Author Topic: SY-300 - Clean Fender Amp  (Read 283 times)
Offline Rhcole
« on: May 02, 2017, 06:31:42 PM »
This patch is nothing more than a generic Fenderish clean amp. It has spring reverb and tremelo. Ctl 1 turns the tremelo on and off. You may need to adjust the reverb for yourself, as I use an Exp pedal to control it. I have found that this amp responds very differently to different guitars and pickup combinations, so tweak these as you need to.
Consider this section a module to use as needed within other patches. You don't get the tube "bloom" and sparkle of a real Fender amp, but if you were only about that, you wouldn't be using the SY-300, would you?  ;)
Online lumena
Re: SY-300 - Clean Fender Amp
« Reply #1 on: May 03, 2017, 10:55:07 AM »
super can't wait to try it. thanks so much I have been fumbling with different settings and I am hoping that as usual you have already felled the trees and made a path.
L>
