00 64 00 64 00 64 00 64 00 64 00 64 00 64
     00 64 00 64 00 64 00 64 00 64 00 64 00 64 00 64 00 64 00 64 00
     64 00 64 00 00 00 64 00 00 00 64 00 64 00 64 00 64 00 64 00 00
     00 64 00 64 04 F7
0x60000830   INTEGER1x7   0   0   0   127   'BOOSTER MIN'          PRM_EXP_PEDAL_ASSIGN_BOOSTER_MIN
0x60000831   INTEGER1x7   0   100   0   127   'BOOSTER MAX'          PRM_EXP_PEDAL_ASSIGN_BOOSTER_MAX
0x60000832   INTEGER2x7   0   0   0   2000   'DELAY MIN'            PRM_EXP_PEDAL_ASSIGN_DELAY_MIN
0x60000834   INTEGER2x7   0   100   0   2000   'DELAY MAX'            PRM_EXP_PEDAL_ASSIGN_DELAY_MAX
0x60000836   INTEGER2x7   0   0   0   500   'REVERB MIN'           PRM_EXP_PEDAL_ASSIGN_REVERB_MIN
0x60000838   INTEGER2x7   0   100   0   500   'REVERB MAX'           PRM_EXP_PEDAL_ASSIGN_REVERB_MAX
0x6000083a   INTEGER1x7   0   0   0   127   'CHORUS MIN'           PRM_EXP_PEDAL_ASSIGN_CHORUS_MIN
0x6000083b   INTEGER1x7   0   100   0   127   'CHORUS MAX'           PRM_EXP_PEDAL_ASSIGN_CHORUS_MAX
0x6000083c   INTEGER1x7   0   0   0   127   'FLANGER MIN'          PRM_EXP_PEDAL_ASSIGN_FLANGER_MIN
0x6000083d   INTEGER1x7   0   100   0   127   'FLANGER MAX'          PRM_EXP_PEDAL_ASSIGN_FLANGER_MAX
0x6000083e   INTEGER1x7   0   0   0   127   'PHASER MIN'           PRM_EXP_PEDAL_ASSIGN_PHASER_MIN
0x6000083f   INTEGER1x7   0   100   0   127   'PHASER MAX'           PRM_EXP_PEDAL_ASSIGN_PHASER_MAX
0x60000840   INTEGER1x7   0   0   0   127   'UNI-V MIN'            PRM_EXP_PEDAL_ASSIGN_UNI_V_MIN
0x60000841   INTEGER1x7   0   100   0   127   'UNI-V MAX'            PRM_EXP_PEDAL_ASSIGN_UNI_V_MAX
0x60000842   INTEGER1x7   0   0   0   127   'TREMOLO MIN'          PRM_EXP_PEDAL_ASSIGN_TREMOLO_MIN
0x60000843   INTEGER1x7   0   100   0   127   'TREMOLO MAX'          PRM_EXP_PEDAL_ASSIGN_TREMOLO_MAX
0x60000844   INTEGER1x7   0   0   0   127   'VIBRATO MIN'          PRM_EXP_PEDAL_ASSIGN_VIBRATO_MIN
0x60000845   INTEGER1x7   0   100   0   127   'VIBRATO MAX'          PRM_EXP_PEDAL_ASSIGN_VIBRATO_MAX
0x60000846   INTEGER1x7   0   0   0   127   'ROTARY MIN'           PRM_EXP_PEDAL_ASSIGN_ROTARY_MIN
0x60000847   INTEGER1x7   0   100   0   127   'ROTARY MAX'           PRM_EXP_PEDAL_ASSIGN_ROTARY_MAX
0x60000848   INTEGER1x7   0   0   0   127   'RING MOD MIN'         PRM_EXP_PEDAL_ASSIGN_RING_MOD_MIN
0x60000849   INTEGER1x7   0   100   0   127   'RING MOD MAX'         PRM_EXP_PEDAL_ASSIGN_RING_MOD_MAX
0x6000084a   INTEGER1x7   0   0   0   127   'SLOW GEAR MIN'        PRM_EXP_PEDAL_ASSIGN_SLOW_GEAR_MIN
0x6000084b   INTEGER1x7   0   100   0   127   'SLOW GEAR MAX'        PRM_EXP_PEDAL_ASSIGN_SLOW_GEAR_MAX
0x6000084c   INTEGER1x7   0   0   0   127   'SLICER MIN'           PRM_EXP_PEDAL_ASSIGN_SLICER_MIN
0x6000084d   INTEGER1x7   0   100   0   127   'SLICER MAX'           PRM_EXP_PEDAL_ASSIGN_SLICER_MAX
