Author Topic: GT-100 Amp Switching with Midi in a Patch  (Read 234 times)
Offline steviebabes
« on: May 09, 2017, 11:53:18 AM »
Hi Guys, I'm hoping someone can help, or at least put me out of my misery.
I'd like to switch channels on my Blackstar Series One, from within a patch, on my GT-100, and I just cannot quite figure out where the setting is to control it.
I can see that with the Midi out connected to the amp as I change patches the amp switches channel, so the 4 patch change buttons are working  I just want to be able to set that for some patches and not for others and use the Accel/CTL pedal to do usual switching of effects on and off and send a Channel Change message to change the amp channel.
Online gumtown
Re: GT-100 Amp Switching with Midi in a Patch
« Reply #1 on: May 09, 2017, 01:29:31 PM »
I am not learned on the BlackStar amps, but if it only listens to patch change, then it will only change channel as the GT-100 changes patch.
The GT-100 does not have any function to select which pedal sends patch change or not, the patch change message is only sent as the GT-100 does an actual path change within itself.
The other option is the use the GT-100 AMP CTL jack, assigned to a peda to do A/B channel switching of your amp, if it supports a foot switch type channel changer.
