KATANA MK2 - FAQ
Started by admin, October 07, 2019, 11:49:32 AM
KATANA MK2 100 watt SIGNAL FLOW
All Katana MK2 amps provide only a "dual Mono" monitor feed to the Katana Headphone Output jack
You may connect Stereo headphones, but you will only hear a common mono output signal on both ears ( same situation exists on the MK1 Katana Amps)
The Owners Manual lists the Katana MK2 Headphone Output as Stereo - but this is in Error  - there is no Stereo audio monitoring capability with Katana MK2 amps
https://static.roland.com/assets/media/pdf/KTN-Mk2_eng01_W.pdf
KATANA AIR SIGNAL FLOW
Only the Katana AIR mobile amp provides on board True Stereo FX, Stereo USB, and Stereo Headphone monitoring of Stereo USB Audio and Stereo Audio signals fed into the Katana Air's 3.5mm TRS Stereo Aux Input
The Owners Manual lists the Katana MK2 HEAD as having Stereo A/B FX Loop Return jacks  - but this is in Error  - there is no Stereo FX Loop on  Katana MK2 Head
The Katana MK2 manual states only user controls for the Power Amp Input are Master Volume Knob and Power Wattage Control switch
In reality, There are User adjustable High Pass Filter and Signal Level Controls for the Power Amp Input Signal on Katana MK2 , using Boss Tone Studio for Katana MK2
This means the Power Amp Input is actually feeding an A/D and the Power Amp Input HPF Filter and Level Controls are in the DSP
Boss Tone Studio for Katana MKII User Manual
https://static.roland.com/assets/media/pdf/BTS_KTN-Mk2_eng01_W.pdf
Has errors  - Pages 13 & 14
refers  to "Backing up your GT-1000"
- when they really mean "Backing up your Katana MKII"
Posted byu/gwilymjames
16 hours ago
Using the Mac sidecar feature to wirelessly control Boss Tone Studio on my iPad.
from r/BossKatana
https://support.apple.com/en-us/HT210380
Extend or mirror your Mac desktop with Sidecar
