Author Topic: GT-100 - Live Rig/Set up question for GT-100  (Read 458 times)
Offline PatrickB
« on: February 13, 2017, 04:18:22 PM »
Would like to run the Gt-100 thru PA system AND to another amp onstage (thru effects return) for a monitor/stage sound. Anyone have any tips/experience doing this?
« Last Edit: February 13, 2017, 07:08:36 PM by admsustainiac »
Offline OldPunk
Re: GT-100 - Live Rig/Set up question for GT-100
« Reply #1 on: February 14, 2017, 09:18:01 AM »
Perhaps use a DI/splitter?  Or straight into your amp's return, then out to PA..
Offline gumtown
« Reply #2 on: February 14, 2017, 12:03:34 PM »
Use the L/R main outputs to the PA/desk, with output select set the "Line/Phones" to enable cabinet emulation.
Move the S/R loop to the end of the chain and use the "S/R Send" to the amp,
this will bypass the cabinet emulation which resides at the output stage of the signal chain.
Ensure the SR Loop is set to "Branch out" mode to keep the through signal going to the main output.
« Last Edit: February 14, 2017, 12:46:07 PM by gumtown »
Offline PatrickB
« Reply #3 on: February 14, 2017, 04:42:35 PM »
awesome....Thanks Guys!!  ;D
Offline Sevenmodes
« Reply #4 on: March 27, 2017, 10:51:59 AM »
Patrick - I have a few follow up questions because I'm thinking of doing the same.
What are you using for stage amp/monitor? Are you happy with splitting to PA and using the cab sims? Have you (or anyone) compared with mic'ing the stage amp and turning off cab sims?
I've been considering a Tech 21 PE60 (or similar...suggestions appreciated) as my stage amp or similar for a while and wondering if others had experience.
Offline PatrickB
« Reply #5 on: April 14, 2017, 09:28:26 AM »
Sorry for the late responds....But I haven't gotten to that stage yet. Have not had a chance to experiment yet. :)  Currently, I'm running the 4-cable method and I'm pretty happy with the sounds I can get.