0x6000084e   INTEGER1x7   0   0   0   127   'COMP MIN'             PRM_EXP_PEDAL_ASSIGN_COMP_MIN
0x6000084f   INTEGER1x7   0   100   0   127   'COMP MAX'             PRM_EXP_PEDAL_ASSIGN_COMP_MAX
0x60000850   INTEGER1x7   0   0   0   127   'LIMITER MIN'          PRM_EXP_PEDAL_ASSIGN_LIMITER_MIN
0x60000851   INTEGER1x7   0   100   0   127   'LIMITER MAX'          PRM_EXP_PEDAL_ASSIGN_LIMITER_MAX
0x60000852   INTEGER1x7   0   0   0   127   'T.WAH MIN'            PRM_EXP_PEDAL_ASSIGN_T_WAH_MIN
0x60000853   INTEGER1x7   0   100   0   127   'T.WAH MAX'            PRM_EXP_PEDAL_ASSIGN_T_WAH_MAX
0x60000854   INTEGER1x7   0   0   0   127   'AUTO WAH MIN'         PRM_EXP_PEDAL_ASSIGN_AUTO_WAH_MIN
0x60000855   INTEGER1x7   0   100   0   127   'AUTO WAH MAX'         PRM_EXP_PEDAL_ASSIGN_AUTO_WAH_MAX
0x60000856   INTEGER1x7   0   0   0   127   'PEDAL WAH MIN'        PRM_EXP_PEDAL_ASSIGN_PEDAL_WAH_MIN
0x60000857   INTEGER1x7   0   100   0   127   'PEDAL WAH MAX'        PRM_EXP_PEDAL_ASSIGN_PEDAL_WAH_MAX
0x60000858   INTEGER1x7   0   0   0   127   'GEQ MIN'              PRM_EXP_PEDAL_ASSIGN_GEQ_MIN
0x60000859   INTEGER1x7   0   100   0   127   'GEQ MAX'              PRM_EXP_PEDAL_ASSIGN_GEQ_MAX
0x6000085a   INTEGER1x7   0   0   0   127   'PEQ MIN'              PRM_EXP_PEDAL_ASSIGN_PEQ_MIN
0x6000085b   INTEGER1x7   0   100   0   127   'PEQ MAX'              PRM_EXP_PEDAL_ASSIGN_PEQ_MAX
0x6000085c   INTEGER1x7   0   0   0   127   'GUITAR SIM MIN'       PRM_EXP_PEDAL_ASSIGN_GUITAR_SIM_MIN
0x6000085d   INTEGER1x7   0   100   0   127   'GUITAR SIM MAX'       PRM_EXP_PEDAL_ASSIGN_GUITAR_SIM_MAX
0x6000085e   INTEGER1x7   0   0   0   127   'AC.GUITAR SIM MIN'    PRM_EXP_PEDAL_ASSIGN_AC_GUITAR_SIM_MIN
0x6000085f   INTEGER1x7   0   100   0   127   'AC.GUITAR SIM MAX'    PRM_EXP_PEDAL_ASSIGN_AC_GUITAR_SIM_MAX
0x60000860   INTEGER1x7   0   0   0   127   'AC.PROCESSOR MIN'     PRM_EXP_PEDAL_ASSIGN_AC_PROCESSOR_MIN
0x60000861   INTEGER1x7   0   100   0   127   'AC.PROCESSOR MAX'     PRM_EXP_PEDAL_ASSIGN_AC_PROCESSOR_MAX
0x60000862   INTEGER1x7   0   0   0   127   'WAVE SYNTH MIN'       PRM_EXP_PEDAL_ASSIGN_WAVE_SYNTH_MIN
0x60000863   INTEGER1x7   0   100   0   127   'WAVE SYNTH MAX'       PRM_EXP_PEDAL_ASSIGN_WAVE_SYNTH_MAX
0x60000864   INTEGER1x7   0   0   0   127   'OCTAVE MIN'           PRM_EXP_PEDAL_ASSIGN_OCTAVE_MIN
0x60000865   INTEGER1x7   0   100   0   127   'OCTAVE MAX'           PRM_EXP_PEDAL_ASSIGN_OCTAVE_MAX
0x60000866   INTEGER2x7   0   0   0   300   'PITCH SHIFTER MIN'    PRM_EXP_PEDAL_ASSIGN_PITCH_SHIFTER_MIN
0x60000868   INTEGER2x7   0   100   0   300   'PITCH SHIFTER MAX'    PRM_EXP_PEDAL_ASSIGN_PITCH_SHIFTER_MAX
0x6000086a   INTEGER2x7   0   0   0   300   'HARMONIST MIN'        PRM_EXP_PEDAL_ASSIGN_HARMONIST_MIN
0x6000086c   INTEGER2x7   0   100   0   300   'HARMONIST MAX'        PRM_EXP_PEDAL_ASSIGN_HARMONIST_MAX
