Author Topic: GT-100 - BOSS TONE STUDIO - BUG FIX / MacOS 10.12 compatible  (Read 596 times)
Offline Elantric
« on: March 10, 2017, 10:52:27 AM »
Support for macOS Sierra (10.12) was added.
Bug Fixes
Unintended patch data sometimes being sent during a patch-selection operation was corrected.
The values of ASSIGN 4-8 settings are not correctly sent to the unit from LIBRARIAN.
Some keyboard operations failing to work properly was corrected.
Other modification to the behavior of the user interface were made.
BTS for GT-100 (WIN)
https://www.boss.info/global/support/by_product/gt-100/updates_drivers/e3f75e9c-179d-4742-81b3-93e968963876/
BTS for GT-100 (MacOS 10.12 compatible)
https://www.boss.info/global/support/by_product/gt-100/updates_drivers/2243fbf9-2f2a-4ccf-a20b-347335dbbab1/
Offline HueMan
Re: GT-100 - BOSS TONE STUDIO - BUG FIX / MacOS 10.12 compatible
« Reply #1 on: March 21, 2017, 07:29:10 PM »
Hello Elantric.I recently downloaded Version 2.10 for GT-100 and I am getting Midi loop back error.Make sure Midi Thru is switched off. GT-100 does not have midi thru function and I have rescanned  Midi Setup several times, removed and added the device back. Checked all versions of all hardware and software including Bosstone Studio.I have used GTFx Floorboard and it tries to initialize just as Bosstone studio but it cannot see the driver. I have installed Ver2-1 driver correctly. When I use Logic Pro X it does not recognize a midi device either.Obviously something is wrong but I cannot figure it out. Also I have uninstalled and reinstalled the driver for GT 100 and it is showing Ver 2.10. Updater message is Bin File missing . Please help .
Offline Elantric
« Reply #2 on: March 21, 2017, 07:46:08 PM »
What is your OS?
(MacOS Sierra?)
 Most problems with -Roland boss gear is directly attributed to the owner not reading and following the steps detailed in the installation instructions Roland/Boss has provided (Read_Me.htm or PDF installation instruction file) already contained inside every firmware /USB Driver/BTS download file from  Roland /Boss
Those help files are crucial reading
« Last Edit: March 21, 2017, 08:55:24 PM by Elantric »
Offline gumtown
« Reply #3 on: March 21, 2017, 08:33:11 PM »
Have you updated your GT-100 firmware to 2.10 yet?
https://www.boss.info/global/support/by_product/gt-100/updates_drivers/7172d7ae-7c14-4ab0-a105-d8faba48d4a0/
do the firmware update first, then you will be able to use the new USB driver.
Offline HueMan
« Reply #4 on: March 23, 2017, 08:24:08 PM »
Yes I updated the firmware and installed in the correct order. MacOS 10.12 . I must be the only person to encounter that particular bug. I have been using 2.03 since the update a while ago. I am using Boss as a controller for my DAW and automation. For some reason Mac was saying it could not see Midi device. The next time it said Midi loopback error and Midi Thru needed to be turned off.  I must say, Roland manuals are a little different  :-\    . For example it says HOW TO INSTALL  "When using BOSS TONE STUDIO for GT Ver.1.0.0-Ver.1.1.0" .  Is it me or shouldn't that say   GT Ver.2.10 ?  That is clearly part of the instructions. I hope this works.
Offline gumtown
Online admsustainiac
« Reply #6 on: May 04, 2017, 07:09:54 AM »
All Boss Tone Studio for Windows download links have been removed while Roland /Boss sort out why recent MS Windows update/Adobe AIR updates present a conflict for the BTS Installer
If you already have HYS installed ,please DO NOT REMOVE IT .
I might take a few months for Roland/Boss to deliver a fix
Meanwhile ,use Gumtown's Floorboard Editor for your device (Katana,GP-10,GT-100,GT-001)
https://www.thegearpage.net/board/index.php?posts/24057971/
To all those having problems installing tone studio on windows 10: Set your date back (a year will do) and then run the install - this will get it installed and then you can change the date back to the correct date - All Good!
I believe it is probably something like a code signing certificate has expired (or similar) - changing the date gets around whatever check it is performing during the install. Enjoy!
