Author Topic: Can you use ethernet cable to run midi signals?  (Read 279 times)
Offline philjynx
« on: June 05, 2017, 01:06:57 AM »
My midi controller has both usbMidi and Din Midi - so three cables.
I find that a bit of a PITA so I want to run those signals through an 8 core ethernet cable/RJ45 so I only have one lead to connect.
As far as I can see, there are enough conductors available but I don't know anywhere near enough about electronics to predict whether there will be cross talk issues.
Question is, can I get away with that or not, it would be so much neater to have just one cable instead of the three that are bundled together at present?
I am playing all the right notes. But not necessarily in the right order.
Offline sixeight
Re: Can you use ethernet cable to run midi signals?
« Reply #1 on: June 05, 2017, 01:17:16 AM »
Yes you can. The VG99 uses an ethernet cable to connect two midi signals and power to the FC-300 (RRC2) . So if Roland can do it, you can as well.
Offline philjynx
« Reply #2 on: June 05, 2017, 01:19:01 AM »
Yes you can. The VG99 uses an ethernet cable to connect two midi signals and power to the FC-300. So if Roland can do it, you can as well.
Cheers sixeight! Don't forget to have a look at that midi queue code I wrote for you!  :)
Online gumtown
« Reply #3 on: June 05, 2017, 02:15:48 AM »
Just ensure you use 'twisted pairs' for each circuit, which will help both with cable capacitance, cross talk, and emitted noise.
pair 1 = pins 5+4
pair 2 = pins 1+2
pair 3 = pins 3+6
pair 4 = pins 7+8
shielded UTP cable is best for this application
maximum distance for a USB cable is 5 metres (16 feet)
a midi cable can exceed the recommended 50 feet recommended limit, and has been known to work up to 400 feet.
« Last Edit: June 05, 2017, 02:20:12 AM by gumtown »
Offline sixeight
« Reply #4 on: June 06, 2017, 11:39:41 AM »
The VG99 also uses these pairs:
Online admsustainiac
« Reply #5 on: June 06, 2017, 11:52:35 AM »
And there is an off the shelf solution for MIDI over Cat-5
Eureka Sound MIDIMIZER
http://www.vguitarforums.com/smf/index.php?topic=17582.msg125187#msg125187
« Last Edit: June 06, 2017, 11:55:13 AM by admsustainiac »