0x6000086e   INTEGER1x7   0   0   0   127   'HUMANIZER MIN'        PRM_EXP_PEDAL_ASSIGN_HUMANIZER_MIN
0x6000086f   INTEGER1x7   0   100   0   127   'HUMANIZER MAX'        PRM_EXP_PEDAL_ASSIGN_HUMANIZER_MAX
0x60000870   INTEGER1x7   0   0   0   127   'PHASER 90E MIN'       PRM_EXP_PEDAL_ASSIGN_EVH_PHASER_MIN
0x60000871   INTEGER1x7   0   100   0   127   'PHASER 90E MAX'       PRM_EXP_PEDAL_ASSIGN_EVH_PHASER_MAX
0x60000872   INTEGER1x7   0   0   0   127   'FLANGER 117E MIN'     PRM_EXP_PEDAL_ASSIGN_EVH_FLANGER_MIN
0x60000873   INTEGER1x7   0   100   0   127   'FLANGER 117E MAX'     PRM_EXP_PEDAL_ASSIGN_EVH_FLANGER_MAX
0x60000874   INTEGER1x7   0   0   0   127   'WAH 95E MIN'          PRM_EXP_PEDAL_ASSIGN_EVH_WAH_MIN
0x60000875   INTEGER1x7   0   100   0   127   'WAH 95E MAX'          PRM_EXP_PEDAL_ASSIGN_EVH_WAH_MAX
0x60000876   INTEGER2x7   0   0   0   600   'DC-30 MIN'            PRM_EXP_PEDAL_ASSIGN_DC30_MIN
0x60000878   INTEGER2x7   0   100   0   600   'DC-30 MAX'            PRM_EXP_PEDAL_ASSIGN_DC30_MAX
0x6000087a   INTEGER1x7   0   0   0   127   'HEAVY OCTAVE MIN'     PRM_EXP_PEDAL_ASSIGN_HEAVY_OCT_MIN
0x6000087b   INTEGER1x7   0   100   0   127   'HEAVY OCTAVE MAX'     PRM_EXP_PEDAL_ASSIGN_HEAVY_OCT_MAX
Unknown
Out: F0 41 00 00 00 00 33 11 60 00 09 00 00 00 00 21 76 F7
In:  F0 41 00 00 00 00 33 12 60 00 09 00 00 00 00 00 00 00 00 00 00
     00 00 00 17 F7 00
0x60000900
Unknown
Out: F0 41 00 00 00 00 33 11 60 00 09 30 00 00 00 4C 1B F7
In : 04 F0 41 00 04 00 00 00 04 33 12 60 04 00 09 30 04 00 64 00 04 00 00 64 04 00 00 00
     04 64 00 64 04 00 64 00 04 64 00 64 04 00 64 00 04 64 00 64 04 00 64 00 04 64 00 64
     04 00 64 00 04 64 00 64 04 00 64 00 04 64 00 64 04 00 64 00 04 64 00 64 04 00 64 00
     04 64 00 64 04 00 00 00 04 64 00 00 04 00 64 00 04 64 00 64 04 00 64 00 04 64 00 00
     04 00 64 00 07 64 03 F7
0x60000930
Unknown
Out: F0 41 00 00 00 00 33 11 60 00 0A 00 00 00 00 21 75 F7
In : F0 41 00 00 00 00 33 12 60 00 0A 00 00 00 00 00 00 00 00 00 00
     00 00 00 16 F7 00
0x60000a00
Unknown
Out: F0 41 00 00 00 00 33 11 60 00 0A 30 00 00 00 4C 1A F7
In : F0 41 00 00 00 00 33 12 60 00 0A 30 00 64 00 00 00 64 00 00 00
     00 64 00 64 02 F7
0x60000a30
Editor And Patch
0x7f000000                     Editor communication Level
0x7f000001                     Editor communication Mode (0/1)
0x7f000002                     Running mode
0x7f000003                     Editor communication revision
0x7F000104                     Patch Write
0x7F010003                     Patch temp clear
0x7F000100                     Patch select
Buttons
0x7f010100                     Press Amp Type Variation button
0x7f010101                     Press Booster color button
0x7f010102                     Press MOD color button
0x7f010103                     Press FX color button
