Author Topic: Roland GI-10 Schematic  (Read 177 times)
Offline kevink
« on: August 28, 2017, 04:43:09 PM »
Does anyone know where I can get a schematic for a Roland GI-10?
Thanks,
Kevin
Offline HAMERMAN409
Re: Roland GI-10 Schematic
« Reply #1 on: August 28, 2017, 10:43:59 PM »
Here is a little bit of the power section.
http://music-electronics-forum.com/t44505/
I haven't run across a full schematic. I own a GI-10 so if you need to identify a blown IC or anything like that I may be able to help.
Offline kevink
« Reply #2 on: August 29, 2017, 01:50:52 AM »
My unit actually works OK. I 'm looking for a schematic because I want to modify it so I need to get a look at the input circuitry for each string.
Thanks.
Offline HAMERMAN409
« Reply #3 on: August 29, 2017, 08:36:49 AM »
OK - then I would recommend taking a look at the GR-30 service notes because there's a good chance that the input sections are very similar.
You can find one here: http://www.synfo.nl/pages/servicemanuals.html
http://www.synfo.nl/servicemanuals/Roland/GR-30_SERVICE_NOTES.pdf
« Last Edit: August 29, 2017, 10:27:35 AM by admsustainiac »
Offline kevink
« Reply #4 on: August 30, 2017, 08:29:37 AM »
The input sections probably are similar but I need the proper schematic to identify the entire buffer chain and conclusively know which IC carries which signal path at each point in the chain.
Thanks,
Kevin
Offline admsustainiac
« Reply #5 on: August 30, 2017, 09:10:57 AM »
Only official Roland repair centers obtain these now
start there
Offline kevink
« Reply #6 on: August 30, 2017, 09:44:57 AM »
I called Roland but they only release schematics to authorized repair centers. I was an authorized repair tech for years and had access to schematics from every major manufacturer but I moved to LA and have been working in studios for 20+ years now. Since I'm no longer a bench tech I'm on the outside of that world now. I really miss access to technical documentation.
Just saw Bill's response, I'll PM you. Thanks so much!
Kevin
