Guitar Wiring - Peavey T-60
Started by admin, May 10, 2018, 09:44:47 AM
The most versatile passive wiring was the old 1980 era Peavey T-60 - and rewiring any Les Paul to the T60 wiring yields a very wide palette of new "non Gibson" tones and accomplishes all I wrote above:
a Les Paul type guitar wired as above yields an amazing array of tones
Phase Switch for Peter Green Tones
Rotary Tone Controls 0-9 = Humbucking Mode and Gibson Tones
Rotary Tone Controls on 10 = Single Coil Mode and Fender Tones
While Bridge Rotary Tone Control on 10 = Single Coil Mode and Fender Tones, now the Phase Switch functions as a Bridge PU Coil select switch -
selects which coil of the Bridge Humbucker is active,
When Bridge PU coil closest to Bridge is active  = Telecaster type tones
When Bridge PU coil furthest away from Bridge is active  = Clapton early 70's Quack Stratocaster Mid+Bridge type tones
The only flaw with this wiring is the Volume pots are wired to MIX the Neck & Bridge Pickups, but htis shunts each PU output to Ground, which kills tone (Not like Gibson) - instead swap the leads so the pot wiper feeds the PU Select switch, and this opens up the tone
Treble Bleed with 500k pots
Details
http://thesnowfields.com/manuals/Peavey%20T40%3AT60.pdf
http://www.samuelbarker.net/t60mafia/mods.html
https://www.samash.com/spotlight/sam-ash-obscure-du-jour-peavey-t-60-guitar