0x7f010104                     Press Delay color button
0x7f010105                     Press Reverb color button
0x7f010106                     Delay Tap button
0x7f010107                     Delay2 Tap Button
Unknown
Out: F0 41 00 00 00 00 33 11 7F 01 02 01 00 00 00 01 7C F7
In : F0 41 00 00 00 00 33 12 7F 01 02 01 00 7D F7
0x7f010201
CodeSmart
Address 60 00 07 00 Panel Knob Assign
Address 60 00 08 00 EXP Pedal Assign
Address 60 00 09 00 GAFC EXP1 Assign
Address 60 00 0A 00 GAFC EXP2 Assign
00   KATANA:   EXP PEDAL   ASSIGN   Booster
01   KATANA:   EXP PEDAL   ASSIGN   Delay 1 & 2
02   KATANA:   EXP PEDAL   ASSIGN   Reverb
03   KATANA:   EXP PEDAL   ASSIGN   Chorus
04   KATANA:   EXP PEDAL   ASSIGN   Flanger
05   KATANA:   EXP PEDAL   ASSIGN   Phaser
06   KATANA:   EXP PEDAL   ASSIGN   UniVibe
07   KATANA:   EXP PEDAL   ASSIGN   Tremolo
08   KATANA:   EXP PEDAL   ASSIGN   Vibrato
09   KATANA:   EXP PEDAL   ASSIGN   Rotary
0A   KATANA:   EXP PEDAL   ASSIGN   Ring Mod
0B   KATANA:   EXP PEDAL   ASSIGN   Slow Gear
0C   KATANA:   EXP PEDAL   ASSIGN   Slicer
0D   KATANA:   EXP PEDAL   ASSIGN   Compressor
0E   KATANA:   EXP PEDAL   ASSIGN   Limiter
0F   KATANA:   EXP PEDAL   ASSIGN   T Wah
10   KATANA:   EXP PEDAL   ASSIGN   Auto Wah
11   KATANA:   EXP PEDAL   ASSIGN   Pedal Wah
12   KATANA:   EXP PEDAL   ASSIGN   Graphic EQ
13   KATANA:   EXP PEDAL   ASSIGN   Parametric EQ
14   KATANA:   EXP PEDAL   ASSIGN   Guitar Sim
15   KATANA:   EXP PEDAL   ASSIGN   Acoustic Sim
16   KATANA:   EXP PEDAL   ASSIGN   Acoustic Proc
17   KATANA:   EXP PEDAL   ASSIGN   Wave Synth
18   KATANA:   EXP PEDAL   ASSIGN   Octave
19   KATANA:   EXP PEDAL   ASSIGN   Pitch Shifter
1A   KATANA:   EXP PEDAL   ASSIGN   Harmonist
1B   KATANA:   EXP PEDAL   ASSIGN   Humanizer
1C   KATANA:   EXP PEDAL   ASSIGN   Phaser 90E
1D   KATANA:   EXP PEDAL   ASSIGN   Flanger 117E
1E   KATANA:   EXP PEDAL   ASSIGN   Wah 95E
1F   KATANA:   EXP PEDAL   ASSIGN   DC-30
20   KATANA:   EXP PEDAL   ASSIGN   Heavy Octave
Address 60 00 08 30 EXP Pedal Assign
Address 60 00 09 30 GAFC EXP1 Assign
Address 60 00 0A 30 GAFC EXP2 Assign]
30   KATANA:   EXP PEDAL ASSIGN   Booster   Min
31   KATANA:   EXP PEDAL ASSIGN   Booster   Max
32   KATANA:   EXP PEDAL ASSIGN   Delay   Min
33   KATANA:   EXP PEDAL ASSIGN
34   KATANA:   EXP PEDAL ASSIGN   Delay   Max
35   KATANA:   EXP PEDAL ASSIGN
36   KATANA:   EXP PEDAL ASSIGN   Reverb   Min
37   KATANA:   EXP PEDAL ASSIGN
38   KATANA:   EXP PEDAL ASSIGN   Reverb   Max
39   KATANA:   EXP PEDAL ASSIGN
3A   KATANA:   EXP PEDAL ASSIGN   Chorus   Min
3B   KATANA:   EXP PEDAL ASSIGN   Chorus   Max
3C   KATANA:   EXP PEDAL ASSIGN   Flanger   Min
3D   KATANA:   EXP PEDAL ASSIGN   Flanger   Max
3E   KATANA:   EXP PEDAL ASSIGN   Phaser   Min
3F   KATANA:   EXP PEDAL ASSIGN   Phaser   Max
40   KATANA:   EXP PEDAL ASSIGN   UniVibe   Min
41   KATANA:   EXP PEDAL ASSIGN   UniVibe   Max
42   KATANA:   EXP PEDAL ASSIGN   Tremolo   Min
43   KATANA:   EXP PEDAL ASSIGN   Tremolo   Max
44   KATANA:   EXP PEDAL ASSIGN   Vibrato   Min
45   KATANA:   EXP PEDAL ASSIGN   Vibrato   Max
46   KATANA:   EXP PEDAL ASSIGN   Rotary   Min
47   KATANA:   EXP PEDAL ASSIGN   Rotary   Max
48   KATANA:   EXP PEDAL ASSIGN   Ring Mod   Min
49   KATANA:   EXP PEDAL ASSIGN   Ring Mod   Max
4A   KATANA:   EXP PEDAL ASSIGN   Slow Gear   Min
4B   KATANA:   EXP PEDAL ASSIGN   Slow Gear   Max
4C   KATANA:   EXP PEDAL ASSIGN   Slicer   Min
4D   KATANA:   EXP PEDAL ASSIGN   Slicer   Max
4E   KATANA:   EXP PEDAL ASSIGN   Compressor   Min
4F   KATANA:   EXP PEDAL ASSIGN   Compressor   Max
50   KATANA:   EXP PEDAL ASSIGN   Limiter   Min
51   KATANA:   EXP PEDAL ASSIGN   Limiter   Max
52   KATANA:   EXP PEDAL ASSIGN   T Wah   Min
53   KATANA:   EXP PEDAL ASSIGN   T Wah   Max
54   KATANA:   EXP PEDAL ASSIGN   Auto Wah   Min
55   KATANA:   EXP PEDAL ASSIGN   Auto Wah   Max
56   KATANA:   EXP PEDAL ASSIGN   Pedal Wah   Min
57   KATANA:   EXP PEDAL ASSIGN   Pedal Wah   Max
58   KATANA:   EXP PEDAL ASSIGN   Graphic EQ   Min
59   KATANA:   EXP PEDAL ASSIGN   Graphic EQ   Max
5A   KATANA:   EXP PEDAL ASSIGN   Parametric EQ   Min
5B   KATANA:   EXP PEDAL ASSIGN   Parametric EQ   Max
5C   KATANA:   EXP PEDAL ASSIGN   Guitar Sim   Min
5D   KATANA:   EXP PEDAL ASSIGN   Guitar Sim   Max
5E   KATANA:   EXP PEDAL ASSIGN   Acoustic Sim   Min
5F   KATANA:   EXP PEDAL ASSIGN   Acoustic Sim   Max
60   KATANA:   EXP PEDAL ASSIGN   Acoustic Processor   Min
61   KATANA:   EXP PEDAL ASSIGN   Acoustic Processor   Max
62   KATANA:   EXP PEDAL ASSIGN   Wave Synth   Min
63   KATANA:   EXP PEDAL ASSIGN   Wave Synth   Max
64   KATANA:   EXP PEDAL ASSIGN   Octave   Min
65   KATANA:   EXP PEDAL ASSIGN   Octave   Max
66   KATANA:   EXP PEDAL ASSIGN   Pitch Shifter   Min
67   KATANA:   EXP PEDAL ASSIGN
68   KATANA:   EXP PEDAL ASSIGN   Pitch Shifter   Max
69   KATANA:   EXP PEDAL ASSIGN
6A   KATANA:   EXP PEDAL ASSIGN   Harmonist   Min
6B   KATANA:   EXP PEDAL ASSIGN
6C   KATANA:   EXP PEDAL ASSIGN   Harmonist   Max
6D   KATANA:   EXP PEDAL ASSIGN
6E   KATANA:   EXP PEDAL ASSIGN   Humanizer   Min
6F   KATANA:   EXP PEDAL ASSIGN   Humanizer   Max
70   KATANA:   EXP PEDAL ASSIGN   Phaser 90E   Min
71   KATANA:   EXP PEDAL ASSIGN   Phaser 90E   Max
72   KATANA:   EXP PEDAL ASSIGN   Flanger 117E   Min
73   KATANA:   EXP PEDAL ASSIGN   Flanger 117E   Max
74   KATANA:   EXP PEDAL ASSIGN   Wah 95E   Min
75   KATANA:   EXP PEDAL ASSIGN   Wah 95E   Max
76   KATANA:   EXP PEDAL ASSIGN   DC-30   Min
77   KATANA:   EXP PEDAL ASSIGN
78   KATANA:   EXP PEDAL ASSIGN   DC-30   Max
79   KATANA:   EXP PEDAL ASSIGN
7A   KATANA:   EXP PEDAL ASSIGN   Heavy Octave   Min
7B   KATANA:   EXP PEDAL ASSIGN   Heavy Octave   Max
CodeSmart
Thanks for filling the unknown spots!
Was looking for effect chain data but...no!
Quote from: CodeSmart on February 10, 2020, 02:08:59 PM
the chain exists in a patch dump, but BTS does not read it.
Address 60 00 06 00
00   Chain      Chain
01   Chain      Chain
02   Chain      Chain
03   Chain      Chain
04   Chain      Chain
05   Chain      Chain
06   Chain      Chain
07   Chain      Chain
08   Chain      Chain
09   Chain      Chain
0A   Chain      Chain
0B   Chain      Chain
0C   Chain      Chain
0D   Chain      Chain
0E   Chain      Chain
0F   Chain      Chain
10   Chain      Chain
11   Chain      Chain
12   Chain      Chain
13   Chain      Chain
14
15
16
17
18
19
1A
1B
1C
1D
1E
1F
20   KATANA:      Chain   position
21   KATANA:   Chain   Loop   Postion
22   KATANA:   Chain   EQ   Postion
23   KATANA:   Chain   Pedal/Fx:   Postion
24   KATANA:   FX1A   Booster   GREEN
25   KATANA:   FX1A   Booster   RED
26   KATANA:   FX1A   Booster   YELLOW
27   KATANA:   FX1B   MOD   GREEN
28   KATANA:   FX1B   MOD   RED
29   KATANA:   FX1B   MOD   YELLOW
2A   KATANA:   FX2B   FX   GREEN
2B   KATANA:   FX2B   FX   RED
2C   KATANA:   FX2B   FX   YELLOW
2D   KATANA:   FX2A   Delay 1   GREEN
2E   KATANA:   FX2A   Delay 1   RED
2F   KATANA:   FX2A   Delay 1   YELLOW
30   KATANA:   FX3   Reverb   GREEN
31   KATANA:   FX3   Reverb   RED
32   KATANA:   FX3   Reverb   YELLOW
33   KATANA:   FX2A   Delay 2   GREEN
34   KATANA:   FX2A   Delay 2   RED
35   KATANA:   FX2A   Delay 2   YELLOW
36   KATANA:   FX BOX   RV/DD2 LAYER   GREEN
37   KATANA:   FX BOX   RV/DD2 LAYER   RED
38   KATANA:   FX BOX   RV/DD2 LAYER   YELLOW
39   KATANA:   FX1A   Select   Booster
3A   KATANA:   FX1B   Select   MOD
3B   KATANA:   FX2A   Select   Delay 1
3C   KATANA:   FX2B   Select   FX
3D   KATANA:   FX3   Select   Reverb
3E   KATANA:   PEDAL FUNCTION   Select   EXP Pedal
3F   KATANA:   PEDAL FUNCTION   Select   GAFC EXP1
40   KATANA:   PEDAL FUNCTION   Select   GAFC EXP2
41   KATANA:   PEDAL FUNCTION   Select   GAFC FS1
42   KATANA:   PEDAL FUNCTION   Select   GAFC FS2
43   KATANA:   Output   Output:   Cab Resonance
44
45
46
47
48
49
4A
4B
4C
4D
4E
4F
50   Panel:   knob   Amp   Type
51   Panel:   knob   Amp   Gain
52   Panel:   knob   Amp   Volume
53   Panel:   knob   Amp   Bass
54   Panel:   knob   Amp   Middle
55   Panel:   knob   Amp   Treble
56   Panel:   knob   Amp   Presence
57   Panel:   knob   Effect   Booster
58   Panel:   knob   Effect   MOD
59   Panel:   knob   Effect   FX
5A   Panel:   knob   Effect   Delay
5B   Panel:   knob   Effect   Reverb
5C   Panel:   led state   Amp   Variation
5D   Panel:   led state   Effect   Booster
5E   Panel:   led state   Effect   MOD
5F   Panel:   led state   Effect   FX
60   Panel:   led state   Effect   Delay
61   Panel:   led state   Effect   Reverb
Thanks Robert and Colin for posting this information. I have a Katana 100 Head MK2 on loan. This address map is giving me a head start on adding Katana MK2 compatibility to the VController / VC-mini.
It looks like the parameters and values are the same as Katana Mk1, only the addresses are different. Did you guys notice any changes or features that are different?
The few things I found thus far:
- the spring colour in the reverb block is actually working on MK2 . This parameter does not seem to do anything on the Katana MK1.
- The min, max and contour settings of the footvol pedal have disappeared. I  can't remember if these actually worked on MK1.
There are less (hidden) effects in MOD and FX in the MK2.
Quote from: gumtown on November 03, 2020, 09:58:32 AM
So far all the amps and effects that worked in version 4 of the MK1 are also there in MK2 and seem to work. I am still testing though, so I may find some differences.
MK1 FW4 Katana FX effects
<PARAM value="00" name="T.WAH "/>
<PARAM value="01" name="AUTO WAH "/>
<PARAM value="02" name="PDL WAH "/>
<PARAM value="03" name="ADV.COMP "/>
<PARAM value="04" name="LIMITER"/>
<PARAM value="05" name="SUB OD/DS"/>
<PARAM value="06" name="GRAPHIC EQ "/>
<PARAM value="07" name="PARA EQ "/>
<PARAM value="08" name="TONE MODIFY "/>
<PARAM value="09" name="GUITAR SIM. "/>
<PARAM value="0A" name="SLOW GEAR "/>
<PARAM value="0B" name="DEFRETTER "/>
<PARAM value="0C" name="WAVE SYNTH"/>
<PARAM value="0D" name="SITAR SIM. "/>
<PARAM value="0E" name="OCTAVE "/>
<PARAM value="0F" name="PITCH SHIFT"/>
<PARAM value="10" name="HARMONIST "/>
<PARAM value="11" name="SOUND HOLD "/>
<PARAM value="12" name="AC.PROCESS"/>
<PARAM value="13" name="PHASER"/>
<PARAM value="14" name="FLANGER"/>
<PARAM value="15" name="TREMOLO"/>
<PARAM value="16" name="ROTARY 1"/>
<PARAM value="17" name="UNI-V"/>
<PARAM value="18" name="PAN"/>
<PARAM value="19" name="SLICER"/>
<PARAM value="1A" name="VIBRATO"/>
<PARAM value="1B" name="RING MOD."/>
<PARAM value="1C" name="HUMANIZER"/>
<PARAM value="1D" name="2X2 CHORUS"/>
<PARAM value="1E" name="SUB DELAY"/>
<PARAM value="1F" name="AC GTR SIM"/>
<PARAM value="20" name="ROTARY 2"/>
<PARAM value="21" name="TERA ECHO"/>
<PARAM value="22" name="OVER TONE"/>
<PARAM value="23" name="PHASER 90E"/>
<PARAM value="24" name="FLANGER 117E"/>
<PARAM value="25" name="WAH 95E"/>
<PARAM value="26" name="DELAYCHORUS30"/>
<PARAM value="27" name="HEAVY OCTAVE"/>
MK2 Katana FX effects
<PARAM value="16" name="ROTARY"/>
<PARAM value="03" name="COMPRESSOR"/>
<PARAM value="02" name="PEDAL WAH "/>
<PARAM value="1F" name="AC GUITAR SIM"/>
<PARAM value="12" name="AC.PROCESSOR "/>
<PARAM value="0C" name="WAVE SYNTH "/>
<PARAM value="0F" name="PITCH SHIFTER "/>
StevenMartin
I have a few questions regarding the address mapping.
Could someone explain the 'what/how' for the addresses, size and offset? What are they, how are they used/worked out?
For example, I currently use the addresses in this form: lets say writing to the boost switch at 0x60000010 I would (using the legendary MS_3 library for arduino) write to that address with the data I want (1 or 0) and the size.... but in address_map.js in the BTS mac app package it says the same param has the address of:
var prm_prop_patch_0 = [   // 0x00000010
        { addr:0x00000000, size:INTEGER1x7        , ofs:0   , init:0   , min:0   , max:1   , name:'SW'                     },    // PRM_ODDS_SW
So this obviously doesn't match up and highlights a gap in my knowledge and how it's all working.
I understand that the size is in bytes (mostly 1 or 2) but what do they mean with the Interger1x7 or (PADDING | 0x8)?  I thought an Integer was usually 4 bytes? I understand what they 'mean' by padding, but not how it works or is used.
And what offset is the offset and how is it used?
Excuse the flood of questions, just trying to learn more!
CodeSmart
#15
Quote from: StevenMartin on October 20, 2021, 03:10:04 AM
Long time now since working with this, but everything in MIDI is only 7 bits data so this is a BYTE with only lowest 7 bits used. The 8'th bit needs to be zero.
Padding is a dummy odd byte to get to an even WORD adress. So if adr=100 and you write a BYTE there might be a dummy byte at 101 to get to 102 which is an even address nice for a 16-bit (2xBYTE) addressing.
An integer represents an integral number (not floating point) that can be both negative and positive. Integers can occupy 8, 16, 32, 64 or more bits depending on how it's implemented.
Magic Russ
Here's something I ran into in working with the tsl.  I can't comment if the .syx is the same way.
The default delay time is 400ms.
In the tsl it shows the following two bytes, "03" and "10"
If I put this into a hex calculator, it gives me decimal 784.
It turns out that the 1st byte is multiples of 128 instead of 256 and that the 2nd byte only goes to 127.  So 3*128 + 1 * 16 = 400.
This makes some sense if you think of it in light of MIDI data being 7 bits, but if you haven't done a lot of work deciphering MIDI data, it's an easy mistake to make.
Magic Russ
Also found myself getting burned on a few enums that don't follow the order implied by dropdown menus in BTS.
    public enum KMk2_BoostType
        MID_BOOST = 0,
        CLEAN_BOOST,
        TREBLE_BOOST,
        CRUNCH_OD = 3,
        NATURAL_OD,
        WARM_OD,
        FAT_DS,
        METAL_DS=8,
        OCT_FUZZ,
        BLUES_DRIVE=10,
        OVERDRIVE,
        T_SCREAM,
        TURBO_OD = 13,
        DISTORTION = 14,
        RAT,
        GUV_DS,
        DST_PLUS = 17,
        METAL_ZONE,
        _60S_FUZZ,
        MUFF_FUZZ = 20,
        HM_2,
        METAL_CORE,
        CENTA_OD
    public enum KMk2_DelayType
        DIGITAL = 0,
        PAN,
        STEREO,
        REVERSE = 6,
        ANALOG,
        TAPE_ECHO,
        MODULATE,
        SDE_3000
    public enum KMk2_ReverbType
        ROOM = 1,
        HALL = 3,
        PLATE = 4,
        SPRING = 5,
        MODULATE = 6
